Results 1 to 10 of 10
Thread: Focus in OSCAM
    04 Apr 2009
    Default Focus in OSCAM
    Ma poate ajuta careva sa pun bazele unui server OSCAM cu Focus ca local? As dori sa intru si eu in febra asta OSCAM(server+client) sa vad ce poate. Cardul este in Smartbee legat la UFS910 prin convertor serial->USB. Multumesc anticipat.
    04 Apr 2009
    Am incercat diverse versiuni de oscam cu aceasta configuratie la oscam.server:
    # reader configuration
    # USB serial reader
    [reader]
    label = reader2
    protocol = mouse
    detect = CD
    device = /dev/ttyUSB0
    group = 1
    emmcache = 1,3,2
    services = focustv_Familia
    caid = 0B02
    Din pacaete nu-mi ia localul de nici o culoare.Cam asta imi apare in log:
    >> OSCam << cardserver started at Sat Oct 2 23:45:37 2010
    2010/10/02 23:45:37 1530 s version=1.00-svn, build #3336, system=sh4-amino-linux, nice=-10
    2010/10/02 23:45:37 1530 s max. clients=29, client max. idle=120 sec, debug level=0
    2010/10/02 23:45:37 1530 s max. logsize=unlimited
    2010/10/02 23:45:37 1530 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=0 ms
    2010/10/02 23:45:37 1530 s auth size=4772
    2010/10/02 23:45:37 1530 s services reloaded: 0 services freed, 13 services loaded
    2010/10/02 23:45:37 1530 s userdb reloaded: 0 accounts freed, 1 accounts loaded, 0 expired, 0 disabled
    2010/10/02 23:45:37 1530 s signal handling initialized (type=sysv)
    2010/10/02 23:45:37 1530 s 72 service-id's loaded
    2010/10/02 23:45:37 1530 s can't open file "/var/keys/oscam.tiers" (err=2), no tier-id's loaded
    2010/10/02 23:45:37 1530 s can't open file "/var/keys/oscam.provid" (err=2), no provids's loaded
    2010/10/02 23:45:37 1530 s monitor: initialized (fd=7, port=988)
    2010/10/02 23:45:37 1530 s camd 3.3x: disabled
    2010/10/02 23:45:37 1530 s camd 3.5x: disabled
    2010/10/02 23:45:37 1530 s cs378x: disabled
    2010/10/02 23:45:37 1530 s newcamd: disabled
    2010/10/02 23:45:37 1530 s cccam: initialized (fd=8, port=12000, crypted)
    2010/10/02 23:45:37 1530 s radegast: disabled
    2010/10/02 23:45:37 1530 s http thread started
    2010/10/02 23:45:37 1530 s creating thread for device /dev/ttyUSB0 slot 0 with ridx 0 cs_idx 2
    2010/10/02 23:45:37 1530 s reader thread started (pid=1530, device=/dev/ttyUSB0, detect=cd, mhz=357, cardmhz=357)
    2010/10/02 23:45:37 1530 s waiting for local card init
    2010/10/02 23:45:37 1530 h HTTP Server listening on port 8888
    2010/10/02 23:45:40 1530 s init for all local cards done
    2010/10/02 23:45:40 1530 s anti cascading disabled
    2010/10/02 23:45:40 1530 c03 plain dvbapi-client granted (local, au=0)
    2010/10/02 23:45:42 1530 c03 dvbapi: [ADD PID 0] CAID: 0B02 ECM_PID: 14F2 PROVID: 000000 STREAM: 0xffffffff
    2010/10/02 23:45:42 1530 c03 dvbapi: new program number: 76C2 (TVR 1)
    2010/10/02 23:45:42 1530 c03 local (0B02&000000/76C2/4C:0E2D): not found (1 ms)
    2010/10/02 23:45:42 1530 c03 dvbapi: try pids again #1
    2010/10/02 23:45:42 1530 c03 local (0B02&000000/76C2/4C:03B0): not found (3 ms)
    2010/10/02 23:45:42 1530 c03 dvbapi: try pids again #2
    2010/10/02 23:45:52 1530 c03 local (0B02&000000/76C2/4C:6037): not found (0 ms)
    2010/10/02 23:45:52 1530 c03 dvbapi: try pids again #3
    2010/10/02 23:45:52 1530 c03 dvbapi: can't decode channel
    Mentionez ca am cardul pus la UFS910 printr-un SmartBee 3,579Mhz legat printr-un convertor Serial->USB.
    30 Dec 2008
    France
    what're parameters in your oscam.conf ( dvbapi ? )
    Flash : AAF2.e
    USB Stick with BA : RSP ( pkt ou AAF) with OSCAM
    5?W_13?E_19?E_28?E
    04 Apr 2009
    oscam.conf
    # main configuration
    [global]
    nice = -10
    WaitForCards = 1
    # logging
    pidfile = /var/run/oscam.pid
    logfile = /var/log/oscam.log
    usrfile = /var/log/oscamuser.log
    cwlogdir = /var/log/oscam/cw
    # monitor
    [monitor]
    port = 988
    aulow = 120
    monlevel = 1
    # web interface
    [webif]
    httpport = 8888
    httpuser = myusername
    httppwd = mypassword
    # anti-cascading
    # protocols
    [cccam]
    port = 12000
    version = 2.1.4
    reshare = 2
    [dvbapi]
    enabled = 1
    boxtype = ufs910
    user = local
    30 Dec 2008
    France
    i think you have an oscam.user, as
    [account]
    user = local
    pwd = ???????????
    disabled = 0
    group = 1
    uniq = 0
    monlevel = 0
    au = 1
    caid = 0B02
    ident = 0B02:000000
    keepalive = 1
    other trials :
    1 test without focustv_Familia in the line "services" of your reader file
    2 check if your card is in the list of oscam ( http://streamboard.gmc.to:8001/wiki/CardsList)
    Flash : AAF2.e
    5?W_13?E_19?E_28?E
    30 Dec 2008
    France
    if you want to test and say me the results
    [dvbapi]
    enabled = 1
    au = 1
    boxtype = ufs910
    user = local
    pmt_mode = 0
    priority = 0622,0B02,0963,093B,0604,0500
    ignore = 0919
    nb: about novacinema1 from NOVA HELLAS ?
    Flash : AAF2.e
    5?W_13?E_19?E_28?E
    04 Apr 2009
    stil doesn't work. maybe this card in SmartrBEE is not compatible with oscam,
    04 Apr 2009
    singurul mod in care am reusit sa fac sa-mi citeasca focusul a fost sa-l pun in newcs si sa-l leg la oscam. acum au mai aparut vreo 2 probleme:
    1. am 2 peeri cccam eu ma pot conecta la ei , ei la mine nu ( port 12000 setat in oscam.conf este deschis din router)
    2. pe langa cele doua linii cccam am alte 5 linii newcamd, la care ori nu se conecteaza ori nu le foloseste de loc daca sunt si cele ccccam pe langa ele.
    30 Dec 2008
    France
    wiki oscam said : this card is tested succesfull
    and
    Conax
    Focus Sat (UPC)RO0B02:000000OK3.57
    Focus Sat - UPC RO (0B02:000000)
    ATR: 3B 24 00 30 42 30 30
    • CAID: 0B02
    • Providers:
      • id: 000000, name:
    • ECM: ok
    • EMM: ok
    May be these files can help you
    oscam.services
    caid=0B02
    provid=000000
    srvid=00CB,03EB,03ED,03EE,03EF,7599,76C2,76C3,76C4,76C5,76C6,76C7,76C8,76C9,76CA,76CB,76CC,76CD,76CE ,7725,7726,7727,7728,7729,772A,772B,772D,772E,7730,7731,7732,7733,7789,778A,778B,778C,778E,7791,7792 ,7793,7794,7795,7797,7798,77ED,77EE,77F6,77F7,77F8,77FA,7851,7853,7855,7856,7857,7858,785A,785B,785E ,785F,78B5,78B8,78BA,78BB,78BC,78BD,78BE,78C2,78C3
    oscam.srvid
    Code:
    #UPC RO - Focussat
    0B02:00CB|Focus|Travel Channel|TV|
    0B02:03EB|Focus|SportKlub Romania|TV|
    0B02:03ED|Focus|VH1 Romania|TV|
    0B02:03EE|Focus|Fishing & Hunting|TV|
    0B02:03EF|Focus|DOQ|TV|
    0B02:7599|Focus|Eurosport2 NEE|TV|
    0B02:76C2|Focus|TVR 1|TV|
    0B02:76C3|Focus|TVR 2|TV|
    0B02:76C4|Focus|TVR Cultural|TV|
    0B02:76C5|Focus|Antena 1|TV|
    0B02:76C6|Focus|Prima TV|TV|
    0B02:76C7|Focus|Realitatea TV|TV|
    0B02:76C8|Focus|National TV|TV|
    0B02:76C9|Focus|Favorit TV|TV|
    0B02:76CA|Focus|Universal Channel|TV|
    0B02:76CB|Focus|Romantica RO|TV|
    0B02:76CC|Focus|MTV Romania|TV|
    0B02:76CD|Focus|Minimax|TV|
    0B02:76CE|Focus|Telesport|TV|
    0B02:7725|Focus|Pro TV|TV|
    0B02:7726|Focus|Pro Cinema|TV|
    0B02:7727|Focus|Acasa|TV|
    0B02:7728|Focus|Sport.ro|TV|
    0B02:7729|Focus|Pro TV International|TV|
    0B02:772A|Focus|Antena 3|TV|
    0B02:772B|Focus|TVR 3|TV|
    0B02:772D|Focus|Animal Planet RO|TV|
    0B02:772E|Focus|National Geographic RO|TV|
    0B02:7730|Focus|Cartoon Network RO/TCM RO|TV|
    0B02:7731|Focus|AXN RO|TV|
    0B02:7732|Focus|Cinemax ROM|TV|
    0B02:7733|Focus|Etno|TV|
    0B02:7789|Focus|B1|TV|
    0B02:778A|Focus|Euforia Lifestyle|TV|
    0B02:778B|Focus|N24|TV|
    0B02:778C|Focus|Sport1 RO|TV|
    0B02:778E|Focus|TVR Info|TV|
    0B02:7791|Focus|Discovery RO|TV|
    0B02:7792|Focus|CNN|TV|
    0B02:7793|Focus|Antena 2|TV|
    0B02:7794|Focus|Reality ROM|TV|
    0B02:7795|Focus|Trinitas|TV|
    0B02:7797|Focus|HBO RO|TV|
    0B02:7798|Focus|VH1 Classic|TV|
    0B02:77ED|Focus|Extreme Sports|TV|
    0B02:77EE|Focus|JimJam EMEA|TV|
    0B02:77F6|Focus|Boomerang|TV|
    0B02:77F7|Focus|Nat Geo Wild|TV|
    0B02:77F8|Focus|Discovery T&L|TV|
    0B02:77FA|Focus|TV5MONDE|TV|
    0B02:7851|Focus|Discovery Science|TV|
    0B02:7853|Focus|bebe tv|TV|
    0B02:7855|Focus|Hustler TV|TV|
    0B02:7856|Focus|Viasat History|TV|
    0B02:7857|Focus|MGM|TV|
    0B02:7858|Focus|ESPN America|TV|
    0B02:785A|Focus|MTV Rocks|TV|
    0B02:785B|Focus|AXN Crime|TV|
    0B02:785E|Focus|History|TV|
    0B02:785F|Focus|Disney ROM|TV|
    0B02:78B5|Focus|Eurosport|TV|
    0B02:78B8|Focus|Viasat Explorer|TV|
    0B02:78BA|Focus|AXN SCI-FI|TV|
    0B02:78BB|Focus|MTV Dance|TV|
    0B02:78BC|Focus|HBO Comedy|TV|
    0B02:78BD|Focus|Daring TV|TV|
    0B02:78BE|Focus|Nickelodeon|TV|
    0B02:78C2|Focus|Cinemax 2|TV|
    0B02:78C3|Focus|Blue Hustler|TV|
    Flash : AAF2.e
    5?W_13?E_19?E_28?E
    04 Apr 2009
    i know...but i think that oscam doesn't like my serial-to-usb converter and that's why it doesn't work. it works ok with newcs as the reader for oscam. do you have any ideeas about isue no.1 ( i fixed no.2)?
