Dislikes:
Member
Beginner
- Rep Power
- 0
SifTeam-0.4.0-r13319
Ultima imagine SIFTEAM pentru toate modelele o gasitii aici:
http://www.sat-universe.com/showthread.php?t=185400
This README is for CubeRevo HD model series.
This document was approved on 24/September/2010 by the Cuberevo-Digital.
Cuberevo-digital release r13319: ( 24/September/2010)
1. Add usb hdd function for small size(4GB ~ 32GB) USB memory stick
but you have to formatting USB memory stick before using timeshit buffer or Storage.
Main Menu --> Go to PVR Setting --> Press Green button --> Select the USB memory stick
2. Improve navigation speed on Grid EPG menu
3. Fix bug and memory leak on Media list menu.
4. Fix memory leak on channel search menu
5. Fix bug as panic on unicable menu.
6. Fix local time bug, expecially, front panel time error of 3000HD
7. Fix bug DiSEqC and USALS
8. Fix panic with PIP function
9. Fix nonstandard EPG in Eutelsat W3A(7.0E)( Amir, thanks a lot )
10. Fix memory leak on channel list(Pacco, many thanks for your great effort )
11. Update Germany by Nils(Nils, thank you so much)
12. Update Web interface Ver.1.6.02 by Nils(Nils, thank you so much, too.)
Caution
1. Back up your data of HDD except the version of r12947 software in your box
At first, you have to back up recorded file or photo, mp3 data from STB
before downloading this image if you need. This image is supported to something
different file format or data format compare with previous software image.
2. Format HDD except the version of r12947 software in your box
You should be format HDD after downloading completed this new image,
otherwise, it will be possible to malfunction about PVR, timeshift, mp3,photo album and so on
Note.
1. Prohibited to recording, and PIP function in Server box when Multiroom Service or Streaming Player is running.
and The boxes should have same FTP user ID/Password with server box and client box when you use Multiroom service function
2. ext3 file system is slower than ext2 normally.
If you will record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
---------- Post added at 20:31 ---------- Previous post was at 20:26 ----------
Pentru toate modelele DGS:
http://dreambox.sifteam.eu/index.php?dir=9000HD/r13319/
Member
Visitor
- Rep Power
- 0
Ipbox 91 hd - cuberevo 250hd
Dear all,
I'm kindly seeking your support as i'm not able to use the IPBOX 91 HD - CUBEREVO 250HD, i switch on and connect the same to the LAN cable. The network IP configurations appear i.e. network connectivity is available but still the receiver can't decode locked channels.
Any one can help how to make it work?
By the Way i'm trying to use the same in Dubai.
- Rep Power
- 75
1.
use FTP client ( eg. Total commander ) for copy url by /var/etc/SifTeam/tmp
change name in url2
edit file url2 by linux editor ( eg notepad ++ ) and change address in
http://www.secondpanel.comli.com/DGS/
use FTP client ( eg. Total commander ) for copy url2 by /var/etc/SifTeam/tmp
after restart , new address is available for download emulators
2.
encrypted channels are less accessible without subscription and transmission is focused on Europe ( eg RAI on 13E and Arquiva on 5E )
