Results 1 to 8 of 8
Thread: Windows 7 (Seven)
    RSP Team XVanish's Avatar
    Baia Mare
    10 Post(s)
    Lightbulb Windows 7 (Seven)
    In acest topic >> totul despre Windows 7 aka Windows Seven
    Quote Originally Posted by XVanish
    Pentru cei care atunci cand folosesc ghilimele (" exemplu ") sau ghilimelele simple (' exemplu ') si nu le apar din prima, decat dupa ce mai scriu ceva, schimbati-va limba din US International English in English >> US si puneti-o pe aceasta pe default.
    Contral Panel >> Region and Language >> Keyboards and Languages >> Change language...
    Sper sa va fie de folos...
    43 Post(s)
    De astazi de dimineata tot primesc aceasta eroare cand deschid Firefox:
    [JavaScript Application]
    Connection error! Please check your connection to the internet and then try again using the Refresh option in the meniu
    Paginile se deschid,am conexiune la net dar de unde apare asta ca ma disperat.Ce trebuie sa fac sa scap de ea?
    43 Post(s)
    Uhhh!Am rezolvat.Era de la un plugin din browser care nu functiona.I-am dat disable si totul e ok.
    29 Mar 2009
    Austria - TM
    Default Win7codecs 2.6.4 Final ( SHARK007 )
    changelog:
    - update gabests filters 2616
    - update ffdshow 3597
    UNINSTALL YOUR OLD VERSION - upgrades are DISABLED
    When choosing to uninstall this software you MUST use the
    button on the Help TAB.
    Deinstallieren Sie die alte Version!!! - Upgrades
    werden nicht unterstutzt. Dieses fuhrt zu Fehlern!!!
    Über den Reiter Hilfe, finden sie das Deinstallations Menu.
    21 Mar 2008
    zona HD
    Am si eu o problema . De cand am Win 7 , nu mai pot sincroniza tel.mobil htc dual cu microsoft outloock . Ideea e ca daca vreau sa lansez Windows Device Mobile Center, se apuca sa-l instaleze , dar da repede urmatorul mesaj :
    Windows Mobile Device Center could not be installed because at least one required Windows component is missing.
    Dar nu zice ce lipseste. Am descarcat si pe net "drvupdate.exe" si la instalare acelas mesaj.
    Ce-i de facut ?
    29 Mar 2009
    Austria - TM
    Win7codecs 2.6.6 Final
    changelog:
    - update gabests filters 2689
    - update ffdshow subtitle settings
    - update dc/bass filters 1.3/2.46
    29 Mar 2009
    Austria - TM
    Win7codecs 2.6.8 Final
    changelog:
    - update ffdshow 3631
    - update gabest filters 2741
    - improve suggested settings
    29 Mar 2009
    Austria - TM
    Win7codecs 2.6.9 Final
    changelog:
    - fix no ac3 audio
