Dislikes:
AAF Hot Summer Version 2 Image VU+ Duo AAF Hot Summer Version 2 Image
E2 update
-- MEDIA PLAYER
- Fix skip funciotn problem when there is a subtitle.
- Fix pause/unpause problem
- Support FF( up to x8 ) trick mode
Driver update
- Separate gcc 4.4.3 version and 4.1.1 version
- Make screen blank when zapping
- Enhance tuning algorithm
- Support more mkv file formats.
- Fix occasional "no audio" problem in playback
- Fix "late audio play" problem in playback
- Support FF trick mode in playback
- Adjust memory allocation(Solo, needs a kernel update)
- Support DTS Passthrough(Solo)
- Fix vtuner frontend info
- Support EOS detection in playback driver
- Fix mp3 playback problem
- Fix "late audio problem" in recording playback.
- Fix trickmode timing-bar display
- Fix remote control *** loss problem
- Fix VFD dolby display problem in standby(duo)
- Fix progrssive proc information
- Fix back ground image problem in radio mode
- Clean up frontend driver
AAF:
+ AAF-Panel
+ Volume Adjust with AC3 support
+ BlueKey Action (Default/Softcam/single EPG/multi EPG/graphic EPG/MyTube Player/AAF-Panel/other extension)
+ RedKey Action (Default/AAF-Panel)
+ GreenKey Action (open Plugin Browser when no subchannels)
+ Grab (credits to scope34 Vu+ Team)
+ default skin DMConcinnity-HD (credits to Mister-X)
+ BrushedAlu-Coolman-Blackmod V2.03 skin (credits to Coolman)
+ Addon-Manager V2.09
+ PowerControl V1.0 (new kernel+systemplugin) (credits to scope34 Vu+ Team)
+ FanControl
+ WirelessLan
+ Upnp
+ Usb-Serial drivers (smargo and others)
+ Backup/Restore Image (credits to scope34 Vu+ Team)
+ fix ecm time (workaround)
+ webremote VU+ picture
+ MyTube fix from 28/08/2010
+ Boardviewer V1.2
Euer AAF Team
Configurable color buttons:
BlueKey Action: bind a extension to the blue button ( Default/Softcam/single EPG/multi EPG/graphic EPG/MyTube Player/AAF-Panel)
RedKey Action: bind the AAF-Panel to the red button ( Default/AAF-Panel )
GreenKey Action: Shows the plugin browser when the channel has no subchannels (not configurable )
Known bugs :
- Some skins give a GS when using MediaPlayer
- Cccam.info give a GS with Avi,Mytube
DOWNLOAD
USB
Serial
O imagine foarte buna ca si prima impresie.
