Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 59
Thread: Intrebari Oscam
  1. #31
    25 Nov 2009
    pai e in prio caid 1880, ignore la restul. am lasat in oscam.servers numai linia cu pricina, nu imi deschide diji de la el nici mortus. zice ca card not found or something. in incubus mere uns.
    sa fie un bug de oscam?
  2. #32
    25 Nov 2009
    Quote Originally Posted by stargate View Post
    daca ai pune si configuratia din oscam poate te putem ajuta dar asa pe ghicite mai greu
    [global]
    logfile = /tmp/oscam.log
    pidfile = /tmp/osca.pid
    disablelog = 0
    disableuserfile = 0
    usrfileflag = 0
    clienttimeout = 5000
    fallbacktimeout = 2000
    clientmaxidle = 120
    cachedelay = 10
    bindwait = 120
    netprio = 1
    clientdyndns = 0
    resolvedelay = 30
    unlockparental = 1
    nice = -1
    serialreadertimeout = 1500
    maxlogsize = 1024
    waitforcards = 1
    preferlocalcards = 0
    saveinithistory = 1
    readerrestartseconds = 3
    readerautoloadbalance = 1
    readerautoloadbalance_save = 100
    [dvbapi]
    enabled = 1
    au = 0
    boxtype = ufs910
    user = dvbapi
    #pmt_mode = 1
    priority = 09C4,1880,0B02,0500,0919,093B,0604,0963,0960,0961,0100
    ignore = 1801,1802,0628,0630,0B02,0B02
    [reader]
    label = s1
    protocol = cccam
    device = server,port
    account = x,z
    group = 2
    fallback = 1
    ecmcache = 1
    blockemm-u = 1
    blockemm-s = 1
    blockemm-g = 1
    blockemm-unknown = 1
    cccmaxhop = 1
    cccwantemu = 1
    nu configul e de vina, am incercat toate posibilitatile
  3. #33
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    vezi in readers entitlement daca iti intra cardul cu pricina, incearca sa maresti cccmaxhop cu 1.
    testeaza diferite vers de OsCAM.
    (urmeaza sfatul lui @mesteru pentru @bliviu27)
    Azbox HD with OpenSPA 3.0 powered by OSCam
    UE46F8000 powered by SamyGO_OSCam
  4. #34
    04 Jan 2010
    Incearca o versiune care merge sigur .ce e nou nu prea merge.
  5. #35
    25 Nov 2009
    @techomate , vreo recomadare?
    Quote Originally Posted by qwess View Post
    cardul e in hop 1, deci eu am in config cccmaxhop = 1deci am ce are el in local plus 1. nu cred ca e cazul sa incrementez parametrul...btw am testat cu toate vers iesite de la thread-ed pana la trunk.
    la reader pentru acel peer am :
    caid: 093B hop: 1 reshare: 1 remote nodes: E451D1F930F69879
    -- Provider 1: 000000 -- 093B:000000 unknown
    caid: 1880 hop: 1 reshare: 1 remote nodes: E451D1F930F69879
    cardfile end
  6. #36
    04 Jan 2010
    recomand 2978 sau 3090,sunt facute in urma cu vreo 2 luni.google-it
    Scoate caid,daca ai cumva setat in oscam.server de pe readerul respectiv.Si nu te zgarci deocamdata la hop ,pune ccmaxhop=3-4 .dupa ce va merge abia aunci pui restrictii.
    scoate linia ignore din oscam.conf
  7. #37
    25 Nov 2009
    am avut si versiunile alea, practic citesc zilnic si updatez zilnic, deci in principiu nu merge, si cred ca e de la peer-ul meu drag dar ramane sa mai testez. la ce ma ajuta sa pun max-hop-ul 3 sau 4? imi vin prea multe carduri.
  8. #38
    04 Jan 2010
  9. #39
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    In .conf, prio si ignore isi dau cap in cap!
    Nu e ca la cccam. Se incearca ceva asemanator la ultimele versiuni prin fisierul separat denumit oscam.dvbapi dar...e nefunctionabil inca.
    Incearca sa pui numai astea la "priority" si "ignore".
    priority = 0100:003311,0963,093b,0500:025900
    ignore = 0500:023800,0500:022f00
    Poti renunta la "ignore". Eu am pus alea pentru Srg-Ssr deoarece am via 4 local si pentru akta pentru ca ....n-am in hop 1 via 22f. La prio nu pui niciodata 1880,1801,1802! E ca si cum n-ai pune nimic. La fel cu 960....61,63....919 si 93b,etc.
    Nu pui niciodata comanda de priorizare si de ignorare pe cardurile aceluiasi provider. Se incurca. Astea le am eu in prio si e instant in deschidere. Doar pe tvr e mai lenes. Fara prio pe acel card deschide instant din cardurile via akta.
    Apoi... in .conf eu unul am la [global] astea
    [global]
    usrfile = /var/log/oscamusr.log
    logfile = /var/log/oscam.log
    cwlogdir = /var/log/oscam/cw
    disablelog = 1
    disableuserfile = 1
    usrfileflag = 0
    clienttimeout = 10
    fallbacktimeout = 5
    clientmaxidle = 150
    cachedelay = 0
    bindwait = 150
    netprio = 1
    clientdyndns = 1
    resolvedelay = 40
    unlockparental = 0
    nice = 10
    maxlogsize = 10
    waitforcards = 1
    preferlocalcards = 1
    saveinithistory = 1
    readerrestartseconds = 7
    lb_mode = 1
    lb_save = 0
    lb_nbest_readers = 1
    lb_nfb_readers = 3
    lb_min_ecmcount = 5
    lb_max_ecmcount = 1000
    lb_reopen_seconds = 900
    resolvegethostbyname = 0
    iar in .server am asa la [reader]
    [reader]
    label = pui ce ai tu
    enable = 1
    protocol = cccam
    device = adresa sau ip,port
    account = user,parola
    services =
    inactivitytimeout = 0
    fallback = 0
    caid =
    ident =
    group = 1 atentie! acelasi grup ca la toate conturile
    ecmcache = 1
    lb_weight = 250 pentru ca linia sa fie prioritara celorlalte
    cccversion = 2.1.3
    cccmaxhops = 3
    ccckeepalive = 1
    ndsversion = 0
    Ca si hopuri cccam poti seta sa ia doar locale astfel incat sa nu plece oscamul pe acelasi caid dar cu ecm mai mic desi e hop mai mare.
    Odata functionabil...se asezoneaza cu fructe de sezon! E cool, suna ca o reteta culinara!
    Incearca si...succes!
  10. #40
    04 Jan 2010
    Quote Originally Posted by parpaneata View Post
    lb_save = 0
    [reader]
    Salut parpaneata.Off-problema de mai sus, spune te rog :
    1.de ce lb save=0 si nu macar 100 dupa cum zic cei care au facut oscamul in exemple,cu cat numarul e mai mare cu atat analiza asupra load balance e mai mare.
    2.group =1 la toti readerii cu linii ccam ?......asa am avut si eu primele luni la folosirea oscamului si parca se misca mai repede dar am inteles ca trebuie group diferit-reader diferit
  11. #41
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    La punctul 1....tocmai de aceea!
    Pentru ca "papa" din procesor degeaba! Lasa-l fara analize pentru ca celelalte setari lb fac exact ce trebuie.
    La punctul 2, eu am tot ce inseamna "reader" in acelasi grup. Ei spun ca trebuie acelasi grup! Astfel readerul local corespondeaza f bine cu readerele celelalte.
    Eu unul cred ca e bine asa. Singura justificare pe care o pot da este ca...nu-mi crapa si nu mi-au crapat niciodata cele doua servere cu oscam.
    Mai am ceva....gasit tot prin testare pas cu pas.
    La cardurile dolce, incercati 318 ca si frecventa de card! O sa ramaneti surprinsi de ecm-uri. La mine sunt in jur de 0,090 constant.
    La cardul Srg-Ssr via 4 merge ok doar pe 357. Ecm in jurul lui 0,230.
  12. #42
    02 Sep 2007
    Timişoara
    Pui readerele in grupuri diferite daca vrei ca unii clienti sa aiba acces numai la unele readere (cum e cazul la mine, am reader local si reader cccam, nu vreau clientii mbox sa "vada" cccam-ul pt ca il voi opri in curand si pentru ca nu vreau trafic suplimentar). Altfel le pui in acelasi grup.
  13. #43
    Standard RSP member bliviu27's Avatar
    03 Feb 2009
    constanta
    Default multumiri
    la mine problema s-a rezolvat cu instalarea noii bimasgini rsp si cu oscamul nou de la panel si setarile de la panel fara nicio modificare. multumiri echipei!!!!!!!!!!!!!!
  14. #44
    25 Nov 2009
    well, mai am o nelamurire:
    de la un peer care sharuie jiji vad in readers/entitlements asa:
    caid: 1880 hop: 1 reshare: 1 remote nodes: XXXXXXXXXXXXXXXX
    -- Provider 1: 002011 -- 1880:002011 unknown
    -- Provider 2: 002111 -- 1880:002111 unknown
    -- Provider 3: 002113 -- 1880:002113 unknown
    dar de la peer-ul de la care nu imi deschide jiji, vad asa:
    adica "no provider"
    are vreo legatura ?
    primul peer are cccam 2.1.1 iar al doilea, 2.0.11.
    in rest am butonat si testat toate versiunile de oscam, dar no luck nu deschide si gata. cu toate modificarile de rigoare sau nu in fisierele de cfg oscam.
  15. #45
    03 Feb 2009
    constanta
    Default mica modificare
    revin cu o parere cu oscam config asa cum l-a postat parpaneata deschide mult mai rapid decat configul descarcat de la panel. poate fi doar las mine asa nu stiu ce sa zic
