Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 59
Thread: Intrebari Oscam
    03 Feb 2008
    Quote Originally Posted by technomate View Post
    cum se poate vedea traficul generat de oscam?
    Pai il vezi in serverul cccam din care trage.
    27 Dec 2008
    Cum sa setez oscam pe kathy cu card viaccess ? Vreau sa fiu server si client .
  3. #18
    04 Jan 2010
    adica sa ii intreb pe cei de la care am linii ?
    Mersi !
  4. #19
    04 Jan 2010
    astea sunt setarile mele pt tvr hd,viaaccess
    .serverul merge bine la fel si clientul
    oscam.conf
    [global]
    nice=-10
    pidfile=/tmp/oscam.pid
    #logfile=/tmp/oscam.log
    #logfile=/dev/null
    disablelog=1
    disableuserfile=1
    maxlogsize=32
    waitforcards=0
    preferlocalcards=1
    cachedelay=0
    saveinithistory=1
    readerautoloadbalance=1
    readerautoloadbalance_save=100
    # WEBIF ----------------------------------------------------
    [webif]
    httpport=8887
    httpallowed=127.0.0.1,192.168.1.1-192.168.1.255
    #pt monitorizare
    [monitor]
    port = 988
    aulow = 120
    monlevel = 2
    NoCrypt = 192.168.1.1-192.168.1.10
    [cccam]
    port = 13000
    version = 2.1.4
    build = 3598
    reshare = 2
    #[newcamd]
    #Key = 0102030405060708091011121314
    #Port = 15000@0500:025900,025910
    [dvbapi]
    enabled=1
    # boxtype: dbox2|dreambox|ufs910|ipbox
    boxtype=ufs910
    user=local
    au=1
    oscam.server
    [reader]
    label = tvrhd_intern
    enable = 1
    protocol = internal
    device = /dev/sci0
    detect = cd
    services = tvrhd
    deprecated = 0
    showcls = 20
    maxqlen = 128
    caid = 0500:000000
    ident = 0500:025900,025910
    group = 1
    ecmcache = 1
    emmcache=1,3,2
    #ecmcache = 1,1,8
    lb_weight = 200
    #mai jos poti pune liniile c de la care primesti
    [reader]
    label=nume_care_vrei_sa_apara_la_info
    protocol=cccam
    device=adresa,port
    cccmaxhop=3
    cccversion=2.1.3
    cccbuild=3165
    account=acount,parola
    #fallback=1
    group=1
    In oscam.user configurezi liniile care le dai,repeti pt cate linii vrei
    [account]
    user=nume_care_vrei_tu
    pwd=parola_care_vrei
    group=1
    uniq=0
  5. #20
    03 Sep 2008
    Cum sa setez oscam pe ipbox 910 am card gigel bk rsa?orice raspuns e bine venit.Mmultumesc
  6. #21
    27 Dec 2008
    Multam fain Technomate!
    Cum pot sa vad daca face au la card?
  7. #22
    04 Jan 2010
    intri in webif (adica intr-un browser de net si scrii ipreceptorort_definit_in_oscam.conf),la mine portul l-am setat 8887.deci ceva de genul 192.168.1.10:8887
    apoi intri pe readers si tre sa ai acolo definit tvr sau local(depinde cum l-ai denumit tu in oscam.server) si dai clk pe icoana din dreapta care inseamna entitlement ..scrie acolo pana cand ai subscriptie
  8. #23
    27 Dec 2008
    Am reusit sa deschid webinterface imi arata cardul local dar numai pentru citeva secunde,apoi imi il arata offline.De ce?
  9. #24
    27 Dec 2008
    Acum am alta problema, nu ma mai pot conecta la webif. , a mers pt. o perioada , m-am desconectat iar cind am incercat sa ma reconectez imi da eroare ( unnable to connect ).
  10. #25
    27 Dec 2008
    Am inteles ca imi trebuie un card reader extern pt. kathy ca sa mearga cu localul in sharing ,care anume e mai bun si care merge cu kathy?
  11. #26
    Standard RSP member bliviu27's Avatar
    03 Feb 2009
    constanta
    Default problema oscam
    ridic urmatoarea problema!
    de 2 zile am pornit un server pe topex. deoarece topexul nu l-am putut configura pe conexiunea pppoe rds am pastrat vechiul router conectat(MSI)cu ip 192.168.0.1 la care am legat in lan topexul cu 192.168.0.2 katy cu 192.168.0.25 si un calc cu 192.168.0.3 .
    topexul functioneaza cu un phoenix atasat si cccam + oscam
    am setat in routerul msi adresa dyndns.org la care am cont si totul e ok.
    am dat linie c unui partener care foloseste cccam si ma vede online si se conecteaza fara probleme. ma conectez cu katy folosind mgcam1.35 si functioneaza insa dupa cateva ore incepe sa freez si se blocheaza motiv pt care incerc oscam.
    fac toate setarile in oscam server la reader si totusi nu vrea sa se conecteze la serverul meu.
    daca bag alte servere la reader katy se conecteaza fara probleme dar la serverul meu nu vrea. precizez ca cccamul din topex e pe port 13000.
    astept sugestii cu precizarea ca nu sunt avansat in domeniu dar sunt dispus sa invat.
  12. #27
    15 Nov 2007
    incearca si cu o versiune mai veche oscam
  13. #28
    25 Nov 2009
    deci hai sa propun urmatoarea problema celor care se cunosc cu oscam+ul.
    am un peer care imi sharuie caid 1880 full, card local, am doar linia lui in config,dar nu imi deschide nimic de la el. Am verificat tot ce se poate verifica, dar nimic.
    are cineva idee ce si cum ?
    in incubus sau mgcamd, merge linia aia ca unsa.
  14. #29
    23 Apr 2007
    P3X-888
    daca ai pune si configuratia din oscam poate te putem ajuta dar asa pe ghicite mai greu
  15. #30
    15 Nov 2007
    Quote Originally Posted by sizan View Post
    pune la prio 1880
