Thanks Thanks:  1
Likes Likes:  1
Results 31 to 45 of 61
Thread: OSCAM - ia conducerea !!!
    O sa incerc sa dau un pachet de install RSP Panel pe alte imagini.
    Pentru cei care fac update la oscam din panel.
    Deoarece am facut schimbari in scriptul de stop trebuie sa respactati urmatorii pasi:
    1. Stop OSCAM
    2. Uninstall OSCAM
    3. Install OSCAM
    3 Start OSCAM
    01 Nov 2008
    Default e2 rsp v3.141
    Noua imagine are rsp panelul schimbat?
    Functioneaza incubus 1.16?
    Driverele pornesc tot cu activare newcs?
    CE IMBUNATATIRI AVEM?
    Are mai multe noutati, dar e o versiune intermediara de panel.
    Din lipsa de timp ramanem inca pe panelul clasic.
    Maine va explic (in premiera public) cum faci kathy ca sa mearga incubus pana la 1.16 pe el.
    15 Nov 2007
    Quote Originally Posted by dorin55 View Post
    pentru ce mai folosesti incubus?.........oscam este mult in fata.
    30 May 2010
    Oscam nu stie bine pe irdeto fata de incubus.
    Functii si optiuni noi.
    Vedeti in WEB.
    Versiunea 3086 pt Sh40.
    Attached Files Attached Files
    oscam_SH40_3086
    Changeset [3087] by schlocke
    loadbalancer: fixed new options - now working
    Changeset [3090] by landlord
    Added documentation for 'lb_mode', 'lb_save', 'lb_nbest_readers', …
    Changeset [3089] by alno
    WebIf: some more cosmetics
    Changeset [3088] by alno
    WebIf: fix typo
           double_check=1 = 0|1 (only if CW double check enabled)
          1 = ECM will be send to two or more readers with the same SC and the CWs will be verified against  each  other,
          lb_nbest_readers must be set to 2 or higher, default:0
           lb_mode = mode
          loadbalance mode:
           0 = loadbalance disabled, ECMs go to all readers (default)
           1 = fastest reader first, after 5 ECMs the reader with the fastest
               response time will be selected
           2 = oldest reader first, reader with the longest no answer
           3 = lowest usage level, the usage level will be calculated by the
               sum of 5 ECMS response times, the higher a reader is busy, the
               higher is usage level
           lb_save = 0|counts
          save autoloadbalance statistics:
            0 = saving of autoloadbalance statistics disabled (default)
           counts = save autoloadbalance statistics every counts ECMs
          To save CPU power a minimum counts of 100 is recommended.
           lb_nbest_readers = counts
          set count of best readers for loadbalancing, default:none
           lb_nfb_readers = counts
          set count of fallback readers for loadbalancing, default:none
           lb_min_ecmcount = counts
          minimal ECM count to evaluate loadbalancing values, default:none
           lb_max_ecmcount = counts
          maximum ECM count before resetting loadbalancing values, default:none
           lb_reopen_seconds = seconds
          time between retrying failed readers/CAIDs/providers/services, default:none
    OSCAM 3090 la panel, cu modificari functionale la pachet:
    -se adapteaza la imaginea de stick si flash
    -oscam.user mutat la emu config (nu se mai suprascrie la update)
    -introdus pasul 2 la stop emu, pas in care se face verificarea opririi.
    04 Jan 2010
    salut !
    cum pot pune si eu imaginea asta pe 910hd ?
    zice ca nu am drepturi daca vreau sa vad postarile de la rsp team
    Mai pe romaneste ca nu inteleg ce zici.
    04 Jan 2010
    vreau sa pun imaginea de care vorbiti pe ipbox910 hd.nu gasesc nicaieri linkul de unde pot trage .
    Imaginea in cauza este pentru UFS-910 (Kathy) si deci nu te intereseaza.
    21 Post(s)
    @technomate - instaleaza-ti imaginea SIF Team E2 097 .... si-ti trimit eu cele
    necesare sa-ti pornesti din rcs_user oscam-ul !
    Imaginea asta o gasesti aici
    01 Nov 2008
    Default oscam
    -am instalat din nou oscam(3090) si tot in keys am gasit oscam.users
    -double_check=1,trimite ecm la doua servere da tot dupa o perioada pe HD ,SKY IT se blocheaza imaginea ca trebuie repornit kathy,am crezut ca se rezolva problema asta
    -am activat newcs,apare in /dev...ttyUSB0,deci driverul ar fi activ ,dar tot nu vede smargo cu oscam(cu imaginea e2 AAF,activand driverul din panou il vede si functioneaza)
