51
20
Dislikes:
oscam 1.00 -svn4965-light-full-Distribution
r4965 | Admin | 2011-04-09 02:39:04 +0200 (Sat, 09 Apr 2011) | 1 line
Add a check to prevent double frees in garbage collector. It also prints out the source file name and line when compiled with debug.
r4964 | Admin | 2011-04-08 21:58:48 +0200 (Fri, 08 Apr 2011) | 1 line
Tuxbox PPC has a toolchain which doesn't match some of the clients it builds binaries for. To fix this errors, Tuxbox PPC doesn't use pthread_cleanup_push anymore. Please test and report in #1743.
oscam 1.00 -svn4966-light-full-Distribution
r4966 | Admin | 2011-04-10 03:00:41 +0200 (Sun, 10 Apr 2011) | 1 line
Correct parameter saving when httpsavefullcfg is set to 1
oscam 1.00 -svn4967-light-full-Distribution
r4967 | Admin | 2011-04-10 11:08:39 +0200 (Sun, 10 Apr 2011) | 1 line
Add garbage to multiple lists to fix high cpu usage on cccam since r4965. Replace add_garbage with ordinary free when releasing an iterator as this only creates unnecessary garbage which can also be cleaned up immediately.
Oscam-1.00-svn4969
Oscam-1.00-svn4969
r4969 | schlocke | 2011-04-10 14:03:05 +0200 (Sun, 10 Apr 2011) | 6 lines
cam: fixed resharemode=3 with minimizecards=2
cccam: added cccstealth to user accounts
cccam/webif: account cccignorereshare, cccstealth, cccreshare now has
default
value of -1, that means use oscam.conf [cccam] values
r4968 | Admin | 2011-04-10 13:21:13 +0200 (Sun, 10 Apr 2011) | 1 line
Most of the time, only one iterator is needed at the same time. To save lots of mallocs/frees, a threadspecific/clientspecific iterator is used in these cases. If the clientspecific iterator is already in use, malloc/free is used instead like previously.
oscam 1.00 -svn4970-light-full-Distribution
r4970 | Admin | 2011-04-10 19:25:49 +0200 (Sun, 10 Apr 2011) | 1 line
Remove clientdyndns from docu as it was removed in r4459
default
Oscam-1.00-svn4970
Oscam-1.00-svn4971
r4971 | landlord | 2011-04-10 21:20:26 +0200 (Sun, 10 Apr 2011) | 1 line
Added new default values for 'cccignorereshare', 'cccreshare' and 'cccstealth' to documentation.
Reason: update
Oscam-1.00-svn4976
Oscam-1.00-svn4976
r4976 | _network | 2011-04-11 19:49:47 +0200 (Mon, 11 Apr 2011) | 2 lines
dvbapi: fix typo from r4972
r4975 | alno | 2011-04-11 19:35:10 +0200 (Mon, 11 Apr 2011) | 1 line
Config: save reader 'enable' parameter only when zero (default is 1)
r4974 | alno | 2011-04-11 19:29:35 +0200 (Mon, 11 Apr 2011) | 1 line
Config: don't save frequencies to conf if readertype is smartreader
r4973 | alno | 2011-04-11 19:19:22 +0200 (Mon, 11 Apr 2011) | 1 line
WebIf: correct reader stats template
r4972 | _network | 2011-04-11 17:05:55 +0200 (Mon, 11 Apr 2011) | 2 lines
dvbapi: fix possible buffer overflow
Oscam-1.00-svn4977
Oscam-1.00-svn4977
r4977 | schlocke | 2011-04-11 23:09:56 +0200 (Mon, 11 Apr 2011) | 2 lines
first try to reactivate the anticascader
oscam 1.00 -svn4981-light-full-Distribution
r4981 | schlocke | 2011-04-12 08:03:40 +0200 (Tue, 12 Apr 2011) | 2 lines
fixed compileerror when compiled without AC
r4980 | Admin | 2011-04-12 02:30:52 +0200 (Tue, 12 Apr 2011) | 1 line
If memory allocation failed in mk_t-functions, an empty constant string was returned. However, freeing this is not possible. Now, these functions also return the constant string if the result is empty. The free_mk_t function takes care to check for this empty returned string before freeing. Furthermore, descriptions were added to the mk_t-functions and a small memory leak was fixed.
oscam 1.00 -svn4982-light-full-Distribution
r4982 | Admin | 2011-04-13 03:01:48 +0200 (Wed, 13 Apr 2011) | 1 line
Fix #1680, thanks to blaky for the good analysis. Furthermore, disabling accounts via WebIf now has immediate effect on connected clients (previously needed first cw which is never requested by monitor clients) and login for disabled accounts is denied from beginning.
oscam 1.00 -svn4983-light-full-Distribution
r4983 | _network | 2011-04-13 10:52:07 +0200 (Wed, 13 Apr 2011) | 2 lines
reduce srvid memory usage
oscam 1.00 -svn4984-light-full-Distribution
r4984 | _network | 2011-04-13 14:23:56 +0200 (Wed, 13 Apr 2011) | 2 lines
dvbapi: filter ecm by length
oscam 1.00 -svn4986-light-full-Distribution
r4986 | schlocke | 2011-04-13 18:48:47 +0200 (Wed, 13 Apr 2011) | 2 lines
cccam: bad sids from remote peer are no longer removed
r4985 | schlocke | 2011-04-13 18:47:42 +0200 (Wed, 13 Apr 2011) | 2 lines
loadbalancer: speed up access by moving mru stats to top of list
---------- Post added at 21:24 ---------- Previous post was at 19:31 ----------
oscam 1.00 -svn4987-light-full-Distribution
r4987 | alno | 2011-04-13 19:46:10 +0200 (Wed, 13 Apr 2011) | 1 line
WebIf: dropdown for AC penalty. @Schlocke: please check the descriptions of values whether it matches with its functionality
Oscam-1.00-svn4990
Oscam-1.00-svn4990
r4990 | _network | 2011-04-13 22:39:08 +0200 (Wed, 13 Apr 2011) | 2 lines
fix bug in srvid parsing
r4989 | _network | 2011-04-13 22:35:38 +0200 (Wed, 13 Apr 2011) | 3 lines
limit blocknano/savenano from 0x80 to 0x8f;
camd33: remove a global variable
r4988 | schlocke | 2011-04-13 22:12:17 +0200 (Wed, 13 Apr 2011) | 2 lines
cccam: prepared entitlements for page switch/alno
oscam 1.00 -svn4992-light-full-Distribution
r4992 | alno | 2011-04-13 22:58:23 +0200 (Wed, 13 Apr 2011) | 1 line
WebIf: first try: cccam entitlements blockwise output (untested)
r4991 | schlocke | 2011-04-13 22:48:32 +0200 (Wed, 13 Apr 2011) | 3 lines
cccam: another fix for minimizecards=2 with resharemode=3
waitforcards: added extra delay for reader inititialization problems
