51
20
Dislikes:
oscam 1.00 -svn4137-light-full-Distribution
r4137 | _network | 2010-12-17 17:58:19 +0100 (Fri, 17 Dec 2010) | 2 lines
WebIf: add POST support
r4136 | dingo35 | 2010-12-17 16:40:38 +0100 (Fri, 17 Dec 2010) | 1 line
COOLSTREAM DVBAPI thanks to all that helped achieving this
r4135 | dingo35 | 2010-12-17 13:50:14 +0100 (Fri, 17 Dec 2010) | 1 line
icc_async.c Reimplementing 3794 since _network had thought this better through than I
---------- Post added at 19:16 ---------- Previous post was at 18:31 ----------
oscam 1.00 -svn4138-light-full-Distribution
r4138 | _network | 2010-12-17 18:55:12 +0100 (Fri, 17 Dec 2010) | 2 lines
stapi: add support for stapi cardreader (included in liboscam_stapi v0.07), thx to ilchegu
Oscam-1.00-svn4139
Oscam-1.00-svn4139
Changeset #4139
Message: small fix for stapi cardreader
---------- Post added at 22:49 ---------- Previous post was at 21:31 ----------
Oscam-1.00-svn4140
Changeset #4140
Message: fix oscam-config.h
oscam 1.00 -svn4143-light-full-Distribution
r4143 | dingo35 | 2010-12-18 08:28:04 +0100 (Sat, 18 Dec 2010) | 1 line
module-coolapi.c : fix compiling problem
r4142 | dingo35 | 2010-12-18 08:13:06 +0100 (Sat, 18 Dec 2010) | 1 line
oscam.c : update help text
r4141 | dingo35 | 2010-12-18 08:10:55 +0100 (Sat, 18 Dec 2010) | 1 line
all: simplify debug system, add D_DVBAPI = -d128, eliminate cs_ptyp which complicates stuff unnecc
r4140 | _network | 2010-12-17 20:23:40 +0100 (Fri, 17 Dec 2010) | 2 lines
fix oscam-config.h
oscam 1.00 -svn4153-light-full-Distribution
r4153 | landlord | 2010-12-18 14:04:54 +0100 (Sat, 18 Dec 2010) | 1 line
Added documentation for SC8in1 reader.
r4152 | landlord | 2010-12-18 13:39:01 +0100 (Sat, 18 Dec 2010) | 1 line
DVBAPI naming in WebIf.
Oscam-svn4158-light-Distribution
r4158 | schlocke | 2010-12-19 01:21:24 +0100 (Sun, 19 Dec 2010) | 2 lines
webif-restart/defines for non-webif
r4157 | schlocke | 2010-12-19 01:15:16 +0100 (Sun, 19 Dec 2010) | 2 line
reverted config change
r4156 | schlocke | 2010-12-19 01:08:48 +0100 (Sun, 19 Dec 2010) | 2 lines
oscam restart by webif
r4155 | alno | 2010-12-19 00:39:59 +0100 (Sun, 19 Dec 2010) | 1 line
WebIf: implement restart button
oscam 1.00 -svn4159-light-full-Distribution
r4159 | alno | 2010-12-19 11:52:31 +0100 (Sun, 19 Dec 2010) | 1 line
XMLAPI: implement errormessage, preparing cccam cardlist
---------- Post added at 13:31 ---------- Previous post was at 12:13 ----------
oscam 1.00 -svn4160-light-full-Distribution
r4160 | _network | 2010-12-19 12:24:45 +0100 (Sun, 19 Dec 2010) | 2 lines
WebIf: improve POST support / fix oscam.js
Oscam-1.00-svn4162
Oscam-1.00-svn4162
r4162 | alno | 2010-12-19 20:12:14 +0100 (Sun, 19 Dec 2010) | 1 line
Remove legacy debuglevel switch code which was required in forked oscam
r4161 | alno | 2010-12-19 19:54:30 +0100 (Sun, 19 Dec 2010) | 1 line
Monitor: Fix switch debuglevel
oscam 1.00 -svn4163-light-full-Distribution
r4163 | alno | 2010-12-19 20:44:45 +0100 (Sun, 19 Dec 2010) | 1 line
Add logmessage if debuglevel is switched from monitor or webif
Oscam-1.00-svn4164
Oscam-1.00-svn4164
r4164 | schlocke | 2010-12-19 23:20:22 +0100 (Sun, 19 Dec 2010) | 2 lines
exiting oscam fix for closing oscam by cs_exit()
oscam 1.00 -svn4165-light-full-Distribution
r4165 | schlocke | 2010-12-20 09:00:20 +0100 (Mon, 20 Dec 2010) | 2 lines
webif restart: command line parameter -r added
oscam 1.00 -svn4166-light-full-Distribution
r4166 | dingo35 | 2010-12-20 10:29:23 +0100 (Mon, 20 Dec 2010) | 1 line
move pcsc_close to icc_async, where ifd specific code belongs
oscam 1.00 -svn4176-light-full-Distribution
r4176 | cogsi | 2010-12-20 14:18:29 +0100 (Mon, 20 Dec 2010) | 1 line
minilzo compression algorithm
r4175 | dingo35 | 2010-12-20 14:11:11 +0100 (Mon, 20 Dec 2010) | 1 line
icc_async.c : Fix pcsc compiling error
r4174 | dingo35 | 2010-12-20 14:07:52 +0100 (Mon, 20 Dec 2010) | 1 line
oscam.c : shorten waiting time to 3500ms
r4173 | dingo35 | 2010-12-20 13:43:27 +0100 (Mon, 20 Dec 2010) | 1 line
oscam.c : make waitforcards work for sc8in1 reader
---------- Post added at 15:01 ---------- Previous post was at 14:56 ----------
oscam 1.00 -svn4177-light-full-Distribution
r4177 | dingo35 | 2010-12-20 14:42:03 +0100 (Mon, 20 Dec 2010) | 1 line
oscam-reader.c : reduce reader activity by checking for card in/out only every 1 second
---------- Post added at 15:42 ---------- Previous post was at 15:01 ----------
oscam 1.00 -svn4179-light-full-Distribution
r4179 | dingo35 | 2010-12-20 15:04:37 +0100 (Mon, 20 Dec 2010) | 1 line
reader-common.c : Small simplification of activation routine
r4178 | dingo35 | 2010-12-20 14:58:44 +0100 (Mon, 20 Dec 2010) | 1 line
ifd_sc8in1.c : disable MCR frequency setting since it doesnt work properly
---------- Post added at 15:49 ---------- Previous post was at 15:42 ----------
oscam 1.00 -svn4180-light-full-Distribution
r4180 | _network | 2010-12-20 15:10:25 +0100 (Mon, 20 Dec 2010) | 2 lines
stapi: allow compiling with SCI_DEV for non stapi internal reader
Oscam-1.00-svn4181
Oscam-1.00-svn4181
r4181 | dingo35 | 2010-12-20 16:56:06 +0100 (Mon, 20 Dec 2010) | 1 line
oscam.c : Fix newcamd + cccam init for NLSU2 + sc8in1
---------- Post added at 20:00 ---------- Previous post was at 18:23 ----------
Oscam-1.00-svn4182
r4182 | dingo35 | 2010-12-20 18:24:28 +0100 (Mon, 20 Dec 2010) | 1 line
icc_asyn.c : SC8in1: Stop switching slots for every GetStatus update
Oscam-svn4183-light-Distribution
r4183 | schlocke | 2010-12-20 23:50:39 +0100 (Mon, 20 Dec 2010) | 2 lines
loadbalancer: autoblocking nondecodeable channels for less ecms requests
Oscam-svn4184-light-Distribution
r4184 | schlocke | 2010-12-21 08:21:26 +0100 (Tue, 21 Dec 2010) | 2 lines
cccam: fixed user-len=20chars problem
Oscam-svn4185-light-Distribution
r4185 | landlord | 2010-12-21 15:27:51 +0100 (Tue, 21 Dec 2010) | 1 line
Documentation for new start parameter 'restart level'.
Reason: completare
