51
20
Dislikes:
oscam 1.00 -svn3818-full-Distribution
r3818 | alno | 2010-11-04 02:45:04 -0700 (Thu, 04 Nov 2010) | 1 line
WebIf: Statusview - merged Login Date and Login Time to one column
r3817 | alno | 2010-11-04 01:39:25 -0700 (Thu, 04 Nov 2010) | 1 line
WebIf: some changes related to device_out_endpoint
Oscam-1.00-svn3821
Oscam-1.00-svn3821
Changeset #3819
Message: add reader label to 'card detected' loginfo
Changeset #3820
Message: csctapi/ifd_smartreader.c : fix small issue with usb endpoints
reader-viaccess.c : remove a cs_dump that was just for debugging.
Changeset #3821
Message: fix some compiler warning on some version of gcc
Oscam-1.00-svn3823
Oscam-1.00-svn3823
Changeset #3822
Message: csctapi/ifd_smartreader.c : fix reader out endpoint.
Changeset #3823
Message: reader-viaccess.c : fix a log message.
oscam 1.00 -svn3824-full-Distribution
r3824 | rorothetroll | 2010-11-04 11:28:58 -0700 (Thu, 04 Nov 2010) | 4 lines
reader-viaccess.c : moved the parental unlock to its own function
csctapi/ifd_smartreader.c : fix my crap.
r3823 | rorothetroll | 2010-11-04 09:25:43 -0700 (Thu, 04 Nov 2010) | 3 lines
Oscam-1.00-svn3825
Oscam-1.00-svn3825
Changeset #3825
Message: fix start of dvbapi emm filter in case of not found, second try
Oscam-1.00-svn3829
Oscam-1.00-svn3829
Changeset #3826
Message: reader-nagra.c : fix tier display for non tiger card. thank you webjoker
Changeset #3827
Message: reader-viaccess.c : change a log message for pin code
oscam.c : fix a compiler warning (dependent on gcc version).
reader-seca.c : inplement the same pin code processing as in reader-viaccess.c
Changeset #3828
Message: reader-viaccess.c : fix parental unlock success/failure message (they were inverted)
reader-seca.c : fix parental unlock success/failure message (they were inverted)
Changeset #3829
Message: fix some casting after talking to _network. minor fixes in other sources.
oscam 1.00 -svn3830-full-Distribution
r3830 | alno | 2010-11-04 17:11:44 -0700 (Thu, 04 Nov 2010) | 1 line
LB: we not longer need this because it's already done in chk_reader() config.c
r3829 | rorothetroll | 2010-11-04 15:52:44 -0700 (Thu, 04 Nov 2010) | 1 line
oscam 1.00 -svn3831-full-Distribution
r3831 | landlord | 2010-11-05 00:49:34 -0700 (Fri, 05 Nov 2010) | 1 line
Update of default value for 'device_out_endpoint' parameter in documentation.
oscam 1.00 -svn3832-full-Distribution
r3832 | alno | 2010-11-05 01:33:11 -0700 (Fri, 05 Nov 2010) | 1 line
Fix some compiler warnings
Oscam-1.00-svn3833
Oscam-1.00-svn3833
Changeset #3833
Message: WebIf: show newcamd clienttype additional to protocol iv avail
oscam 1.00 -svn3834-full-Distribution
r3834 | _network | 2010-11-05 12:59:41 -0700 (Fri, 05 Nov 2010) | 2 lines
dvbapi: fix pmt parsing issues
r3833 | alno | 2010-11-05 04:55:35 -0700 (Fri, 05 Nov 2010) | 1 line
Oscam-1.00-svn3836
Oscam-1.00-svn3836
Changeset #3835
Message: cccam: card exchanging optimized
Changeset #3836
Message: WebIf: additional cccam client version info in status
oscam 1.00 -svn3837-full-Distribution
r3837 | schlocke | 2010-11-05 15:37:02 -0700 (Fri, 05 Nov 2010) | 2 lines
cccam: Fixed reported/updated cards
r3836 | alno | 2010-11-05 15:17:23 -0700 (Fri, 05 Nov 2010) | 1 line
Oscam-1.00-svn3840
Oscam-1.00-svn3840
Changeset #3838
Message: cccam: for webif: version/build/extinfos added
Changeset #3839
Message: WebIf: add special cccam info for cccam ext
Changeset #3840
Message: fix last commit
Reason: Ah post dublu sory
