Thanks Thanks:  51
Likes Likes:  20
Page 73 of 81 FirstFirst ... 2363697071727374757677 ... LastLast
Results 1,081 to 1,095 of 1201
Thread: OSCAM file
  1. #1081
    24 Mar 2009
    24 Mar 2009
    mips-tuxbox-oe2.0 oscam-svn11715-mipsoe20-webif-dvbapi-emu798-icam_dvbapi_v8_patch oscam-svn11715
    V8 ohne Radegast für MIPS receiver wie z.b VU+ Solo SEv2 gebaut mit Toolchain-MIPS-Tuxbox-OE2.0_s_u_p
    Die Datei support/configs/compiler_option öffnen und dort -O1 durch -O3 ersetzen.
    Dann die s3 im Hauptverzeichnis öffnen und dort die Zeile
    cc_opts="-ggdb -pipe -ffunction-sections -fdata-sections -o nodeadcode"
    durch diese ersetzen
    cc_opts="-ggdb -pipe -ffunction-sections -fdata-sections -funroll-loops -fomit-frame-pointer -fno-tree-vectorize"
    Bitte Config beachten so minimal wie möglich gebaut und ohne ssl
    | OSCam ver: 1.20_svn rev: 11715-798 target: mipsel-unknown-linux-gnu
    | Tools:
    | CROSS = /home/ubuntu/Downloads/s3_releases/support/toolchains/mipsoe20/bin/mipsel-unknown-linux-gnu-
    | CC = /home/ubuntu/Downloads/s3_releases/support/toolchains/mipsoe20/bin/mipsel-unknown-linux-gnu-gcc
    | Settings:
    | CONF_DIR = /var/tuxbox/config
    | CC_OPTS = -O3 -ggdb -pipe -ffunction-sections -fdata-sections -funroll-loops -fomit-frame-pointer -fno-tree-vectorize
    | CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition
    | CFLAGS = -fexpensive-optimizations -DWITH_LIBCRYPTO=1 -DWITH_UTF8=1 -DWITH_UTF8
    | LDFLAGS = -Wl,--gc-sections -DWITH_LIBCRYPTO=1 -DWITH_UTF8=1 -DWITH_UTF8
    | LIBS = -lcrypto -lm -lpthread -ldl -lrt
    | UseFlags = USE_LIBCRYPTO=1 USE_UTF8=1
    | Config:
    | Addons : WEBIF WEBIF_LIVELOG WEBIF_JQUERY HAVE_DVBAPI READ_SDT_CHARSETS IRDETO_GUESSING CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CLOCKFIX WITH_EMU WITH_SOFTCAM
    | Protocols: CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE
    | Readers : NAGRA NAGRA_MERLIN IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD DRE TONGFANG BULCRYPT GRIFFIN DGCRYPT
    | CardRdrs : INTERNAL
    | Compiler : mipsel-unknown-linux-gnu-gcc (crosstool-NG 1.15.2) 4.6.3
    | Config : build/mipsel-unknown-linux-gnu/config.mak
    | Binary : /home/ubuntu/Downloads/s3_releases/support/binaries/oscam-svn11715-mipsoe20-webif-dvbapi-emu798
    Version: oscam-1.20_svn-r11715-798-ICAM-v8
    Compiler: mipsel-unknown-linux-gnu
    Box type: vusolose (generic)
    Web interface support: yes
    LiveLog support: yes
    jQuery support intern: yes
    Touch interface support: no
    SSL support: no
    DVB API support: yes
    DVB API with AZBOX support: no
    DVB API with MCA support: no
    DVB API with COOLAPI support: no
    DVB API with COOLAPI2 support: no
    DVB API with STAPI support: no
    DVB API with STAPI5 support: no
    DVB API with NEUTRINO support: no
    DVB API read-sdt charsets: yes
    DVB API with ICAM streamrelay support: yes
    Irdeto guessing: yes
    Anti-cascading support: yes
    Debug mode: yes
    Monitor: yes
    Loadbalancing support: yes
    Cache exchange support: no
    Cache exchange AIO support: no
    CW Cycle Check support: no
    LCD support: no
    LED support: no
    Clockfix with realtime clock: yes
    IPv6 support: no
    Emulator support: yes
    Built-in SoftCam.Key: yes
    camd 3.3x: no
    camd 3.5 UDP: yes
    camd 3.5 TCP: yes
    newcamd: yes
    CCcam: yes
    CCcam share: yes
    gbox: no
    radegast: no
    scam: no
    serial: no
    constant CW: no
    Pandora: no
    ghttp: no
    Reader support: yes
    Nagra: yes
    Nagra Merlin: yes
    Irdeto: yes
    Conax: yes
    Cryptoworks: yes
    Seca: yes
    Viaccess: yes
    NDS Videoguard: yes
    DRE Crypt: yes
    TONGFANG: yes
    Bulcrypt: yes
    Griffin: yes
    DGCrypt: yes
    cardreader_phoenix: no
    cardreader_drecas: no
    cardreader_internal_azbox: no
    cardreader_internal_coolapi: no
    cardreader_internal_coolapi2: no
    cardreader_internal_sci: yes
    cardreader_sc8in1: no
    cardreader_mp35: no
    cardreader_smargo: no
    cardreader_pcsc: no
    cardreader_smartreader: no
    cardreader_db2com: no
    cardreader_stapi: no
    cardreader_stapi5: no
    cardreader_stinger: no
    https://www.mediafire.com/file/jansp...patch.rar/file
    ---------- Post added at 16:53 ---------- Previous post was at 16:11 ----------
    ICAM Patch oscam-emu oscam-1.20_svn11715-798-mipsel-linux-gnu-ssl-v8-opt
    Ich hab mal eine v8 mit weiteren mipsel-Optimierungen gebaut, die laut Benchmark auf meiner vu+ zero nochmal deutlich mehr Datenrate bringt.
    Die Frage ist jetzt allerdings, ob sich das ganze auch im Normalbetrieb bemerkbar macht.
    Wer es auf einer (schwächeren) mipsel-Box testen möchte, habs angehängt
    https://www.mediafire.com/file/71fmy...sl-v8-opt/file
    ---------- Post added at 18:40 ---------- Previous post was at 16:53 ----------
    oscam-svn11715-dream_one_icamV8-webif-dvbapi-ssl-emu798-upx
    ich bin begeistert mit dem V8 läuft es auf der Dreamone ohne Probleme.
    Die geschilderten Probleme mit der 920 habe ich mit der One nicht.
    Binary gebaut mit s3 config Pfad "etc/tuxbox/config/oscam"
    https://www.mediafire.com/file/az8w4...mu798-upx/file
  3. #1083
    24 Mar 2009
    enigma2-softcams-oscam-all-images_11.715-emu-r798-ICAM-v8-arm+mips_all
    - Version v8: Siehe hier: ICAM Patch oscam-emu
    Der ACHTUNG Hinweis bei Version v5 gilt auch für die v8
    ipk
    https://www.mediafire.com/file/ygbod...l.ipk.zip/file
    deb
    https://www.mediafire.com/file/obvwy...l.deb.zip/file
  4. #1084
  5. #1085
    24 Mar 2009
    Oscam 11715 EMU with icam v8 opt
    This version is for the old mipsel boxes, with a change in compiler optimazer makes cpu runs in lower % in sky de stream realy
    https://www.mediafire.com/file/jj5lw...8_opt.zip/file
  6. #1086
    24 Mar 2009
    OSCam ARM inkl. Cak7 iCam V8.1 komplett
    SSL support: no
    Debug mode: yes
    Monitor: yes
    Cache exchange support: yes
    Cache exchange AIO support: yes
    CW Cycle Check support: yes
    LCD support: no
    LED support: no
    IPv6 support: no
    camd 3.3x: no
    camd 3.5 UDP: yes
    camd 3.5 TCP: yes
    newcamd: yes
    CCcam: yes
    CCcam share: yes
    gbox: yes
    radegast: yes
    scam: yes
    serial: yes
    constant CW: yes
    Pandora: yes
    ghttp: yes
    Reader support: yes
    Nagra: yes
    Nagra Merlin: yes
    Irdeto: yes
    Conax: yes
    Cryptoworks: yes
    Seca: yes
    Viaccess: yes
    NDS Videoguard: yes
    DRE Crypt: yes
    TONGFANG: yes
    Bulcrypt: yes
    Griffin: yes
    DGCrypt: yes
    cardreader_phoenix: yes
    cardreader_sc8in1: yes
    cardreader_mp35: yes
    cardreader_smargo: yes
    cardreader_pcsc: no
    cardreader_smartreader: yes
    cardreader_stinger: yes
    https://www.mediafire.com/file/v4r6a...mu798.rar/file
    OSCam mipsoe20 inkl. Cak7 iCam V8.1 komplett
    SSL support: no
    Debug mode: yes
    Monitor: yes
    LCD support: no
    LED support: no
    IPv6 support: no
    camd 3.3x: no
    camd 3.5 UDP: yes
    camd 3.5 TCP: yes
    newcamd: yes
    CCcam: yes
    CCcam share: yes
    gbox: yes
    radegast: yes
    scam: yes
    serial: yes
    constant CW: yes
    Pandora: yes
    ghttp: yes
    Reader support: yes
    Nagra: yes
    Nagra Merlin: yes
    Irdeto: yes
    Conax: yes
    Cryptoworks: yes
    Seca: yes
    Viaccess: yes
    NDS Videoguard: yes
    DRE Crypt: yes
    TONGFANG: yes
    Bulcrypt: yes
    Griffin: yes
    DGCrypt: yes
    cardreader_pcsc: no
    https://www.mediafire.com/file/qv5oc...mu798.rar/file
  7. #1087
    24 Mar 2009
    OSCam mipsoe20 inkl. Cak7 iCam V9 komplett 11715
    SSL support: no
    Debug mode: yes
    Monitor: yes
    LCD support: no
    LED support: no
    IPv6 support: no
    camd 3.3x: no
    camd 3.5 UDP: yes
    camd 3.5 TCP: yes
    newcamd: yes
    CCcam: yes
    CCcam share: yes
    gbox: yes
    radegast: yes
    scam: yes
    serial: yes
    constant CW: yes
    Pandora: yes
    ghttp: yes
    Reader support: yes
    Nagra: yes
    Nagra Merlin: yes
    Irdeto: yes
    Conax: yes
    Cryptoworks: yes
    Seca: yes
    Viaccess: yes
    NDS Videoguard: yes
    DRE Crypt: yes
    TONGFANG: yes
    Bulcrypt: yes
    Griffin: yes
    DGCrypt: yes
    cardreader_pcsc: no
    https://www.mediafire.com/file/04hd2...98(1).rar/file
    OSCam ARM inkl. Cak7 iCam V9 komplett 11715
    SSL support: no
    Debug mode: yes
    Monitor: yes
    LCD support: no
    LED support: no
    IPv6 support: no
    camd 3.3x: no
    camd 3.5 UDP: yes
    camd 3.5 TCP: yes
    newcamd: yes
    CCcam: yes
    CCcam share: yes
    gbox: yes
    radegast: yes
    scam: yes
    serial: yes
    constant CW: yes
    Pandora: yes
    ghttp: yes
    Reader support: yes
    Nagra: yes
    Nagra Merlin: yes
    Irdeto: yes
    Conax: yes
    Cryptoworks: yes
    Seca: yes
    Viaccess: yes
    NDS Videoguard: yes
    DRE Crypt: yes
    TONGFANG: yes
    Bulcrypt: yes
    Griffin: yes
    DGCrypt: yes
    cardreader_pcsc: no
    https://www.mediafire.com/file/8dxhg...98(1).rar/file
  8. #1088
    24 Mar 2009
    - OSCam 11715 ICam V9
    Add Patch V9 for iCam's
    - Adjustment for CMake
    - Compiler parameter -fno-schedule-insns added. (Thanks @@Hacker1 )
    - Removed compiler parameter -fno-tree-vectorize. The binary runs about 10% faster with neon (thanks @@eldi0s )
    - Small change in ffdesca, which is slightly faster.
    enigma2-plugin-softcams-oscam_11715-emu-r798_all.ipk
    https://www.mediafire.com/file/yduz3...8_all.ipk/file
    enigma2-plugin-softcams-oscam_11715-emu-r798_all.deb
    https://www.mediafire.com/file/ikrnk...8_all.deb/file
    enigma2-plugin-softcams-gosatplus-oscam_11715-emu-r798_all.ipk
    https://www.mediafire.com/file/fvwih...8_all.ipk/file
    enigma2-plugin-softcams-powercam-oscam_11715-emu-r798_all.ipk
    https://www.mediafire.com/file/j9oev...8_all.ipk/file
    enigma2-plugin-softcams-supcam-oscam_11715-emu-r798_all.ipk
    https://www.mediafire.com/file/ty9s4...8_all.ipk/file
    enigma2-plugin-softcams-revcam-oscam_11715-emu-r798_all.ipk
    https://www.mediafire.com/file/34ycj...8_all.ipk/file
    oscam-svn11715-mips-emu-r798
    https://www.mediafire.com/file/1yuc5...-r798.zip/file
    oscam-svn11715-arm-emu-r798
    https://www.mediafire.com/file/eclgc...-r798.zip/file
    oscam-svn11715-aarch64-emu-r798
    https://www.mediafire.com/file/z1qtj...-r798.zip/file
    ---------- Post added at 01:53 ---------- Previous post was at 01:47 ----------
    oscam_config_simple_by_atari_V6.5_Icam
    https://www.mediafire.com/file/3bjok..._Icam.zip/file
  9. #1089
    24 Mar 2009
  10. #1090
    24 Mar 2009
    OSCam V117.16
    -iCam V9
    enigma2-plugin-softcams-oscam_11716-emu-r798_all.ipk
    https://www.mediafire.com/file/jx1ve...8_all.ipk/file
    enigma2-plugin-softcams-oscam_11716-emu-r798_all.deb
    https://www.mediafire.com/file/abmh6...8_all.deb/file
    enigma2-plugin-softcams-supcam-oscam_11716-emu-r798_all.ipk
    https://www.mediafire.com/file/fg1ry...8_all.ipk/file
    enigma2-plugin-softcams-revcam-oscam_11716-emu-r798_all.ipk
    https://www.mediafire.com/file/5jafx...8_all.ipk/file
    enigma2-plugin-softcams-powercam-oscam_11716-emu-r798_all.ipk
    https://www.mediafire.com/file/ef0os...8_all.ipk/file
    enigma2-plugin-softcams-gosatplus-oscam_11716-emu-r798_all.ipk
    https://www.mediafire.com/file/ah807...8_all.ipk/file
    oscam-svn11716-AmikoA3-emu-r798
    https://www.mediafire.com/file/n2s0z...-r798.zip/file
    oscam-svn11716-AmikoA4-emu-r798
    https://www.mediafire.com/file/m6j1g...-r798.zip/file
    oscam-svn11716-AmikoA5-emu-r798
    https://www.mediafire.com/file/be9ub...-r798.zip/file
    oscam-svn11716-android24-stapi-emu-r798
    https://www.mediafire.com/file/puk28...-r798.zip/file
    oscam-svn11716-android19-stapi-emu-r798
    https://www.mediafire.com/file/6qeq0...-r798.zip/file
    oscam-svn11716-WetekPlay2-emu-r798
    https://www.mediafire.com/file/d5hy6...-r798.zip/file
    oscam-svn11716-sh4-emu-r798
    https://www.mediafire.com/file/o6s07...-r798.zip/file
    oscam-svn11716-stapi-emu-r798
    https://www.mediafire.com/file/g1cdl...-r798.zip/file
    oscam-svn11716-aarch64-emu-r798
    https://www.mediafire.com/file/aooco...-r798.zip/file
    oscam-svn11716-GxApi-emu-r798
    https://www.mediafire.com/file/9svyr...-r798.zip/file
    oscam-svn11716-arm-emu-r798
    https://www.mediafire.com/file/z7vhr...-r798.zip/file
    oscam-svn11716-mips-emu-r798
    https://www.mediafire.com/file/cu3q6...-r798.zip/file
    oscam-svn11716-x86_64-pc-linux-emu-r798
    https://www.mediafire.com/file/o4i7l...-r798.zip/file
    oscam-1.20_svn11716-798-x86_64-pc-cygwin
    https://www.mediafire.com/file/ufpwz...ygwin.zip/file
  11. #1091
    24 Mar 2009
    XcamClient4_HDBOX-Prime-4K_(Sisyphe)_11716
    https://www.mediafire.com/file/svopx...11716.zip/file
    XcamClient4-11716_(Sisyphe)_V2022.12.16
    https://www.mediafire.com/file/2rcmm...12.16.zip/file
    Oscam-Emu-11716-798_(Sisyphe)_v2022.12.16
    https://www.mediafire.com/file/khfey...12.16.zip/file
  12. #1092
    24 Mar 2009
    Oscam-Patched-Icone-3360-798-(Sisyphe)-2022.12.17
    https://www.mediafire.com/file/ktokw...12.17.zip/file
    ---------- Post added at 09:41 ---------- Previous post was at 09:24 ----------
    OSCam-1.20_Leyla38-Edition-2023-r11716-798-ICAM-v9.1
    aarch64-dreambox_one-linux-gnu-ssl-libusb
    https://www.mediafire.com/file/d8l8z...8-upx.zip/file
    ipv6 --> DreamONE/TWO
    https://www.mediafire.com/file/zsglb...6-upx.zip/file
  13. #1093
    24 Mar 2009
    oscam-icam-patch-v9-svn11717-emu
    Compiled by Levi45
    oscam-svn11717-arm_dream-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-dream_arm-webif-dvbapi-ssl-emu798 = PY3 (9) Openpli based images
    oscam-svn11717-dreambox_fpu-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-dream_one-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-hd51-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-Linux-x86_64-webif-dvbapi-ssl-3.0.2-libusb-emu798
    oscam-svn11717-mipsoe20-webif-dvbapi-ssl-emu798 = PY3 (9) Openpli based images
    oscam-svn11717-openpli40-webif-dvbapi-ssl-libusb-emu798 = PY3 (10)
    oscam-svn11717-osmio4k-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-rasb_hard-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-samsungtv-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-sh4-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-sh_4-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-solo4k-webif-dvbapi-ssl-libusb-emu798
    oscam-svn11717-vuplus4k_arm-webif-dvbapi-ssl-libusb-emu798 = PY3 (10)
    https://www.mediafire.com/file/4bqxc...7-emu.zip/file
  14. #1094
    24 Mar 2009
  15. #1095
    24 Mar 2009
    oscam_config_simple_by_atari_V6.6_Icam
    https://www.mediafire.com/file/22b6g..._Icam.zip/file
