Thanks Thanks:  51
Likes Likes:  20
Page 67 of 81 FirstFirst ... 175763646566676869707177 ... LastLast
Results 991 to 1,005 of 1201
Thread: OSCAM file
  1. #991
    14 Feb 2007
    Oscam_svn5898
    r5897 | zetack | 2011-08-20 00:23:22 +0200 (Sa, 20. Aug 2011) | 2 Zeilen
    rework ecm timeout detection
  2. #992
    Standard RSP member djczefre's Avatar
    08 Oct 2010
    Default Se poate un upload!
    Se poate cere un upload OSCAM 1.20-unstable_svn build #5990 pt dream box, va rog foarte mult, multumesc.
  3. #993
    29 Post(s)
    La oscam zice asa
    OSCam 5990 - unstable
    OSCam 5983 - stable
    Vezi daca ti-e bun, e pentru dm500
    5990
    Fa-ti cont aici
  4. #994
    08 Oct 2010
    Multumesc foarte mult! Nu am gasit pe net nici unde.! Multumesc!
    Pana la urma au aparut butoanele thanks, inca nu am pipait-o! Mersii!
  5. #995
    Post oscam bin ptr koala
    cine oscam vers 1.10 ptr koala ?
    eu am pe koala Version: 1.00-unstable_svn Rev. 0
    multumesc
  6. #996
    29 Post(s)
    Am remarcat ca versiunea aceasta merge bine
    OSCAM 1.20-unstable_svn build #7617
    Desi nu e ultima, merge bine cu 4 carduri: conax, nagra, nds si via, (99.67%) e cel mai prost rezultat.
    Pana acum rar am mai intalnit versiuni sa mearga toate bine.
    Cu absolut aceleasi setari, unu sau doua carduri mai bagau not found fara nicio justificare.
    Dintre astea 4 via a mers bine mereu, cel putin la mine...
  7. #997
    29 Post(s)
    OSCAM 1.20-unstable_svn build #7638
    Optiune noua in oscam
    Last change on this file since 7638 was 7638, checked in by theparasol, 7 hours ago DVBAPI added a new feature: decodeforever
    Till now dvbapi gives up decoding after 3 retries.
    There was an option in oscam.dvbapi to enforce continue decoding by a P: xxxx:xxxxxx 1
    Now you can use decodeforever to try all caids again forever.
    So no more failed recordings or rezapping to open up a channel again!
  8. #998
    13 Feb 2007
    Earth
    OScam Update 28/10/2012 1.21 Unstable
    The OScam is Very Powerfull More Faster Then Its Previous Versions, Include Full Version.Leaked by ! jcberry team.
    Patch Included No Crashes!
    NOTE: To Make It Working. Before Downloading Patch.rar Disable Your Antivirus Or Firewall.
    BCZ It Is Included illegal Liceince May Be Your Antivirus Detect Its As A Virus.
    Download Links.....
    ---------- Post added at 10:03 ---------- Previous post was at 08:57 ----------
    sorry ....
    Do NOT download.
    This have to be fake or virus.
    Lastest oscam for the creator is at this moment:
    oscam-1.20-unstable_svn7819
    Source:
    http://www.streamboard.tv/oscam/wiki/GettingOscam
  9. #999
    moo unii dintre voi santeti grozavi,atat scormoniti rahatu prin toate partile
    ce i aia no crash,no nu stiu ce,tot felu de versiuni ca si la 3c....aveti forumu oficil ce le tot cautati pe la altii nu inteleg
    dupa atat vreme inca va incanta ca scrie:The OScam is Very Powerfull More Faster Then Its Previous Versions, Include Full Version.Leaked by ! jcberry team.
    vi le puteti compila voi cum vreti...ce o fi facut teamu asta de merge ca avionu?
    aaaa dar stai ca dau si un sfat:
    spor la teste
    TOP5: Zgemma H9,
  10. #1000
    29 Post(s)
    Changeset 8758
    Message: added nagra chid info
    this info is correct for all nagra/seca based cards when using the nagra pid
    Acum arata asa:
    1802:000000:03FB:0000 Kiss TV 0092 found 279ms 4402 19.07.13 07:04:03
    1802:000000:03FB:21A4 Kiss TV 0092 found 299ms 299ms 1 19.07.13 11:43:02
    1802:000000:03FB:21BF Kiss TV 0092 found 297ms 297ms 1 19.07.13 11:41:54
    1802:000000:03FB:2378 Kiss TV 0092 found 297ms 297ms 1 19.07.13 11:42:04
    1802:000000:03FB:23B5 Kiss TV 0092 found 296ms 296ms 1 19.07.13 11:42:34
    1802:000000:03FB:24C7 Kiss TV 0092 found 300ms 300ms 1 19.07.13 11:42:24
    1802:000000:03FB:2589 Kiss TV 0092 found 300ms 300ms 1 19.07.13 11:42:44
    1802:000000:03FB:2652 Kiss TV 0092 found 301ms 301ms 1 19.07.13 11:42:54
    1802:000000:03FB:275F Kiss TV 0092 found 307ms 307ms 1 19.07.13 11:41:44
    1802:000000:03FB:29B6 Kiss TV 0092 found 289ms 289ms 1 19.07.13 11:41:39
    1802:000000:03FB:2A3C Kiss TV 0092 found 297ms 297ms 1 19.07.13 11:43:22
    1802:000000:03FB:2C90 Kiss TV 0092 found 299ms 299ms 1 19.07.13 11:43:12
    1802:000000:03FB:2E8F Kiss TV 0092 found 298ms 298ms 1 19.07.13 11:43:32
    1802:000000:03FB:2F4D Kiss TV 0092 found 298ms 298ms 1 19.07.13 11:42:14
    Iar inainte arata asa:
    1802:000000:03FB:0000 Kiss TV 0092 found 336ms 333ms 4415 19.07.13 11:35:34
  11. #1001
    29 Post(s)
    Changeset 8761
    Message: reverting 8758 and 8760
    The two extra chid info is reverted, As it does interfeer with lb.
    For caid othet then those for nagravison s03 cards is different
    under investigation sorry could not now that
  12. #1002
    29 Post(s)
    Changeset 8783
    Author:stefansat
    Message:cosmetic adaptation off services , lb whitelist services
    La reader, acum avem:
  13. #1003
    07 Sep 2013
    https://t.me/blackhatshiller
    Daca vreti sly uk si sly it...rev 9095 are optiunea cwc swap bla bla bla...pe scurt merge bine pe sky(daca aveti card sau o linie)
  14. #1004
    18 Jul 2010
    poate sa-mi dea cineva ultima versiune stabila din oscam compilat.
    mersi
  15. #1005
    08 Feb 2014
    intra cu un proxy aici http://download.oscam.cc
