51
20
Dislikes:
Oscam-svn5471-light-Distribution
r5471 | zetack | 2011-06-23 16:38:55 +0200 (Thu, 23 Jun 2011) | 2 lines
cryptoworks: fix duplicate variable name
Oscam-svn5473-light-Distribution
r5473 | alno | 2011-06-23 20:30:03 +0200 (Thu, 23 Jun 2011) | 3 lines
XMLApi:
1) add readerstatus and caid to readertstats
2) allow calling .../oscamapi.xml?part=.....
r5472 | landlord | 2011-06-23 19:47:57 +0200 (Thu, 23 Jun 2011) | 1 line
Update for DVB API documentation.
Oscam-svn5477-light-Distribution
r5477 | alno | 2011-06-24 08:24:47 +0200 (Fri, 24 Jun 2011) | 1 line
WebIF: reader description case insensitive
r5476 | lareq78 | 2011-06-24 07:54:01 +0200 (Fri, 24 Jun 2011) | 1 line
try fix #1965 which introduced in r5475
r5475 | goodsat | 2011-06-24 00:04:25 +0200 (Fri, 24 Jun 2011) | 1 line
Fix dcw crc
Oscam-svn5483-light-Distribution
r5483 | alno | 2011-06-25 08:36:53 +0200 (Sat, 25 Jun 2011) | 1 line
Config: fix last commit (63 allowed -> 64) ;-)
r5482 | alno | 2011-06-25 08:13:22 +0200 (Sat, 25 Jun 2011) | 1 line
Config: restrict reading of oscam.services to 64 entries. Oscam cannot address more then 64 services
r5481 | Admin | 2011-06-25 07:29:16 +0200 (Sat, 25 Jun 2011) | 1 line
WebIf: Correctly handle deletion of services for readers and accounts, improve efficiency of disabling/deleting accounts
r5480 | Admin | 2011-06-25 05:27:00 +0200 (Sat, 25 Jun 2011) | 1 line
WebIf: Make refresh mechanism more subtle
r5479 | schlocke | 2011-06-24 21:43:26 +0200 (Fri, 24 Jun 2011) | 3 lines
loadbalancer: added time increasing if services/ident is set and failing
readers selected again
r5478 | schlocke | 2011-06-24 13:24:18 +0200 (Fri, 24 Jun 2011) | 3 lines
loadbalancer: fix for ticket #1964
statistics now only created if ecms got results
Oscam-svn5496-light-Distribution
r5496 | alno | 2011-06-26 14:10:21 +0200 (Sun, 26 Jun 2011) | 1 line
fix compile error
r5495 | alno | 2011-06-26 14:08:21 +0200 (Sun, 26 Jun 2011) | 1 line
WebIf: revert last change - icon not work
r5494 | Admin | 2011-06-26 13:59:51 +0200 (Sun, 26 Jun 2011) | 1 line
Reset login time of readers on reconnect. Correct some global structs to save a bit memory.
r5493 | alno | 2011-06-26 13:18:54 +0200 (Sun, 26 Jun 2011) | 1 line
Webif: add new favicon
r5492 | Admin | 2011-06-26 02:01:34 +0200 (Sun, 26 Jun 2011) | 1 line
Don't set lastemm, lastecm and login to zero on network proxy disconnect.
r5491 | zetack | 2011-06-25 23:01:24 +0200 (Sat, 25 Jun 2011) | 2 lines
fix compile error
r5490 | landlord | 2011-06-25 21:43:57 +0200 (Sat, 25 Jun 2011) | 1 line
Fix small typo in 'oscam.server'.
r5489 | zetack | 2011-06-25 20:21:56 +0200 (Sat, 25 Jun 2011) | 2 lines
conax: print out pbm in entitlements
r5488 | landlord | 2011-06-25 19:26:54 +0200 (Sat, 25 Jun 2011) | 1 line
Updated remarks for definitions in 'oscam.services'.
r5487 | lareq78 | 2011-06-25 19:19:59 +0200 (Sat, 25 Jun 2011) | 1 line
revert patch #1955 by Nimloth.
r5486 | Admin | 2011-06-25 13:44:17 +0200 (Sat, 25 Jun 2011) | 1 line
WebIf: Calculate idle time for proxies and readers in a similar way like clients (based on last ecm or login time). Keepalive and management messages are not counted for this anymore as the idle time is also used for the display of the current channel which should not be display when there was just a keepalive message.
r5485 | alno | 2011-06-25 13:11:30 +0200 (Sat, 25 Jun 2011) | 1 line
WebIf: disallow to create more then 64 Services in WebIf
r5484 | landlord | 2011-06-25 12:01:40 +0200 (Sat, 25 Jun 2011) | 1 line
Added some remarks to documentation.
Oscam-svn5498-webif-light-Distribution
r5498 | alno | 2011-06-27 08:40:50 +0200 (Mon, 27 Jun 2011) | 1 line
WebIf: Add some tooltip explanation to usertable headline
r5497 | Admin | 2011-06-26 21:22:28 +0200 (Sun, 26 Jun 2011) | 1 line
WebIf: Don't show login date and online time on readers/proxies in init/error state as values are not correct in this case.
Oscam-svn5501-full-Distribution
r5501 | Admin | 2011-06-28 18:02:07 +0000 (Di, 28. Jun 2011) | 1 Zeile
WebIf: Correct time formatting function. Update logintime on network reader disconnect and show "idle" time as red (indicating error). Try a fix for FreeBSD compilation (untested, see #1968).
r5500 | hapeba | 2011-06-28 16:29:09 +0000 (Di, 28. Jun 2011) | 1 Zeile
added stapi support to config.sh
r5499 | nightmann | 2011-06-28 17:53:08 +0200 (Tue, 28 Jun 2011) | 2 lines
added stapi support to cmake enviroment. your cmake call should be something like this: cmake -DHAVE_DVBAPI=1 -DWITH_STAPI=1 -DCMAKE_TOOLCHAIN_FILE=../toolchains/toolchain-sh4-amino.cmake ..
change config dir on amino target to more recent /var/tuxbox/config folder.
Oscam-svn5502-full-Distribution
r5502 | schlocke | 2011-06-28 23:15:12 +0200 (Tue, 28 Jun 2011) | 7 lines
reader: new option: dropbadcws. Because we got logs that some cards
answers with wrong cws if they got "special" ecms, we added this new
option to discard this cw. Real CI modules also drops this cws, so oscam
is more working like a read cw. Default=off
cccam: ecm-retry implemented if no card is found and last message was a
card change message.
Oscam-svn5505-full-Distribution
r5505 | Admin | 2011-06-29 20:27:19 +0200 (Wed, 29 Jun 2011) | 1 line
CCCam: Close connection when init seed could not be received and improve error messages for this case. Increase block timeout factor and wait a bit after calling connect() for the connection to setup.
r5504 | schlocke | 2011-06-29 18:06:31 +0200 (Wed, 29 Jun 2011) | 3 lines
loadbalancer: now reader-found by cache does not add a "rc 0 80000" stat
entry
Oscam-1.00-svn5506-full-Distribution
r5506 | Admin | 2011-06-29 21:17:31 +0000 (Mi, 29. Jun 2011) | 1 Zeile
Fix segfault introduced in r5504
Oscam-svn5507-full-Distribution
r5507 | zetack | 2011-06-30 18:46:10 +0200 (Thu, 30 Jun 2011) | 2 lines
dvbapi: add support for BISS
Oscam-svn5509-full-Distribution
r5509 | alno | 2011-07-01 21:23:47 +0200 (Fr, 01. Jul 2011) | 1 Zeile
XMLApi: avoid creating a user on empty or wrong 'user' parameter in part userconfig
r5508 | schlocke | 2011-07-01 20:48:49 +0200 (Fr, 01. Jul 2011) | 3 Zeilen
cccam: support for ecm+emm with size>256 bytes (TNT France). Please
test and report!
Oscam-svn5528-full-Distribution
r5528 | alno | 2011-07-03 19:53:35 +0000 (So, 03. Jul 2011) | 1 Zeile
Add ll_entitlements to videoguard readers !untested!
r5527 | docman | 2011-07-03 18:37:28 +0000 (So, 03. Jul 2011) | 1 Zeile
Added documentation in html format.
r5525 | alno | 2011-07-03 20:02:41 +0200 (So, 03. Jul 2011) | 1 Zeile
fix bug in last commit
r5524 | alno | 2011-07-03 19:49:23 +0200 (So, 03. Jul 2011) | 1 Zeile
insert different naming in WebIf output of entitlements
r5523 | alno | 2011-07-03 19:19:48 +0200 (So, 03. Jul 2011) | 1 Zeile
enhance last commit
r5521 | alno | 2011-07-03 14:47:40 +0200 (So, 03. Jul 2011) | 1 Zeile
Add ll_entitlements to nagra reader !untested!
r5520 | alno | 2011-07-03 14:23:57 +0200 (So, 03. Jul 2011) | 1 Zeile
Add ll_entitlements on cryptoworks !untested! i havn't such card
r5519 | alno | 2011-07-03 14:03:55 +0200 (So, 03. Jul 2011) | 1 Zeile
Activate new ll_entitlement on irdeto reader (additional to cs_ri_log()) legacy entitlement out put shouldn't be affected. In webif the new output is shown below legacy output on entitlements of irdeto readers
r5518 | alno | 2011-07-03 11:48:15 +0200 (So, 03. Jul 2011) | 1 Zeile
Add function to calc an entitlement date but not active. Just for discussion
r5517 | Admin | 2011-07-03 01:32:23 +0200 (So, 03. Jul 2011) | 1 Zeile
Fix too small date buffer on cw logging.
r5516 | alno | 2011-07-02 21:16:17 +0200 (Sa, 02. Jul 2011) | 1 Zeile
add function to clear entitlements llist
r5515 | alno | 2011-07-02 19:10:16 +0200 (Sa, 02. Jul 2011) | 1 Zeile
Add samplecode in irdeto module for using entitlement list. Maybe somebody with S02 in irdetomode can check this codepart.
r5514 | alno | 2011-07-02 17:50:30 +0200 (Sa, 02. Jul 2011) | 1 Zeile
WebIf: improvement for last commit
r5513 | alno | 2011-07-02 17:23:38 +0200 (Sa, 02. Jul 2011) | 1 Zeile
WebIf: Add some testoutput in Entitlement page for new entitlement structure. If something is in llist it will added on end of page
r5512 | alno | 2011-07-02 16:36:09 +0200 (Sa, 02. Jul 2011) | 1 Zeile
Add structure for entitlements and function add entitlements to a llist in reader - just preapare no functionality
r5511 | alno | 2011-07-02 16:02:23 +0200 (Sa, 02. Jul 2011) | 1 Zeile
Code: some more cleanup, whitespaces and readability
r5510 | alno | 2011-07-02 11:07:00 +0200 (Sa, 02. Jul 2011) | 1 Zeile
Code: some cleanup, whitespaces and radability
Oscam-svn5556-full-Distribution
r5556 | alno | 2011-07-06 22:53:09 +0200 (Mi, 06. Jul 2011) | 1 Zeile
Add entitlement structure to videoguard provided by docmarius (SB)
Oscam-svn5701-light-Distribution
r5701 | alno | 2011-07-22 19:45:00 +0200 (Fr, 22. Jul 2011) | 1 Zeile
WebIf: fix for Changeset [5699]
r5699 | alno | 2011-07-21 20:26:09 +0200 (Do, 21. Jul 2011) | 1 Zeile
WebIf: deactivate temporarily "kill client" functionality because of unexpected behavior in the moment
