Results 1 to 15 of 1213
Thread: OSCAM file
    23 Apr 2007
    P3X-888
    Default OSCAM file
    in aceast topic se vor posta doar arhive ale noilor versiuni de oscam si comentarii despre ce probleme sunt rezolvate de fiecare versiune nou aparuta orice alte comentarii sau intrebari vor fi sterse .
    va multumesc
    11 Apr 2008
    Fost mebru
    Post
    O mică completare pentru a şti de care versiune aveţi nevoie :
    - powerpc-tuxbox-smartreader = DM500, DM500+, DM600, DM7000, DM7020 compatible STBs with usb for smartreader
    - powerpc-tuxbox-without_smartreader = DM500, DM500+, DM600, DM7000, DM7020
    - mips-tuxbox = DM500HD, DM800, DM7025, DM8000
    - sh4-amino = IPBOX 9000 HD, IPBOX 910 HD, IPBOX 91 HD, Kathrein UFS 910
    - i686-pc-linux = 32 Bit Linux PC
    - x86_64-pc-linux = 64 Bit Linux PC
    - openwrt-little_endian-kernel24 = OpenWRT Router with Kernel 2.4.x
    - openwrt-little_endian-kernel26 = OpenWRT Router with Kernel 2.6.x
    - arm-coolstream = CoolstreamHD1
    - arm-nslu2-openwrt = OpenWRT Linksys NSLU2
    - arm-nslu2-unslung = Unslung Linksys NSLU2
    - dbox2-tuxbox = Dbox2
    - mips-fonera2 = La Fonera Router
    - mips-freetz = Fritzbox Router
    - tripledragon = Triple Dragon
    23 Apr 2007
    P3X-888
    r2954 | rorothetroll | 2010-08-26 14:48:14 -0700 (Thu, 26 Aug 2010) | 1 line
    fixes for the utils/CMakeLists.txt for Dockstar platform
    r2953 | rorothetroll | 2010-08-25 10:11:44 -0700 (Wed, 25 Aug 2010) | 1 line
    added Seagate FreeAgent DockStar support. thanks Robby
    oscam-svn2954-full-Distribution
    29 Mar 2009
    Austria - TM
    Default oscam-svn2955-full-Distribution
    Code:
    r2955 | polo | 2010-08-27 03:15:01 -0700 (Fri, 27 Aug 2010) | 4 lines
    - Add 'reread' command in monitor to reload entitlements
    - Improve logging message
    oscam-
    Code:
    webif is on all versions included
    dvb-api is on all dvb-api stbs included like dreambox and sh4 stbs with enigma2, also availble on azbox (openxcas)
    smartreader support is included in all versions except on 'without_smartreader' versions in filename
    azbox version can be installed by copying Camd.tgz to /tmp and installing from the plugins menu
    23 Apr 2007
    P3X-888
    Changeset #2955:
    Timestamp: 08/27/2010 12:15:01 PM (less than one hour ago)
    Author: polo
    Message: - Add 'reread' command in monitor to reload entitlements
    Changeset #2956: | schlocke | 2010-08-27 09:40:40 -0700 (Fri, 27 Aug 2010) | 2 lines
    cccam: loadbalancer: Fallback is now secondbest reader
    Changeset #2957:
    Timestamp: 08/27/2010 11:19:58 PM
    Author: alno
    Message: Commit patch from manio related Ticket #739 (separate DES Key configurable for each newcamd port) THX
    !!! No WebIf support yet !!!
    Changeset #2958:
    Timestamp: 08/28/2010 07:25:59 AM
    Author: landlord
    Message: Documentation for multiple newcamd DES keys.
    Changeset #2959:
    Timestamp: 08/28/2010 08:29:35 AM
    Author: alno
    Message: WebIf: add separate (per port) DES key config support
    oscam-svn2959-full-Distribution
    dMd
    Guest
    Oscam-svn2965-full-Distribution
    Code:
    r2965 | cogsi | 2010-08-29 00:28:52 -0700 (Sun, 29 Aug 2010) | 1 line
    nds: fixed skyit 9cd atr detection and more cosmetics
    r2964 | cogsi | 2010-08-29 00:27:02 -0700 (Sun, 29 Aug 2010) | 1 line
    nds: removed old sky uk atr and other cosmetic changes
    r2963 | cogsi | 2010-08-29 00:24:07 -0700 (Sun, 29 Aug 2010) | 1 line
    nds: added skyit 9cd atr (thanks .:foggy:.) and other cosmetic changes
    r2962 | cogsi | 2010-08-29 00:17:51 -0700 (Sun, 29 Aug 2010) | 1 line
    updated SkyIt tiers table
    oscam-svn2965-full-Distribution
    Default 2 fisiere lipsa
    In arhiva in version.txt zice:
    available versions:
    - oscam-svnX-arm-coolstream CoolstreamHD1
    - oscam-svnX-arm-nslu2-openwrt OpenWRT Linksys NSLU2
    - oscam-svnX-arm-nslu2-unslung Unslung Linksys NSLU2
    - oscam-svnX-dbox2-tuxbox Dbox2
    - oscam-svnX-i686-pc-linux 32 Bit Linux PC
    - oscam-svnX-x86_64-pc-linux 64 Bit Linux PC
    - oscam-svnX-mips-azbox AZBox HD
    - oscam-svnX-mips-fonera2 La Fonera Router
    - oscam-svnX-mips-freetz Fritzbox Router
    - oscam-svnX-mips-tuxbox DM500HD, DM800, DM7025, DM8000
    - oscam-svnX-openwrt-little_endian-kernel24 OpenWRT Router with Kernel 2.4.x
    - oscam-svnX-openwrt-little_endian-kernel26 OpenWRT Router with Kernel 2.6.x
    - oscam-svnX-powerpc-tuxbox-smartreader DM500, DM500+, DM600, DM7000, DM7020 compatible STBs with usb for smartreader
    - oscam-svnX-powerpc-tuxbox-without_smartreader DM500, DM500+, DM600, DM7000, DM7020
    - oscam-svnX-sh4-amino IPBOX 9000 HD, IPBOX 910 HD, IPBOX 91 HD, Kathrein UFS 910
    - oscam-svnX-tripledragon Triple Dragon
    dar
    nu este
    Exact de asta am nevoie. Daca stie cineva de existenta lui il rog sa-mi zica si mie.
    Multumesc
