oscam 1.00 -svn4333-light-full-Distribution
r4333 | alno | 2011-01-06 00:22:39 +0100 (Thu, 06 Jan 2011) | 1 line
WebIf: fix small issue with nano settings
r4332 | alno | 2011-01-05 23:43:29 +0100 (Wed, 05 Jan 2011) | 1 line
Config: remove multiple code
oscam 1.00 -svn4334-light-full-Distribution
r4334 | Admin | 2011-01-06 01:15:33 +0100 (Thu, 06 Jan 2011) | 1 line
Cleanup redundant key_atob functions
oscam 1.00 -svn4335-light-full-Distribution
r4335 | alno | 2011-01-06 09:44:20 +0100 (Thu, 06 Jan 2011) | 1 line
Config: more simplify config.c and reduce code
Oscam-1.00-svn4339
Oscam-1.00-svn4339
r4339 | alno | 2011-01-06 15:34:13 +0100 (Thu, 06 Jan 2011) | 1 line
WebIf: improve styles of debuglevel selector
r4338 | alno | 2011-01-06 13:25:37 +0100 (Thu, 06 Jan 2011) | 1 line
Config: fix defaults
r4337 | alno | 2011-01-06 12:35:17 +0100 (Thu, 06 Jan 2011) | 4 lines
WebIf: multiple debuglevel selection in status & files/logfile
Skin creators, please update your css skins:
A.debugls <- selected debuglevel
A.debugl <- unselected debuglevel
r4336 | alno | 2011-01-06 11:13:57 +0100 (Thu, 06 Jan 2011) | 1 line
Config: fix cccam updateinterval (THX FilipeAmadeuO for report)
oscam 1.00 -svn4340-light-full-Distribution
r4340 | Admin | 2011-01-06 18:26:32 +0100 (Thu, 06 Jan 2011) | 1 line
Fix issue mentioned in #1439
Oscam-1.00-svn4343
Oscam-1.00-svn4343
r4343 | schlocke | 2011-01-06 19:34:24 +0100 (Thu, 06 Jan 2011) | 2 lines
camd35: small change with CMD08 handling
r4342 | schlocke | 2011-01-06 19:15:32 +0100 (Thu, 06 Jan 2011) | 2 lines
camd35: handling of sleepstate changed
r4341 | alno | 2011-01-06 18:56:55 +0100 (Thu, 06 Jan 2011) | 2 lines
Config: remove unused parameters from reader config, mk_t function for services - removing redundant code
camd35 protocol: for testing: received CMD08 are added to LB stats with returncode from server. For testing use client AND Server oscam with this release. The effect should be visible in stats on clientside. Please Test and report
oscam 1.00 -svn4344-light-full-Distribution
r4344 | Admin | 2011-01-06 20:07:46 +0100 (Thu, 06 Jan 2011) | 1 line
Remove tiger_rsakey and n3_rsakey => use rsakey instead. Remove n3_boxkey => use boxkey instead. Remove unnecessary internal variable has_rsa. This should also fix #1441.
Oscam-1.00-svn4346
Oscam-1.00-svn4346
r4346 | Admin | 2011-01-06 20:46:07 +0100 (Thu, 06 Jan 2011) | 1 line
Fix if there are zeros at the end of the rsakey. Cleanup aeskey output.
r4345 | alno | 2011-01-06 20:29:16 +0100 (Thu, 06 Jan 2011) | 1 line
XMLAPI: readerstats las access -> ISO Timeformat
oscam 1.00 -svn4347-light-full-Distribution
r4347 | alno | 2011-01-06 21:52:16 +0100 (Thu, 06 Jan 2011) | 1 line
Config: increase number of Betatunnel mappings from 16 to 20
oscam 1.00 -svn4356-light-full-Distribution
r4356 | Admin | 2011-01-07 02:01:57 +0100 (Fri, 07 Jan 2011) | 1 line
Replace all occurences of localtime() with the threadsafe version localtime_r()
r4355 | Admin | 2011-01-07 01:08:35 +0100 (Fri, 07 Jan 2011) | 1 line
Webif: Fix missing highlight of debug mode after clicking the link (CSS error)
Oscam-1.00-svn4360
Oscam-1.00-svn4360
r4360 | schlocke | 2011-01-07 13:01:46 +0100 (Fri, 07 Jan 2011) | 3 lines
loadbalancer: if a reader has idents, this services also never gets
blocked
r4359 | landlord | 2011-01-07 09:45:04 +0100 (Fri, 07 Jan 2011) | 1 line
Small documentation update for 'aeskeys'.
r4358 | Admin | 2011-01-07 02:31:36 +0100 (Fri, 07 Jan 2011) | 1 line
Fix for debug level selector in logfile section.
r4357 | Admin | 2011-01-07 02:22:41 +0100 (Fri, 07 Jan 2011) | 1 line
WebIf: Remove unnecessary key parameter in cs378x section, make debuglevel selector immune to browser refreshes.
Oscam-1.00-svn4361
Oscam-1.00-svn4361
r4361 | schlocke | 2011-01-07 14:44:32 +0100 (Fri, 07 Jan 2011) | 4 lines
webif: fixed empty protocol
cccam: small available fix
cache extend thread safe
Oscam-1.00-svn4364
Oscam-1.00-svn4364
r4364 | Admin | 2011-01-07 21:44:15 +0100 (Fri, 07 Jan 2011) | 1 line
Fix for #1444, thanks to sulge!
r4363 | schlocke | 2011-01-07 21:18:05 +0100 (Fri, 07 Jan 2011) | 2 lines
webif: status fix
r4362 | schlocke | 2011-01-07 19:40:44 +0100 (Fri, 07 Jan 2011) | 2 lines
webif: fixed client counter with hide idle clients
Oscam-svn4365-light-Distribution
r4365 | landlord | 2011-01-07 23:01:16 +0100 (Fri, 07 Jan 2011) | 1 line
Added GPL licensing.
oscam 1.00 -svn4366-light-full-Distribution
r4366 | schlocke | 2011-01-07 23:20:54 +0100 (Fri, 07 Jan 2011) | 3 lines
loadbalancer: new parameter lb_retrylimit, reopen reader only if
responsetime > lb_retrylimit
