Thanks Thanks:  51
Likes Likes:  20
Page 21 of 81 FirstFirst ... 111718192021222324253171 ... LastLast
Results 301 to 315 of 1201
Thread: OSCAM file
  1. #301
    14 Feb 2007
    Onscam-svn4051-light-Distribution
    r4051 | schlocke | 2010-12-07 08:49:40 +0100 (Tue, 07 Dec 2010) | 2 lines
    cccam: blocking users when connect answer timeout occurs
    r4050 | schlocke | 2010-12-07 08:37:33 +0100 (Tue, 07 Dec 2010) | 2 lines
    cccam: added inactive login clients timeout (2s), fixed card reporting
  2. #302
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn4053
    Oscam-1.00-svn4053
    Changeset #4052
    Message: Documentation update for 'clienttimeout'.
    Changeset #4053
    Message: Documentation update for 'clienttimeout', now with txt, too.
  3. #303
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn4054
    Oscam-1.00-svn4054
    Changeset #4054
    Message: cccam: changed emm handling/provider generation
  4. #304
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn4056-light-full-Distribution
    r4056 | schlocke | 2010-12-07 23:00:05 +0100 (Tue, 07 Dec 2010) | 2 lines
    cccam: changed provider to 4 bytes
    r4055 | landlord | 2010-12-07 19:31:27 +0100 (Tue, 07 Dec 2010) | 1 line
    manpage update for parameter 'clienttimeout'.
  5. #305
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn4058-light-full-Distribution
    r4058 | schlocke | 2010-12-07 23:45:42 +0100 (Tue, 07 Dec 2010) | 2 lines
    cccam: changed keepconnected/keepalive check
    r4057 | schlocke | 2010-12-07 23:41:58 +0100 (Tue, 07 Dec 2010) | 2 lines
    loadbalancer: added support for "prefer local cards"
  6. #306
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn4059-light-full-Distribution
    r4059 | landlord | 2010-12-08 07:56:51 +0100 (Wed, 08 Dec 2010) | 1 line
    TNTSAT fix nano D2 0b AES, thanks to jerdvb.
  7. #307
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn4064
    Oscam-1.00-svn4064
    Changeset #4060
    Message: ifd_cool.c : checked threadsafe
    Changeset #4061
    Message: cccam: Adding null-provider if card has no providers
    Changeset #4062
    Message: Readd betacrypt provider id mapping
    Changeset #4063
    Message: cccam: converted n. FFFFFF provider to 00000n
    Changeset #4064
    Message: cccam: fixed compile error
  8. #308
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn4065-light-full-Distribution
    r4065 | schlocke | 2010-12-08 15:29:17 +0100 (Wed, 08 Dec 2010) | 3 lines
    cccam: updated emm code
    webif: added active/count readers/proxies/users
    r4064 | schlocke | 2010-12-08 13:41:00 +0100 (Wed, 08 Dec 2010) | 2 lines
  9. #309
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn4066
    Oscam-1.00-svn4066
    Changeset #4066
    Message: cccam: fixed dup cards check
  10. #310
    23 Apr 2007
    P3X-888
    oscam-svn4071-light-Distribution
    Changeset [4067] by schlocke
    cccam/loadbalancer: added support for forwarding preferred cards cccam: …
    Changeset [4068] by schlocke
    fixed compile error
    Changeset [4069] by schlocke
    loadbalancer: Support for preferred card
    Changeset [4070] by schlocke
    fixed compile error
    Changeset [4071] by schlocke
    cccam: minimize cards option with no preferred reader (mode 1/2)
  11. #311
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn4072
    Oscam-1.00-svn4072
    Changeset #4072
    Message: fix possible memory corruption when CS_LOGHISTORY is enabled
  12. #312
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn4073
    Oscam-1.00-svn4073
    Changeset #4073
    Message: cccam: updated emm handling
  13. #313
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn4075-light-full-Distribution
    r4075 | schlocke | 2010-12-10 09:02:07 +0100 (Fri, 10 Dec 2010) | 2 lines
    cccam: reset preferred card when card is invalid/not found/retry
    r4074 | schlocke | 2010-12-10 09:01:15 +0100 (Fri, 10 Dec 2010) | 3 lines
    webif: Totals of the server now collects persistent - also when user
    disconnects
    r4073 | schlocke | 2010-12-09 23:31:57 +0100 (Thu, 09 Dec 2010) | 2 lines
  14. #314
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn4076
    Oscam-1.00-svn4076
    Changeset #4076
  15. #315
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn4077-light-full-Distribution
    r4077 | schlocke | 2010-12-10 15:34:40 +0100 (Fri, 10 Dec 2010) | 2 lines
    r4076 | schlocke | 2010-12-10 14:03:40 +0100 (Fri, 10 Dec 2010) | 2 lines
