54
21
Dislikes:
Oscam-1.00-svn3862
Oscam-1.00-svn3862
Changeset #3861
Message: WebIf: add capability to edit/save some files in file section. This feature is HIGHLY EXPERIMENTAL. YOU CAN LOOSE DATA. Because we work with the 'get' function the file is transmitted over URL. Different Browsers are limited in URL length. So you risc writing an incomplete file. !!!! PLEASE BACKUP YOUR CONFIGFILES BEFORE USING THIS FUNCTIONALITY !!!!
Writing files over this functionality have no effect at running oscam. The config files just readed on oscam startup. So a restart is needed to see effects of changed files.
Changeset #3862
Message: dvbapi: add shared and global videoguard emm filter
Oscam-1.00-svn3863
Oscam-1.00-svn3863
Changeset #3862
Message: cccam: fixed small cccam-ext protocol issue
Oscam-1.00-svn3864
Oscam-1.00-svn3864
Changeset #3864
Message: cccam: changed kind of card updating to the clients
oscam 1.00 -svn3865-full-Distribution
r3865 | alno | 2010-11-09 13:03:37 -0800 (Tue, 09 Nov 2010) | 1 line
Config: change waitforcard default
r3864 | schlocke | 2010-11-09 12:51:16 -0800 (Tue, 09 Nov 2010) | 2 lines
Oscam-1.00-svn3867
Oscam-1.00-svn3867
Changeset #3866
Message: cccam: fixed dcw checksum
Changeset #3867
Message: cccam: fixed dcw (2)
oscam 1.00 -svn3868-full-Distribution
r3868 | schlocke | 2010-11-10 01:39:09 -0800 (Wed, 10 Nov 2010) | 2 lines
cccam: fixed client timeouts
r3867 | schlocke | 2010-11-09 13:45:26 -0800 (Tue, 09 Nov 2010) | 2 lines
Oscam-1.00-svn3869
Oscam-1.00-svn3869
Changeset #3869
Message: dvbapi: fix priority and mapping bug
Oscam-1.00-svn3871
Oscam-1.00-svn3871
Changeset #3870
Message: reader-viaccess.c : improvment on long ECM parsing and making sure we only send the right ECM to the card. NOT TESTED !!!!. I tested on a card with normal ECM and it still works. I need someone to test this on a card with long ECM in debug mode.
csctapi/ifd_pcsc.c : improve debug messages.
globals.h : added number_ecm for long ecm processing in viaccess.
Changeset #3871
Message: loadbalancer: detecting droped/offline reader to switch lb-reader
Oscam-1.00-svn3874
Oscam-1.00-svn3874
Changeset #3872
Message: loadbalancer: optimized reader offline switching
Changeset #3873
Changeset #3874
Message: dvbapi: fix seca unique emm filter
oscam 1.00 -svn3875-full-Distribution
r3875 | rorothetroll | 2010-11-10 14:29:07 -0800 (Wed, 10 Nov 2010) | 3 lines
reader-viaccess.c : move the test for long ecm number to the begining of the card init.
r3874 | _network | 2010-11-10 13:13:32 -0800 (Wed, 10 Nov 2010) | 2 lines
oscam 1.00 -svn3876-full-Distribution
r3876 | rorothetroll | 2010-11-10 15:03:07 -0800 (Wed, 10 Nov 2010) | 2 lines
reader-viaccess.c: fix potential aes key provider maping as we were using the SOID instead of ident as the parameter.
---------- Post added at 02:47 ---------- Previous post was at 01:50 ----------
oscam 1.00 -svn3877-full-Distribution
r3877 | rorothetroll | 2010-11-10 15:49:21 -0800 (Wed, 10 Nov 2010) | 3 lines
csctapi/ifd_pcsc.c: added a log message to display ATR from card.
oscam 1.00 -svn3878-full-Distribution
r3878 | schlocke | 2010-11-11 01:28:14 -0800 (Thu, 11 Nov 2010) | 2 lines
cccam: reverted service check for card exchange
Oscam-svn3879-full-Distribution
r3879 | landlord | 2010-11-11 02:33:50 -0800 (Thu, 11 Nov 2010) | 1 line
Refinement of 'aeskeys' documentation.
Oscam-1.00-svn3880
Oscam-1.00-svn3880
Changeset #3880
Message: Again, small refinement of 'aeskeys' documentation.
oscam 1.00 -svn3881-full-Distribution
r3881 | alno | 2010-11-11 06:47:24 -0800 (Thu, 11 Nov 2010) | 1 line
WebIf: remove 'cccam ext' from form parameters - not valid
r3880 | landlord | 2010-11-11 04:17:06 -0800 (Thu, 11 Nov 2010) | 1 line
