VTI "Vu+ Team Image" 2.0, OE 1.6 - Flash Version
Enigma 19/08/2010
Driver 8.19.2010
Plugins 08/19/2010
Skins 08/19/2010
Changes in the image:
Custom Boot Logo's new radio and fashion logo.
various adjustments to the image and diffs and links from / usr / keys and / var / keys in the image and other minor things.
Vu+ Changes:
- Turn off LNB power at standby
- Fix video event problem
- Fix VFD display problem
- Fix long press key problem
- Adjust remote control response time a bit more
- Fix virtual tuner problem.
- Support Fancontorl interface at standby.(duo)
- Support pcm sound(needs additional kernel modules)
in dolby digital downmix mode.
- Clean up playback driver and fix misc. bugs.
- Fix some diseqec switch problem.
- Fix front rotary switch problem.(duo)
- Separate gcc 4.4.3 version and 4.1.1 version
- Make screen blank when zapping
- Enhance tuning algorithm
- Support more mkv file formats.
- Fix occasional "no audio" problem in playback
- Fix "late audio play" problem in playback
- Support EOS detection in playback driver
- Fix mp3 playback problem
- Support FF trick mode in playback
- Adjust memory allocation(Solo, needs a kernel update)
- Support DTS Passthrough(Solo)
- Fix vtuner frontend info
- Fix tuning problem.(Solo)
VTI Changes:
- Enhanced Multiboot support (BA and other)
- Enhanced SATA-HDD recognition
- Some Enigma2 fixes
- Cronjobs full supported
- No error massages while changeing the password
- Pure audio disc playback - (USB CD Drive)
- PowerControl systemplugin support
- Kernel and system enhancements
- OE1.6 QT-Webbrowser support
- Many enhancements in network and networkbrowserplugin
- Support for Windows 7 Samba (CIFS-Server)
- Support for Vu+ Solo and Duo Imagebackup (USB/NFI-Restore) OE1.6 Fix
- New Enigma2 Crashlogremover
- Swapfile at /media/usb
- IPK-Installer search at /media/usb/* too
- Softwaremanager plugin is now build-in into the image
- Rytec EPG removed has to be installed manual
- Some WLAN fixes
- Settings in Fancontrol and Powercontrol must be identical!
- Support for FTDI chipset cardreader like smargo and easymouse2
- Greenscreen fix when no softcam is installed and any color key will be pressed
- New Skin Infobar/Renderfile
- Running Softcam shown in the Infobar
- Better support for MyTube, MetacafeDirect and other
http://www.4shared.com/file/QW5GFkRI...082010nfi.html
Thanks ..........
Dislikes:
