Results 1 to 9 of 9
Thread: SIF Team Enigma2 0.9.8
    21 Post(s)
    Default SIF Team Enigma2 0.9.8
    release 0.9.8
    - fixed Scart/NTSC, HDMI/480i60, HDMI/480p60 resolutions (let me know if they are working ok or not,
    here i can't test perfectly NTSC standard, but seems working good)
    - fixed grey screen of death
    - fixed some compatibility of HDMI video output
    - fixed the switching between certain 1080p modes unreliable
    - fixed YCbCr to full range RGB conversion
    - sometimes happened that screen can get hidden when switching between modes that do not change the resolution
    - some rescale improvements
    - fixed some downscale bugs
    - fixed some artifacts cases when stopping playback (need to test more about it)
    - first try for audio clock initial setup for HDMI compatibility (people who are using Samsung's TVs and
    have had problems with audio throught HDMI should let me know if there are improvements)
    - fixed the bug where non-linear video zoom fail all over on (now it works good let me know how do you feel it)
    - fixed a wmv bug
    - fixed an alignment problem on DVD-player
    - updated cross epg changes (now you should be able to use latest cross-epg version)
    - minor bug fixes
    O versiune plina de lucruri noi ! " fixed grey screen of death " daca asta inseamna rezolvarea eternei probleme
    a "zapezii" ... chiar o versiune de exceptie !!! revin cu detalii dupa teste ...
    Din cate stiu, s-a rezolvat la TF o problema majora de decoder H.264, prin care a scazut mult ocuparea procesorului si s-a eliminat o eroare majora.
    Deja merge sa inregistrezi 2 HD-uri si sa urmaresti al 3-lea (au 2 tunnere).
    21 Post(s)
    Chiar se intampla lucruri interesante :
    - folosesc incubus 1.17
    - SIF 0.9.8
    - panel RSP
    - raportul de ECM time da cifre exceptionale ... aproape incredibile
    sky IT hop=3 350ms , idem hop=2 150ms , HD Suisse hop=2 350ms
    - evident ..nu sintem la o ora de varf ...ora locala 16 ... si vacanta generala !
    - deocamdata nici o surpriza neplacuta ... comuta repede si exact
    - asteptam un incident de NET ... si va veni ca doar am net de la RTC ...inca
    P.S. dupa 3 ore de functionare corecta ..la o mica pauza de NET... a inceput sa ninga !
    10 Feb 2008
    "fixed grey screen of death" nu e zapada ... e un bug care apare la cateva TV-uri conectate pe HDMI
    Uacing setalait televijan uitaut sabscripsan iz iligal !!!
    VIP
    23 Sep 2008
    la mine merge de 2 zile nonstop cu ultimul oscam si pkt 9.8.
    net de la rds!...am lasat toata noaptea pe un canal Hd si nu a facut zapada!
    m-am uitat in cele 2 servere unde sunt conectat si nu mai am trafic forte,ca acum 2 luni.
    au miscat ceva baieti cu 'oscam'..
    23 Apr 2008
    Bucharest West
    am luat vers release_098_cuberevo-250hd_flash.tar.gz..
    vreau sa l pun direct in flash..
    are inclus Panel ca la PKT sau trebe sa adaug manual?
    merci.
    Vu+Zero4K, Offset Motor 1m
    01 Apr 2007
    nu , trebuie sa instalezi manual panelul_emu
    alta varianta pt flash ar fi AAF-Hot
    Pentru AAF instalezi manual emu in /var/bin ( cu 755 ) si editezi /var/etc/cardreader.emu in acord cu emu pe care il instalezi
    02 Sep 2007
    Timişoara
    La mine nu merge oscam cu imaginea asta, am incercat cu svn2914 şi cu svn2900-threaded şi nu crează nici măcar oscam.log. newcs+mgcamd merg perfect.
    Aceleaşi versiuni oscam merg perfect pe 0.9.7.
    Aveţi vreo idee care ar putea fi problema?
    02 Sep 2007
    Timişoara
    Quote Originally Posted by gogi View Post
    Ai putea spune exact ce oscam foloseşti şi pe ce box? La mine nu merge oscam cu ultimul PKT (vezi postul meu anterior).
