Page 1 of 5 12345 LastLast
Results 1 to 15 of 66
Thread: Fausto!
    Membru de onoare
    08 Apr 2007
    Default Fausto!
    Am promis zilele trecute ca voi reveni cu detalii si teste legat de acest emu/server/client/etc.Din start va spun ca poate fi folosit doar pe PC.
    Ultima versiune este 1.45 din 23/06/2010:
    FAUSTO KEYS EDITOR/EMULATOR/LOGGER/CLIENT/SERVER
    Installation: not needed to uninstall previous version, just run Fausto V1.XX setup.exe
    Fausto Emulator compatibilities:
    *XML file to be compatible with Fausto Emulator MUST include cryptoworks Cardkey (06)
    This keys used in internal by diablo cam emu
    If the CardKey (06) not include you'll can't decode cryptoworks with Fausto Emulator
    CardKey (06) added on Keys.bin has no effect under diablo cam emulator
    *Include Betacrypt Tuneled Nagra 2 Providers
    *Include ECM IV & ECM Seed keys under Irdeto2 Coding System
    CS Cards Client supported:
    CCCam (TCP)
    Newcamd (TCP)
    RadeGast (TCP)
    Camd35 (UDP cs357x)
    Camd35 (TCP cs378x)
    Camd33 (TCP)
    Gbox Listener (localhost only, default ports)
    Twin Protocol (Serial)
    Gbox (UDP)
    CS Cards server supported:
    Newcamd (TCP) & EMM Support
    RadeGast (TCP)
    Camd35 (UDP cs357x)
    Camd35 (TCP cs378x)
    Camd33 (TCP)
    Support:
    - Ethernet (linux box, diablo wifi,...)
    - SSSP/HSIC/TM Share/CSC (Serial)
    - Season Interface (Cams/box Readers)
    - Diablo Wireless (base unit)
    Main Functions:
    - Emulator
    - Logger
    - Net client
    - Card server
    - Cards support
    - DVB Plugins (without pctv card)
    IMPORTANT: For Windows Vista or Windows7 user's, change Fausto.exe properties to Compatibility Windows XP2/3 to prevent any problems Alarm
    Version 1.45 (23/06/2010)
    - Emulator
    Viaccess 2.6/3.X: keys are now defined on keys file (XML or BIN)
    BIS TV & CSAT tested & worked (load keys.bin file joined under MONITOR)
    *Monitor:
    Added option ECM/EMM Offline decoding
    Report to File Fausto_ECMOfflineDecoding.txt for more details
    *Tracker:
    -Added Extented Tracker Log window -> double clic on Tracker log Window
    To back to normal window log, double clic again on original log window
    *Card Client:
    Newcamd: send keep alive command to server
    Newcamd: Added datas SIDOVERRIDE report to FaustoClients_Example.cfg for syntax & definition
    CCCam: code improved (io handler modified too)
    Gbox: connection improved (tested with Mbox worked)
    Gbox: Connection Line status modified: if no shares from server at connection, status = FAILED
    Gbox: Added CardId on ECM Log
    *Serial:
    Added HomeShare protocol
    Code improved & usb to com cable worked too
    *Cards Support:
    Viaccess: TNTSat Card Fix
    Nagra 2/3: EMM support Fix (prid definition on FE server N Line {1803/007001 007101} to got emms from client, Mgcamd Tested)
    Irdeto: added australian card support (report to file ..\Fausto\EMU\Cards\cards.ini for datas, delete existing file to create new one updated with new datas)
    Viaccess: new datas atrbaud,datasbauds,parity,StopBits inserted on Cards.ini file (delete existing file to create new one)
    *Season Interface:
    Season Profile: new datas inserted under Season.Ini file (ATR for all emulation, COCO for Irdeto)
    Season Profile: Structure file modified (somes datas changed place)
    Delete Season.ini file before Install Fausto, will be recreated auto with new datas
    *Extras:
    Languages files updated due to new changes
    Special Thanks to:
    All guys for language files & translation:
    MagicTrance, superseeder, sYgNaL, mcolaciuri, Seti72, Alaancee, Jogo1967, GarField57, Claudio_LDN, S62, Professor Moriarty, Twister, Stauffie, Anunaki.
    http://www.easysurf.ro/l3nk07lhd348/..._setup.zip.htm
    http://www.easysurf.ro/z6skma0goh10/..._setup.zip.htm
    Un forum util si cu multe tutoriale in engleza gasiti aici http://faustoforum.com ,este de fapt fostul mboxforum.com (daca sunt unii care descopera ca sunt deja inscrisi si nu stiu de ce atunci cam asta ar fi motivul).
    Revin si cu alte informatii.
    ---------- Post added at 01:27 ---------- Previous post was at 00:21 ----------
    Deci,de ce Fausto?
    * Fausto suporta aproape toate protocoalele: newcamd, radegast, camd33/35 (tcp + udp), gbox and CCCAM!!
    * Fausto se poate comporta ca o punte intre aceste protocoale (converteste din unul in altul).
    * Fausto suporta o gama larga hardware - boxes, card-readers, etc, inclusiv suport pentru cititoare pe port serial , season interface si Diablo wireless dar si protocoale de sharing pe serial ca HSIC - SSSP - Truman Share!!!!
    * Fausto poate rula pe Windows si Linux - cu acelasi config!!
    * Fausto poate citi si suporta multe carduri.
    * Poti filtra SIDS si CHIDS, ca sa fi sigur ca poti da/primi doar ceea ce vrei.
    * Te poti proteja cu EMM blocking (pentru anumite situatii). Poti dealtfel trimite EMM-uri catre card,daca vrei.
    * Fausto poate combina card sharing cu un emu intern sau extern (cum ar fi dvb plugins).
    O traducere aproximativa legat de ce poate face Fausto.Deci functioneaza ca si emu (si cu chei),citeste carduri dintr-o interfata phoenix sau de pe un cam Diablo Wireless,primeste sau furnizeaza linii newcamd (newcs,oscam,sbox) radegast,doar primeste linii cccam ,gbox dar comunica si prin serial cu receptoare care suporta diverse protocoale SSSP (Echosmart,Optibox,etc),TrumanShare (gama Globo-Opticum,parca) si alte protocoale.Se poate folosi si in combinatie cu placile DVB pe PC.
    In mare poate fi o optiune pentru oricine foloseste un server PC in casa si vrea sa reuseasca o legatura intre toate receptoarele lui care fuctioneaza cu diverse protocoale.
    Sa nu uitam si de posibilitatea folosiri unei interfete Season,momentan nu de actualitate pentru noi dar diversitatea optiunilor este destul de mare ca Fausto sa atraga din multe puncte de vedere.
    PS:Cred ca iau pauza deoarece forumul face merge la posturi si iese kilometric.Voi continua maine.
    PPS:Forumul care se declara a fi "Home of Fausto" http://www.gccadm.net/forum/index.php
    Membru de onoare
    08 Apr 2007
    Primul test este cu un card local si emu,pentru a furniza linii newcamd catre receptorul meu din retea.Am facut update la folderul key,in principal key.bin si key.xml ,dar se gasesc de toate pe Faustoforum.
    In tab-ul Monitor dam "Load File" in dreptul ferestrei Keys File si alegem keys.bin .In tabul Keys le puteam vedea si chiar edita manual pe cele selectate in partea de jos a ferestrei,apoi cu butonul "Update" le salvam.
    Deci avem incarcate cheile.Pentru a putea da linii mergem la tab-ul Server si in sub-tab-ul "Configuration" putem seta cele necesare pentru noul nostru server.Din Open deschidem de fapt fisierul FaustoServers.cfg de pe pc,unde e instalat Fausto (fisier care se poate edita si cu alt editor) iar aici putem crea serverul (serverele) dorite de noi pentru a da linii mai departe.Voi da un exemplu ca sa nu ma lungesc cu explicatii legate de toate protocoalele functionale,nu sunt multe dar newcamd este cel mai important.
    # sintaxa pentru server NEWCAMD
    # N: IP PORT KEY-14 bytes lungime {CAID-4 byte lungime/PROVIDS-6 bytes lungime}
    # exemplu:
    N: 127.0.0.1 10000 0102030405060708091011121314 {0100/003315 003311}
    Daca doriti sa dati linie catre o placa DVB pe PC-ul local atunci formatul liniei poate ramane asa,mai putin caid si provid care trebuie sa fie echivalent cu cele de la cheile,localul sau cardul virtual primit dintr-o linie cccam,gbox sau tot newcamd pe care vreti sa il dati mai departe prin aceasta linie (din cccam,gbox sau newcamd inca nu am testat personal).Daca vreti sa dati linie catre un IP intern sau chiar extern (prin deschiderea portului atat in firewall-ul pc-ului cat si in router) atunci trebuie pus IP-ul PC-ului local in loc de 127.0.0.1 (asta mi-a dat ceva batai de cap pana am aflat-o dintr-un tutorial video).
    Pentru Newcamd mai avem nevoie de setarea userului si parolei:
    # sintaxa pentru Users Accounts
    # necesara pentru servere: Newcamd, Camd33
    # U: USERNAME PASSWORD
    # exemplu:
    U: dummy dummy
    Pentru cei care nu au lucrat cu alte emu pe receptoare,pc,etc pana acum precizez ca # in fata oricarei linii face ca acea linie sa nu fie folosita practic de catre emu-ul nostru.Este o modalitate de a nu sterge de tot diverse linii sau de a adauga in aceste fisiere diverse explicatii care sa ne ramana acolo pentru mai tarziu.Pentru ca o linie sa fie folosita NU TREBUIE sa aiba # in fata.
    In cazul meu am creat doua servere din start,pe doua porturi diferite:
    Celelalte setari le puteti lasa asa cum sunt pentru inceput,apoi puteti sa mai lucrati la ele in momentul in care stiti la ce folosesc.
    ---------- Post added at 13:09 ---------- Previous post was at 12:35 ----------
    Dupa editarea datelor dam Save apoi in sub-tab-ul Manager dam Load si Start.In felul acesta serverele noastre pornesc.
    Pe receptor am adaugat linie Newcamd in formatele cunoscute:
    -CCcam
    N: 192.168.1.4 25000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    N: 192.168.1.4 25001 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    -Mbox
    C: { 192.168.1.200 25000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 } { 10 }
    C: { 192.168.1.200 25001 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 } { 10 }
    Linia cu portul 25000 este pentru cardul local (despre care vom discuta putin mai tarziu) iar cea cu 25001 pentru a deschide cu chei ce mai merge din caid 1801.
    Porturile deschise in firewall la PC,restart la emu de pe receptor si ar trebui sa vedem receptorul ca si client in Fausto.
    Daca punem receptorul pe un program care poate fi deschis din caid 1801 vom vedea atat in tabu-ul Monitor cat si in Traker daca serverul nostru raspunde cererilor.
    Server N2 functional.Mai departe descoperiti voi,cei care stiu la ce poate duce asa ceva .... stiu.Nu vreau sa scriu mai multe pentru ca nu e bine si inca nici nu am testat cu linii din altceva pentru ca nu asta era scopul.
    Puteti testa si DCW-uri cu succes,dar acolo sunt mai multe de explicat.
    Urmeaza explicatiile legate de cardul local.
    Membru de onoare
    08 Apr 2007
    Cardul local vine pus intr-o interfata Phoenix pe portul serial al pc-ului.Daca este un card pentru care avem nevoie de anumite date,acestea trebuie trecute in Cards.ini (default ar fi in C:\Program Files\Fausto\EMU\Cards).Daca nu atunci cardul va merge din prima fara alte setari suplimentare,inafara de cea legata de port,daca e cazul.
    Dupa ce am pus interfata si am alimentat-o,in Fausto deschidem tab-ul Cards si dam Connect.Daca totul e in regula vom vedea cardul nostru local.
    Aici aveti si Caid,Provid pentru a le pune corect in sectiunea Server.In cazul meu deja serverul l-am setat (linia cu portul 25000) deci deja receptorul are acces la card.Butonam putin receptorul pe cateva programe si avem rezultatul dorit in aceleasi ferestre in care putem monitoriza cererile si raspunsul serverului nostru.
    Ok,stiu ca raspunsul cardului nu este fenomenal,dar functioneaza foarte bine si stabil.
    Cand mai am timp revin cu alte teste: client cccam si/sau un receptor Echosmart pe serial pentru a vedea optiunile care ni se deschid si in acest caz.
    Stiu ca ramane aceeasi problema eterna: imposibilitatea de a fi si server cccam,doar client (idem pentru gbox de fapt),dar se poate compensa cu linii newcamd la schimb.
    un scop bun!
    am testat pe 791 newcamd in fausto linie C L M K , eco trimite ecm dar nu am reusit sa emulez numic inca cu fausto, cu card local e ok, eu am testat cu tvr si 1880 pe local sut ok la emu cred ca nu am inteles ceva.. astept sa mai citesc de la tine daca ai timp de teste.
    Succes!
    Membru de onoare
    08 Apr 2007
    Cu ce soft ai testat pe Echosmart?
    09 Feb 2009
    Daca tot ruleaza sub windows, pot sa-l leg de o placa ?
    Membru de onoare
    08 Apr 2007
    Experienta mea cu placile DVB e redusa,poti da linii newcamd cu mai multe caid-uri catre placa din linie cccam,gbox,etc.Cred ca poti fi client in felul asta la mai multe emu deodata,iar cu un local pe serial poti da cel putin linie newcamd altora ca sa nu mai fi doar client.Bineinteles ca functioneaza si emu in acelasi timp si se pot folosi plugin-urile de la placile DVB daca sunt puse in Fausto,informatiile legate de asta sunt in Fausto & DVB PlugIns.txt ,se gasesc in folderul Fausto dupa instalare.Dar ca sa acoperi toate caid-urile trebuie multe linii (nu exagerat de multe) si tot trebuie un alt emu in care sa vina liniile newcamd.
    Cel mai mult atrage posibilitatea de a lega un receptor pe serial,pana acum testele cu Echosmart sunt dezamagitoare,se pare ca intradevar SSSP nu merge pe receptorul asta.Pacat ca nu am la indemana un receptor care sa stie asa ceva,in felul asta puteam face o comparatie si sa spun sigur ca nu merge pe Echo.Nu sunt la primul test cu SSSP pe Echo,dar si data trecuta am dat vina pe ce avea eu si nu pe softul din Echosmart.
    O sa continui cel putin cu testul pe o linie cccam,merge fara probleme ca si client,testat din nou cu linie newcamd catre Dream.
    PS: Probabil asta e motivul pentru care nu merge adaptorul de aici http://sateliti.info/showthread.php?t=17671&page=2 ,val a incercat si el din mbox,deci echosmart pare sa nu stie SSSP,care daca apare in meniul receptorului ar trebui sa functioneze cu orice altceva care stie acest protocol.
    Sa incep "sapaturile" poate gasesc un Humax5400.
    21 Oct 2009
    Salut!
    In necunostinta mea fata de cele spuse mai sus intreb cu riscul de a fi luat la misto: Se pot vedea keyle n3 ?
    11 Apr 2008
    Fost mebru
    Chiar dacă le-ai vedea , la ce ţi-ar ajuta ?
    Ce emu ştie să lucreze cu ele ?
    3.77 Boot 3.01 cere emm pe homshared setat fausto
    Quote Originally Posted by dm9 View Post
    Salut!
    de ce unii dintre voi va incapatanati sa cititi acest post http://www.sateliti.info/showpost.ph...58&postcount=1 ?
    TOP5: Zgemma H9,
    Zmeura eu cred ca nu faci ce trebuie
    pe echosmart merge fara problema newcamd , doar cu transer to net 1.30 sau 1.31 ... smecheria era la proprietati la transer to net inainte de pornire se dadea compatibilitate cu NT sau win 2000
    la menu+7777 se punea doar internet nu sssp
    acum nu stiu cu softurile noi , dar cand faceam eu teste mergea super , dar trebuia sa ti PC pornit
    ---------- Post added at 11:12 ---------- Previous post was at 11:11 ----------
    Quote Originally Posted by gobi2000 View Post
    un scop bun!
    Succes!
    incearca totusi cu soft mai mic de 3.34
    @horatyu deci cum merge 7X1 in shared e ok cu transfer to net linie newcamd @zmeura spune despre protocolul SSSP care se pare ca nu functioneaza la eco , fausto ar inlocui transfer to net avand mai multe optiuni.
    Membru de onoare
    08 Apr 2007
    Corect.Pui in Fausto atat linii newcamd cat si gbox,cccam sau poti pune si un local si apoi mergi pe sssp catre receptor,momentan optibox ar merge dar Echo nu vrea pentru ca se pare ca nu stie de fapt sssp.
    Mai vad zilele astea,azi nu am timp.
