Cu respectiva combinatie , periodic linia N cade.Dupa ce-i dau restart porneste iar..........dupa un timp iar cade N.Ce-i de facut ?
Asa arata sbox:
[main]
server_only=1 # 0=emu+newcamd server 1=only newcamd server
log=0 # 0=no log 1=log to /tmp/sbox.log //ALWAYS USE 0//
userspath=/var/bin/users.sbox # users list
webinterface=1 # 1=web interface on 0=web interface off
webport=8181 # web interface port
[slot0]
active=1 # 0=inactive 1=active
sci=/dev/sci0 # lower
ncdserver=1 # 0=newcamd server off 1=newcamd server on
deskey=1112232455667788991911121314 # newcamd deskey
port=xxxx # newcamd port
mhz=357 # Mhz for card in this reader, DON'T WORK ON PHOENIX INTERFACE. Example: mhz=357, mhz=368
reader=1 # 0=phoenix, 1=sci (internal reader), 2=smartreader
# How to ADD RSA for TIGER/NCMED cards
# If your card is a ROM TIGER547 Rev124 (for example)
# [TIGER547] <- this is the rom version from your card
# rsa=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
# ONLY THIS, for config bloquer, portlist, etc, look at the examples above!
#Nagra2/3 Example
[xxxxxxxx] # nagra2 camid (4 bytes)
rsa=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
# rsa "n" from this card (like newcs)
boxkey=xxxxxxxxxxxxxxx
# boxkey from this card
emm=0 # 0=accept all 1=block emms 2=block emmu 4=block emmg
portlist=0 # use portlist or no
#portlistpath=/var/keys/port.list # path from port.list
O idee va rog...........
