Results 1 to 7 of 7
Thread: card init fail
    24 Jun 2010
    Default card init fail
    Salut
    am citit si citit si citit la o gramada de forumuri dar tot n-am gasit raspunsul pt problema mea.
    card dolce, care in dm500s merge fara probleme+sharing local
    vreau sa fac un server 24/7, Ubuntu 9.10, smargo smartreader+,
    cand bag smargo-ul si pronesc Cccam am urmatoarea problema:
    17:17:32.730 CCcam: calculated EGT: 39 us
    17:17:32.730 CCcam: nds card found
    17:17:35.755 CCcam: card init fail
    17:17:37.168 CCcam: calculated EGT: 39 us
    17:17:37.168 CCcam: nds card found
    17:17:40.186 CCcam: card init fail
    am incercat incercat tot feluri de chestii(alt calculator, alt smargo, alt cccam.cfg), dar tot nu merge.
    Pur si simplu nu mai stiu ce sa fac.
    Iar in dm500 merge fara probleme, numai pe pc nu.
    Any ideas?
    As aprecia.....
    10x
    Dute in var/log/mesage cu smartgo-ul scos baga si da refres la fisierul mesage vezi cum il recunoaste
    Code:
    usbcore: registered new interface driver usbserial_generic
    usbserial: USB Serial Driver core
    USB Serial support registered for FTDI USB Serial Device
    ftdi_sio 2-2:1.0: FTDI USB Serial Device converter detected
    usb 2-2: Detected FT232RL
    usb 2-2: Number of endpoints 2
    usb 2-2: Endpoint 1 MaxPacketSize 64
    usb 2-2: Endpoint 2 MaxPacketSize 64
    usb 2-2: Setting MaxPacketSize 64
    usb 2-2: FTDI USB Serial Device converter now attached to ttyUSB0
    29 Mar 2009
    Austria - TM
    daca ne pui configul am putea zice mai mult
    si eu am un ubuntu 9.10 si smargo l-am cautat cu lsusb
    [reader]
    protocol = smartreader
    detect = CD
    device = 002:004
    acum depinde ce ai si tu
    24 Jun 2010
    Default config
    Nu ma lasat sa intru cu userul vechi, nici parola n-am putut sa resetez, asa ca a trebuit sa-mi fac un nou user
    deci
    configul
    #### Config ####
    SERVER LISTEN PORT : 10010
    ALLOW TELNETINFO: yes
    ALLOW WEBINFO: yes
    WEBINFO USERNAME :
    WEBINFO PASSWORD :
    TELNETINFO USERNAME :
    TELNETINFO PASSWORD :
    TELNETINFO LISTEN PORT : 16010
    WEBINFO LISTEN PORT : 16002
    ZAP OSD TIME :0
    OSD USERNAME :root
    OSD PASSWORD :####
    OSD PORT :80
    SHOW TIMING : yes
    DEBUG : no
    NEWCAMD CONF :no
    DISABLE EMM : no
    EXTRA EMM LEVEL : yes
    MINI OSD : yes
    CAID PRIO FILE : /var/keys/CCcam.prio
    #LOADBALANCE : /dev/ttyUSB0 /dev/ttyUSB1
    SERIAL READER : /dev/ttyUSB1
    DVB API: -1
    BOXKEY: /dev/ttyUSB1 xx xx xx xx
    SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB1 3570000
    MINIMUM CLIENT VERSION : 2.0.1
    EMM THREADS : 1
    MINIMUM DOWNHOPS: 0
    iar la log/messeges am
    usb 2-5: new full speed USB device using ohci_hcd and address 4
    usb 2-5: configuration #1 chosen from 1 choice
    ftdi_sio 2-5:1.0: FTDI USB Serial Device converter detected
    usb 2-5: Detected FT232BM
    usb 2-5: Number of endpoints 2
    usb 2-5: Endpoint 1 MaxPacketSize 64
    usb 2-5: Endpoint 2 MaxPacketSize 64
    usb 2-5: Setting MaxPacketSize 64
    usb 2-5: FTDI USB Serial Device converter now attached to ttyUSB1
    la lsusb am
    Bus 002 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    29 Mar 2009
    Austria - TM
    Smargo cum l-ai setat ?
    Mode: Autoswitch
    Kernel: Normal
    T-Mode: T=0 sau 1
    EGT: 0
    24 Jun 2010
    MODE autoswitch
    FREQ 3.69 Mhz
    KERNEL normal
    T_MODE t = 0
    EGT 0
    e setat cum ai scris tu......
    am incercat o gramada de chestii......de la frecventa pana la comandarea unui nou smargo........dar tot asa face.
    Standard RSP member disat's Avatar
    19 Feb 2009
    Question smargo
    UNDE AI SETAT TU FRECVENTA ASTA IN SMARGO?
    FREQ 3.69 Mhz!!
