Dislikes:
- 64
A aparut PKT 9.6.1
Ipbox 91HD:
http://e2.pkteam.pl/index.php?dir=IM...file=91.tar.gz
Ipbox 900HD:
http://e2.pkteam.pl/index.php?dir=IM...ile=900.tar.gz
Ipbox 910HD:
http://e2.pkteam.pl/index.php?dir=IM...ile=910.tar.gz
Ipbox 9000HD:
http://e2.pkteam.pl/index.php?dir=IM...le=9000.tar.gz
- Added Media Center Menu
- Ejected from the menu VCR scart
- Reorganization of the Setup Menu
- POINT dopaswanie skins to change the menu
- Update Picon
- Added new plugin POINT Skin Setup (described in section Skins POINT)
- Added ability to disable the background image in the radio mode
- Added ability to disable top info bar in the Skinhead BlackGlass show off EMU in Skin Setup Info
- Cosmetic fixes in Skinhead BlackGlassHD
- Added call POINT Skin Setup by pressing the SWAP (the sub-web)
- Skin removed PKT_F1-Lite - now with Skin Setup can be obtained from the same Skin PKT_F1-HD
- Added support for the EmuCamInfo OSCAM (works with versions that generate ecm.info)
- Optymaplizacja code EmuCamInfo
- Other minor fixes and performance graphics
Greetings to Polish Team Kathi
WARNING! We assume no responsibility for the use THIS SOFTWARE unlawfully, REMEMBER THAT LOOK unpaid pay television subscription is a crime and are punishable by imprisonment up to 3 years!
