Dislikes: 0
Dream Elite Vu+ Duo BH 1.3.3
Specifications:
Based on NEW Official release 4.8
- New Bootlogo by Army
- New Skin Beyonce F1 by matrix10
- Fix "timer:waiting..." problem
- Fix input event buffer allocation problem(no free fifo)
- Update satellites.xml
- Update kernel and drivers
- Fix booting problem when there is no rtc at the front board
- Fix video freezing problem in AC3 pass-through playback
- Fix lagging problem when no satellite signal
- Support 2 virtual tuners(vtuner0/vtuner1)
- Support generic linux input device
- Modify the dvb-core frontend header for easy backporting of usb driver
- Fix 4:3 video mode problem.
- Turn off FAN at stadnby mode when there is no channel recording.(Duo only)
- Fix udev problem.
- Change mbox-dvb-modules.bb to download driver from vuplus server.( ** All build trees are being moved to vuplus git server **)
- Move kernel-module dependency to mbox-dvb-modules.bb from initscripts-mbox_1.0.bb
- Clean up udev-static-devices
- Internal test routine is added to e2
- Fix framerate information(20100603 driver)
- New Dream Elite Usb Tuner Panel
- New Check for correct image in flash
- New Dream Elite own pathed kernel
- New Usb Tuner Panel for drivers donwloadl
Meoboot Removed:
Meoboot have been removed becouse of stability and performance reasons. We think that in Vu+ Duo is better to have Dream-Elite image directly in flash and to not use multiboot systems that should cause kernel conflicts
This is the first Vu+ Duo image in the world that have USB TUNER SUPPORT.
The Usb tuner support is experimental.
At the present it seems to work very good with: Hauppauge WinTV Nova stick.
But it seems to work on FTA channels only. We will wait for driver fix by VuDuo for crypted channels support to in Usb Tuner.
Warning: BECAUSE OF NEW DRIVERS THIS IMAGE HAVE TO BE INSTALLED IN FLASH YOU CANNOT INSTALL THIS IMAGE IN MULTIBOOT WITH PREVIOUS DREAM ELITE BH IMAGE OR ANY OTHER IMAGE.
THIS IMAGE HAVE TO STAY IN FLASH.
This image is a final Black Hole serie, entirely rewrote and recoded to have maximum stability and performance.
We remember that black hole serie images have the best epg system available:
- Integrated Openepg for Sky-it Sky-uk Sky-Au
- Latest CVS enigma2 Epg features
- New external epg.dat system.
Therefore, each board or community can create its favourite EPG data files, and upload it to a web space. Community members can then download it from that server.
This feature offers additional benefits, such as:
EPG download increased speed
EPG download from any channel
EPG scheduled download also during standby
User set EPG Providers Add/Remove
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Dream ELite Blue Panel
Button 1x Blue + 1x Red = Dream Elite Epg Panel
Button 1x Blue + 1x Yellow = New System Monitor Panel
Button Green = Dream Elite Green Panel
Button Green-Long-Push = Subservices
Button 1x Green + 1x Red = CCcam Info
Button Yellow = Time Shift
Addons
Dedicated Addons Server
Download and install additional packages from Dream Elite server
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information
Dream Elite Panels features
Blue Panel
Extra Setting
Black Hole Cron Manager
OSD Settings
Devices Manager
Kernel Modules Manager
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Black Hola Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
Info
CCcam Info
Service Info
Enigma2 Settings
About
Memory
Space
CPU
Process
AutoCam
Select EMU by Channel
EPG Panel
Global setting
Provider Setting
Green Panel
CCcam info
Fast Plugin
Addons
Addons Download Manager
Manual Install Del packages
Manual Install IPK packages
Addons Uninstall Panel
Dream Elite Statistics
Scripts
Many thanks to the Beta Testers Team.
Many thanks to Rytec for all the epg servers providing precompiled Epg.dat for Dream Elite Image (add skyIta and SkyDe).
Credits
Many Thanks to Rytec for external epg
E2 Sky Epg loader integration by MaxZ4.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
Many thanks to Reinh@rd for the satellites.xml file.
SPECIAL THANKS TO ANGELOFSKY1980 AND DPEDDI FOR USB DVB-T DRIVERS
- USBTUNER REWROTE BY angelofsky1980 and PATCHED by dpeddi
- DE-API KERNEL PATCH BY dpeddi
ATTENTION!
THIS IMAGE HAVE TO BE INSTALLED IN FLASH.
THIS IMAGE CANNOT WORK IN MULTIBOOT WITH DIFFERENT IMAGES IN FLASH.
STARTING FROM THIS VERSION DREAM-ELITE IMAGES HAVE AN OWN PATCHED KERNEL VERSION WITH A CHECK FOR THE CORRECT IMAGE IN FLASH.
Backups or other modified Images are not supported!
This Images doesn't contain any keys nor softcams.
easysurf.ro_DreamEliteBH_VUDUO_133D_USB.zip - 37.7 Mb
