Page 2 of 16 FirstFirst 12345612 ... LastLast
Results 16 to 30 of 231
Thread: Activare smartcard TVR tel: +40213058951
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    la mine nu a vrut sa faca AU cu oscam, cum am bagat mgcamd+newcs a facut instantaneu, posibil sa fi fost deja activat(sa le activeze ei la vanzare) sau DA a facut cu oscam si atunci isi ia si EMM-uri.
    Stai linistit in legatura cu modulul VIA, dai banii degeaba pentru o asemenea cartela.
    cumparat cartela anul trecut,au activat o doar vreo 2 sau 3 luni,nu mai retin si de atunci cred ca numa Dumnezeu daca o mai activeaza si poate ii face update ca eu tot ce am incercat a fost in zadarpe langa email urile date in disperare catre ei,nici macar bunu simt sa imi raspunda nu au avut
    26 Oct 2009
    Walachia / Paname
    Cu astea a facut AU instantaneu, a se modifica in functie de receiver/reader
    newcs.xml(1.67)
    <newCSconfig>
        <readers name="AZBOX">
             <device>
                <name>Smargo1</name>
                <type>smartreader+</type>
                <mhz>357</mhz>
                <node>/dev/ttyUSB0</node>
                <parity>odd</parity>
                <reset>normal</reset>
                <export>Yes</export>
                <enabled>Yes</enabled>
                <blocksa>No</blocksa>
                <blockua>No</blockua>
                <blockga>No</blockga>
                <blockC0>yes</blockC0>
                <boxkey></boxkey>
                <PTShandshake>No</PTShandshake>
                <carddetect>Yes</carddetect>
                <newcamd_port>34000</newcamd_port>
                <autosid>Yes</autosid>
                    <sid>
                        <allow>
                        <id>0001</id>
                        <id>0002</id>
                        <id>000F</id>
                        </allow>
                        <deny>
                        </deny>
                    </sid>
                <Seca-PPV>No</Seca-PPV>
                <pincode>0000</pincode>
                <priority>round</priority>
            </device>
        </readers>
        <cache>
                <emm>20</emm>
                <ecm>-1</ecm>
        </cache>
        <httpd>
            <server>
                <port>8080</port>
                <enabled>yes</enabled>
            </server>
            <user>
                <name>newcs</name>
                <password>newcspass</password>
                <accesslevel>admin</accesslevel>
            </user>
        </httpd>
        <debug>
                <password>NewCSpwd</password>
                 <mode>simple</mode>
                 <darint39>sintoi51</darint39>
                <level>normal</level>
                <type>all</type>
                <output>console,tcp</output>
                <logfile>/tmp/newcs.txt</logfile>
                <console_options>normal,init</console_options>
                <file_options>init,ecm,emm,all</file_options>
                <udp_host>192.168.x.x</udp_host>
                <udp_port>9001</udp_port>
                <udp_options>normal,init</udp_options>
                <tcp_host>192.168.X.X</tcp_host>
                <tcp_port>1001</tcp_port>
                <tcp_password>newcs</tcp_password>
                <tcp_options>normal,init</tcp_options>
        </debug>
        <newcamdserver>
                    <name>newcs</name>
                    <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
                <user>
                    <status>access</status>
                    <name>mgcamd</name>
                    <password>mgcamd</password>
                    <hostname>127.0.0.1</hostname>
                    <port>34000</port>
                    <au>on</au>
                    <spider>Yes</spider>
                    <allow>Smargo1</allow>
                    <sidoverride>off</sidoverride>
                    <rate>2</rate>
                    <cardlevel>1</cardlevel>
                </user>
             </newcamdserver>
    </newCSconfig>
    mg_cfg(1.35a)
    # EMM messages
    #    00 don't show any EMMs (default)
    #    01 show only valid EMMs
    #    02 show valid and bad EMMs with complete data display
    M: { 01 }
    # ECM messages
    #    00 don't show anything about ecm
    #    01 normal mode, show pids processed, decoded ecm and cw
    #    02 verbose mode, show valid and bad ECMs with data
    C: { 01 }
    # AU
    #    00 disable, no emm pids processed
    #    01 enable, emm pids always processed for soft-au and shared cards
    #    02 auto, emm started only if channel cant be decoded
    #    03 process emm pids for network cards update only
    A: { 02 }
    # key update (sum 01 or 02 with 04)
    #    01 update only new keys, default setting
    #    02 update all keys (used for valid PMK checking)
    #    04 enable TPS au
    #    + tps SID, which pmt pid contains au pid
    U: { 01 } 0x12c0
    # config files folder (softcam, autoroll, ignore/priority)
    #    00 files in /var/keys
    #    01 files in /tmp
    T: { 00 }
    # network mode, use summ for several clients
    #    00 no network (default)
    #    01 newcamd netclient
    #    02 radegast netclient
    #    04 camd3 netclient
    #    08 gbox netclient
    #    32    cccamd netclient, card list saved as /tmp/cccamd.info
    #        (ECM only, supported server version up to 2.1.1, later not work)
    G: { 33 }
    # network retry, use summ for several options
    #    00 disable
    #    01 retry every new ecm
    #    02 try to connect to offline shares every Q: seconds
    #    04 try to detect and fast reconnect to lost (and not used atm) server
    #    + XX messages number and YY seconds to reconnect
    #    mg will reconnect to server, if no answer to last XX ecm/keepalive or
    #    if no answer for last ecm or keepalive sent for YY seconds
    #    set to 0 to disable
    N: { 07 } 5 30
    # network ecm timeout in seconds
    K: { 05 }
    # newcamd dead routes connect retry, sec
    Q: { 600 }
    # network shares priority
    # 00 gbox, newcamd, cccamd, radegast, camd3 (default)
    # 01 camd3, radegast, cccamd, gbox, newcamd
    # 02 cccamd, newcamd, camd3, gbox, radegast
    P: { 02 }
    # on screen display type
    #    00 No OSD (default)
    #    01 neutrino
    #    02 enigma
    #    03 relook
    #    + user password for http auth
    O: { 00 } username password
    # on screen display Options, summ of:
    #    01 show emu ecm
    #    02 show network shares messages
    #    04 show decoding failed / fta
    #    08 show emm keys update
    #    + web port to use for osd
    S: { 03 } 8000
    # Log option, summ of:
    #    00 off
    #    01 network udp log
    #    02 log to console
    #    04 file, appended ! delete it by yourself, before it eat all your hdd
    #    + IP udp-port log-file-name
    L: { 03 } 192.168.X.X 12005 /tmp/mgcamd.log
    # keep ecm cache, seconds
    # every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
    # for openbox/elanvision users with remote shares make sense to set it higher than default value,
    # to not hammer cards while timeshifting or playing crypted recordings.
    E: { 15 }
    # cache option, summ of:
    #    00 Off (default)
    #    01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
    #    02 Ecm data cache, remember CW for (E:) time
    #    04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
    H: { 07 }
    # reread files, summ of:
    #    00 No (default)
    #    01 reread config file on channel change (including priority and ignore, but not replace/cache)
    #    02 reread SoftCam.Key on channel change
    #    04 reread SoftCam.Key if file changed
    R: { 00 }
    # debug, summ of
    # 00 off (default)
    # 01 debug ecm
    # 02 debug emm
    # 04 debug network ecm
    # 08 debug network emm
    # 16 debug network login
    # 32 show mem/cpu stats every 1 min
    # 64 add timestamp to log messages
    D: { 00 }
    # box type
    # 00 autodetect, change only if you think wrong type detected.
    # 01 dbox2
    # 02 dreambox
    # 03 triple-dragon
    # 04 relook
    # 05 openbox
    # 06 dreambox/mips
    # 08 stapi/kathrein
    # 09 stapi/ipbox
    # 11 stapi/openbox
    B: { 00 }
    # map all 180x nagra caids to 1801
    # default is 01
    F: { 00 }
    newcamd.list
    CWS = 127.0.0.1 34000 mgcamd mgcamd 01 02 03 04 05 06 07 08 09 10 11 12 13 14 2 lan newcs
    CWS_INCOMING_PORT = 12000
    04 Jan 2010
    deci cartela mea daca vede ,a facut au sau nu ?
    29 Mar 2009
    Austria - TM
    DAca vezi cred ca a facut dar mai sigur uitate sa vezi data pentru urmatorul update in entitlements
    In cazul asta nu mai trebuie päna in 23,02,2011
    card reader /dev/sci0
    handled 0(0) ecms and 1(1) emms
    Viaccess card
    Caid 500
    Cardserial bf645a
    ident fff720 - bf645a
    ident 25900 - bf645a
    ident 25910 - bf645a
    valid from 27-8-2010 untill 23-2-2011
    valid from 18-8-2010 untill 23-2-2011
    Standard RSP member cristy's Avatar
    08 Jul 2008
    Pe undeva prin Arges
    eu am facut update in gbox2.1b de la nabilo in cateva secunde. fara sa mai sun la ei.
    04 Jan 2010
    Aveti idee cum pot vedea entitlements ?
    Am AAF sumer image si oscam ultima versiune .
    dMd
    Guest
    Foloseste functia webif de la Oscam si acolo ai entitlements.
    30 May 2010
    Default rezolvat
    felicitări TVR! azi duminică am constatat că una din cartelele TVR din casă nu mai funcţioneaza , am sunat la nr din acest thread şi dl de acolo mi-a activat-o in circa 20 - 30 secunde cit a durat convorbirea.
    ok ma bucur pentru voi,eu am sunat acum vreo 3 zile si de atunci pauza,omu nu gasea nici pix ca sa noteze seria.eu alta metoda de a activa cartela nu stiu decat newcs mgcamd dar nu vrea nici sa l ..... daca aveti ceva configuri ptr dreambox sa o activez spuneti mi si mie
    multumesc
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    Se apropie data exprarii: 23.o2.2o11.
    A facut auto update la cineva?
    Se vorbea ca incepand cu februarie se va da drumul la un nou termen.
    23 Apr 2007
    P3X-888
    si eu am un card tvr care tot asa spune
    class: 0A, expiry date: 2010/08/18 - 2011/02/23
    ultima data cand am facut update am facut in echosmart sper sa mearga si de data asta "vrajeala"
    29 Nov 2008
    Cu capu' in nori
    La mine nu a mers acu vreo 3 zile ţinut in cam Viaccess, pană nu am sunat la ei.
    03 Feb 2009
    maramures
    @Stargate! Ne spui si noua cum e "vrajeala" in Echosmart cu ,cardulTvr?
    Golden Member mar1us's Avatar
    09 May 2009
    dublin
    nu e nicio vrajeala,treaba e ca nu orice soft face update la card o sa vedem cind va fi adica pe 23 luna asta care soft face update.Eu am akta pe technomate 6900super si softul nu face update nici la akta,trebuie sa il bag in echosmart 792 sw 3.80
