Results 1 to 2 of 2
Thread: SifTeam Enigma2 095 !!!
Threaded View
    21 Post(s)
    Default SifTeam Enigma2 095 !!!
    Insfarsit o noua versiune ! dupa o pauza cam lunga ...deocamdata va servesc
    doar "release note" dar promit sa revin cu detalii de testare !
    Originariamente inviata da ReadMe
    release 0.9.5
    - back to STLinux 2.2 because of some audio bugs on STLinux 2.3: when i will fix it, we will go again on stlinux 2.3
    - added wmv file player
    - added multi descrambling feature: i tested it only with incubusCamd 0.99 wich fully supports multidescrambling
    for e2 (previous version don't work, and i don't know if other softcams works or not, just test them)
    - fixed some memory crash on h264 channels
    - fixed remote controller buttons with teletext activated
    - fixed DVDPlayer crash
    - DVDPlayer buttons are now better showed than before
    - supported DTS audio on mkv files
    - other MediaPlayer fixes
    - updated greek language
    - updated bulgarian language
    - added samba (not started by default, you have to add it on the rcS_user.sh if you need it)
    - added cp2101 external card reader drivers (load it in rcS_user.sh if you need it: /lib/modules/cp2101.ko)
    - added ralink rt2870 wireless chipset drivers (load them in rcS_user.sh if you need it: /lib/modules/rt2870sta.ko)
    - added Freesat EPG support
    - by default the sci-ng driver (pacco's 1.4 version) is loaded at enigma2's boot: this is a temporary option, i built a
    sc driver but still getting many memory errors, i don't know when it will be full ready
    - update Enigma2 CVS to 02/05/2010
    - enabled again PIP function, watching 2 channels on PIP will make slow live channels playing, so it does not work at 100%
    Enjoy it! Tideglo
    ---------- Post added at 18:02 ---------- Previous post was at 16:16 ----------
    Zis si facut !
    - imaginea s-a instalat fara surprize pe IPBOX 910
    - am oprit wizardul care verifica spatiul in flash ( dezactivat )
    - am facut curat manual ( /usr/loacal/share/enigma2/po ) am sters
    toate limbile ...mai putin cea curenta
    - am pus settings E2
    - am pus panel RSP ( tnks Zildan ! )
    - am adus din panel incubus97 si mgcamd1_35
    - am inlocuit incubus97 cu 99 ( inca nu este in panel ! )
    - si am pornit la teste
    Constatari :
    - misca senzational prin meniuri ! Dreamboxul se poate ascunde !
    - dupa mai multe manevre am ramas fara sunet ! am pus WSS=on si a fost OK !
    - am ramas din nou fara sunet la un zaping ... prea rapid sub incubus ...WSS=off si a fost ok !
    - per total ...cu lipsurile acestea imaginea este de departe cea mai sprintena vazuta !
    - teste facute pe un tv/monitor SD ! o sa reiau pe HDMI !
