Parca este mai sprintena decat alte imagini ...am dat un "reload enigma" si a mers foarte repede ! deocamdata numai bine despre imagine !
Gemini2 v5.0
Enigma from 29.04.2010 - Patched drivers and SSL75, SSL72, SSL70 and SSL69.
An overview over most functions can be found here
Gemini-Wiki
Function Buttons:
* BLUE - Blue Panel (BP)
* BLUE long - Picture in Picture (DM7025, DM8000)
* 2x BLUE - BP -> Gemini Extras
* BLUE RED - File-Manager
* RED - Recording (not for DM8000)
* GREEN - Quickbutton / Subservices
* YELLOW - Timeshift (not for DM8000)
Extras:
* Addon and Plugin Server
* Cryptinfos of the channel or Cam, Stick Cam to certain channels
* Function for managing many daemons / server (BP -> Services/Daemons)
* optical enhancements like HD-skin, additional icons or modification of the channel list
* Manager for format, setup or mount devices (BP -> Device-manager)
* Additional EPG-functionality like Autosave, Refresh or different EPG-format view
* Particular addons like Dreamnetcast, Jukebox, Calendar, eMail or eTorrent, just to name some of them
* Quickbutton, to define functionality of the Green button via menun
* Detailled information about your Dreambox (Menu -> Information)
* File-Manager, which can handle different format-types, regardless whether it is a picture-, audio-, videoformat, playlists, torrent, scripts or DVD-files (BP -> File-Manager)
* complete handling of hard disks, DVD-drives, USB-Sticks changed to udev (system handels those devices by itself)
Information about many other functions can be found at the IhaD-Board or our Wiki.
New:
* Adaptions for 500HD
* Change to OE1.6, new kernel version
* FTP-Mounts - Mounts FTP-Servers as directories into the system (BP->Extras->FTP-Mount)
* new widget, animations (GIFs) in the skin
* ext2 or ext3 selectable if initialize
* The expert line in the infobar can be configured now
* Standby for USB-Harddisks (Attention: Doesn't work with all conrtolers)
* Device-Manager partially very strong revised
Fixes + Updates:
* Email-Checker fixed, can handle Googlemail accounts again, and no Enigma2 crash if no SSL-Connection can be done.
* The Stream-Traffic-Info should work better now on HD-Channels
* Selectable quickbuttonfunctions extended
* Weather
* see CVS
Important:
Attention on some harddisks the new kernel may cause problems.
* On the DM8000 from the beta-series, a security chip update will maybe make a second boot necessary.
This image doesn't contain any keys or softcams!
Backups or other modified images are not released by us
and won't be supported in any way!!!
Code:SSL75 : http://rapidshare.com/files/382703206/Gemini-5.0-OE1.6-dm800-SSL75_TS_TEST.rar SSL72 : http://rapidshare.com/files/382634420/Gemini-5.0-OE1.6-dm800-SSL72_TS.rar SSL70 : http://rapidshare.com/files/382636795/Gemini-5.0-OE1.6-dm800-SSL70_TS.rar SSL69 : http://rapidshare.com/files/382638988/Gemini-5.0-OE1.6-dm800-SSL69_TS.rar
Pe un site ( chinezesc ) se plingeau userii ca ar avea probleme cu tunerul pe aceasta imagine ! @Mihai daca ai asa ceva ?
Si eu am instalat-o dar mai ramän la Nabilo
Nu se initializeaza Hdd-ul si nici smargo
Cu tunerul nu am avut probleme pe 8 sateliti
Am sa ma mai joc cu ea
mfg
Nu am avut probleme cu tunnerul ! si merge in general foarte bine !
Chinezii au avut mult timp probleme pe clone ... acum ca s-a schimbat
kernelul era si de asteptat .... le rezolva baietii de la Nabilo...
eu sunt multumit de imagine...
hdd -ok...
tuner -ok....
nici o problema...zbarnaie
CCcam info v1.3c se gaseste in Blue-Panel ....Addons (Cam-Plugins)
La clonele cu sim 2.01 nu sut probleme le cele cu sim 2 sau 1 pot apare aceste probleme , imaginea a fost pache-uita pe 2.01
@gobi2000 nu cred ca merge inca pe clone.
Imaginea face upgrade la bootloader iar pe clone nu reuseste si face disable la tuner... cel putin asa am vazut pe forumuri.
Pe 8a8f8 se recomanda pentru clone cu SSL72 sa se foloseasca versiunea pentru SSL70. In felul asta nu mai da fail tunerul si nici alte surprize nu apar.
Si eu sunt multumit de imagine...
hdd -ok...
tuner -ok....
Imagine ok..
stabilitate ok
e inca sub atenta supraveghere...
Never settle for less than perfection. Never!
Respecte!
Deci....baietile,merge Gemini 5.0 pe DM 800 clone cu SIM 1,sau nu?
Daca da,care SSL sa-l folosesc,69,70 sau 72?
Si un link,de unde sa o iau,ca unde am gasit mi-a dat ca arhiva e defecta sau intr-un format necunoscut....?!
Mersi.
Bafta!
Respect!
am pus imaginea si nu reusesc sa pun drtic si asd le pun in tmp le dau install dar cand dau la plugin im scrie asa
extensions/drtic no module named plugin
extensions/asd no module named plugin
si nu imi apar la plugin
ma poate ajuta cineva
multumesc mult
shadowman @
Deocamdata nu, si iti recomand sa nu te grabesti nici cand apare pentru a nu avea surprize![]()
