Member
Visitor
- 0
newcs kamikaze 8.09 newcsgpio
Hi all
im use wrt54g v2.2
(phoenix connect is max232 gipo 7. i Don use usb reader)
BusyBox v1.11.2 (2009-12-28 12:50:09 CET) built-in shell (ash)
Enter 'help' for a list of built-in commands.
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
KAMIKAZE (bleeding edge, r18161) ------------------
* 10 oz Vodka Shake well with ice and strain
* 10 oz Triple sec mixture into 10 shot glasses.
* 10 oz lime juice Salute!
Newcs 1.66 + SB4Ls v03e03v03e03
root@OpenWrt:/etc/init.d# ./newcsgpio /dev/tts/1 7 &
root@OpenWrt:/etc/init.d# ./newcsgpio: can't resolve symbol '__uClibc_start_main
how to fix this???
ps. newcs_10.1.17_mipsel.ipk with kamikaze7.09 work perfect!!!
Member
Visitor
- 0
You will need new version of that newcs which is compiled against kamikaze uClibc. Also make shure you enabled FPU emulation if you compile you own image.
I have newcs 1.65 runing on backfire 10.03 (svn) withoud problem, newcs is runing just fine, and from your error msg, newcs cant be started at all.
Can you try "normal" newcs.openwrt file on your router and see if it is going to start at all..
