Dislikes: 0
'' In new versions of OSCAM is support of Smargo natively.
To use the Smargo natively you must use a particular protocol and a particular type of device configuration (file osacm.server)
items that vary over a typical configuration for reading slots are:
= internal protocol that must become SmartReader =
protocol = SmartReader
and device that has become = = internal BUS: ID that has our Smargo
device = 001:002
therefore the section for the reader Smargo will be something like:
[reader]
Label = smargoSkyIt
Protocol = SmartReader
Detect = CD
Device = 001:003
Fallback = 0
EMMCache = 1,3,2
BoxID = 12345678
Group = 1
CAID = 093B
the problem on our dream is to find that bus and that id has our Smargo seen that the dream is not expected utility lsusb
OSCAM developers have come to meet us and have developed a small utility that displays it is called there list_smargo and is installed with the package that I attach.
to install an FTP client should copy the package to / tmp
after that we should give the command from a Telnet
ipkg install / tmp/smargo-util_0.1-r0_mipsel.ipk
After that we could use the utility by simply typing list_smargo
Opendreambox 1.5.0 dm8000
dm8000 login: root
Password:
root @ dm8000: ~ # cd / tmp /
root @ dm8000: / tmp # ipkg install / tmp/smargo-util_0.1-r0_mipsel.ipk
Installing Smargo-util (0.1-r0) to root ...
Configuring Smargo-util
root @ dm8000: / tmp # list_smargo
Bus 001, device 005: 0403:6001 SmartReader
Nelle nuove versioni di oscam c'è il supporto dello smargo in maniera nativa.
Per poter usare lo smargo in maniera nativa bisogna usare un particolare protocollo e un particolare tipo di device nella configurazione (file osacm.server)
le voci che variano rispetto una classica configurazione per lettura da slot sono:
protocol che da = internal deve diventare = smartreader
protocol = smartreader
e device che da =internal deve diventare =BUS:ID che ha il nostro smargo
device = 001:002
perciò la sezione reader per lo smargo sarà qualcosa del tipo:
[reader]
Label = smargoSkyIt
Protocol = smartreader
Detect = CD
Device = 001:003
Fallback = 0
EMMCache = 1,3,2
BoxID = 12345678
Group = 1
CAID = 093B
il problema sui nostri dream è quello di scoprire che bus e che id ha il nostro smargo visto che sui dream non è previsto l'utility lsusb
gli sviluppatori di oscam ci sono venuti incontro è hanno sviluppato una piccola utility che ce lo visualizza si chiama list_smargo e si installa con il pacchetto che allego.
per installarla dovremmo copiare con un client FTP il pacchetto in /tmp
dopo di che da telnet dovremmo dare il comando
ipkg install /tmp/smargo-util_0.1-r0_mipsel.ipk
dopo di che potremmo usare l'utility semplicemente GOGUtando list_smargo
OpenDreambox 1.5.0 dm8000
dm8000 login: root
Password:
root@dm8000:~# cd /tmp/
root@dm8000:/tmp# ipkg install /tmp/smargo-util_0.1-r0_mipsel.ipk
Installing smargo-util (0.1-r0) to root...
Configuring smargo-util
root@dm8000:/tmp# list_smargo
bus 001, device 005 : 0403:6001 Smartreader
root@dm8000:/tmp# ''
download :
easysurf.ro_smargo-util_0.1-r0_mipsel.rar - 24.7 Kb
http://ca****aring.us/forum/oscam/15...html#post28481
