Results 1 to 15 of 17
Thread: UFS910 Enigma2 New Generation Image from PKT team
    Default UFS910 Enigma2 New Generation Image from PKT team
    Iata ca cei de la PKT au scos prima versiune din noua E2 , numita E2 New Generation :
    " Enigma2 OpenSource Project GIT Duckbox SH4-612 POINT mod SVN-414 New Generation Image
    Image is designed for installation on the flash drive or hard disk SATA
    Posted by sh4 Duckbox Team:
    - No sound bug is fixed in zap
    - Fixed "multi-click" button TXT Bug
    - Fix the config menu, teletext
    - Fix Teletext zoom modus
    - Fix HD DVB Subtitle Scale
    - Enable wireless lan support ufs910
    - Fix memory allocation al. Srt subtitle
    - Fix starting SubtitleThread
    - Fix epgcache GS
    - Fix for stopping a player eof
    - Ts optimize buffer boards for 7100
    - Fix ac3 audio tone
    - Fix crash witch mp3 playback
    Posted by POINT:
    - New default skin POINT Silver HD
    - Update to version 2010-03-31 enigmy2
    - Updated Polish translations
    - Update Picon
    - Update of channel list 10-04-2010
    - Amendment to mbox'a EmuCamInfo - full name of the provider
    - Update InfoCenter
    - New plugins: Dream Explorer 6.2, BPBrowser, AutoResolution
    - Disable Downmix AC3 - DD5.1 and DTS works correctly
    - A separate menu to download plugins from the server
    - New plugin: Dreambox Client 0.3.28 Supply Project - Special thanks to the author @ areq dvhk [plugin allows you to download subtitles Polish and automatic conversion to srt format. Subtitles for download by clicking TEXT prior selection of the corresponding movie in the browser DreamExplorer]
    - Many other modifications
    Important changes to the current image:
    - AC3 DD5.1 works correctly for all the Polish, Italian and Scandinavian HD channels
    - Working path DTS formats MKV, x264, etc.
    - Works DVB-Subtitle
    - Stable playback mkv and x264
    - Removed the problem of loss of sound
    - Stable work TimeShift"
    - http://www.megaupload.com/?d=VSI3TRZK
    04 Apr 2009
    cine are ocazia sa testeze ce se intampla daca intra la configurarea tunerului la advanced si apasa OK chiar daca nu modifica nimic acolo si indiferent de ce set de settings are puse. initial am crezut ca e doar la AAF treaba dar se pare ca imaginile din noua generatie vin cu niste probleme.
    21 Mar 2009
    @apoklyps3
    - chiar daca nu va merg mai multe dintre setarile din e2, probabil ca nu stii ca aceste variante se inbunatatesc permanent in urma sesizarilor primite de la utilizatori ca Dvs.
    - limbajul sau exprimarea Dvs cam lasa de dorit, va recomand sa recapitulati "cei 7 ani de acasa" si sa reveniti improspatat.
    04 Apr 2009
    n-am inteles nimic din ce-ai vrut sa zici , daca era un raspuns "mascat" la problema mea nu m-am prins.
    in fine,pentru cei care intampina problema mea , pentru ca vor mai fi, sa incerce sa seteze satelitii cand configureaza primii pasi la prima pornire. apoi va merge snur.
    Pai tu la primii pasi cand configurai imaginiile cand ajungeai la config. de satelitii , lasa-i cum venea imaginiile , adica cu diseq 1.1 ( doar 4 sateliti ) ?
    Total gresit , eu la toate cand ajungeam in acest stadiu , schimbam in "advance" si la toti satelitii din lista "originala" ( ca erau 3-4 sau 45 sau mai multi ) de obicei in plaja 45W - 45E ii puneam pe toti : Lnb1 ) si apoi continuam mai departe cu setariile
    Daca aveam doar 3-4 satelitii in lista originala , dupa config./restarturile necesare schimbam "satellite.xml" cu unul mai cuprinzator ( sau daca nu aveam de unde , cu setarile/fisierul lui EnF70 )
    04 Apr 2009
    Lasam nemodificat ca oricum urma sa schimb cu setul lui EnF, drept urmare si satelitii din lista aia. Nu avea rost sa-i mai invart, numai ca la asta n-a mai mers treaba. Oricum la mine asta a fost rezolvarea. Am pus doar unul de acolo la prima initiere si nu s-a mai suparat. Ai pus imaginea asta?
    03 Jun 2008
    E chiar o veste buna! In sfarsit ceva cu adevarat nou! Am incercat aceasta imagine si se misca foarte bine! Cred ca e E2 e reconstruita din nou.
    Astept o imagine "ZILDAN".
    04 Apr 2009
    poate sa-mi zica vreunul daca ii porneste emu automat la restart la imaginea asta? eu am fost nevoit sa pun mbox0.4b22 manual prin ftp deoarece nu este in panel. am modificat emu.conf din /var/config/ cu numele exact al mbox din /var/emu/ in spetza "mbox0.4b22" insa la restart nu porneste automat de si pe displayul lui kathy apare "starting mbox0.4b22". sunt nevoit sa-l pornesc de fiecare data din telnet.
    Exista vreo diferenta majora intre vers. care ai instalat-o tu si versiuniile mbox de pe serverul lor : 0.4b0015 si 0.6b0010 ?
    Nu crezi ca este mai usor si mai sigur sa descarci/instalezi unul dintre cele 2 vers. de pe serverul lor si apoi doar configurai fisierul xxx.conf
    Eu unul asa procedez cu incubus si nu am avut niciodata vreo prb. cu vreo imagine
    Nu te supara , dar parca prea te "scarpinii cu mana stanga la urechea dreapta" , iar apoi scrii ca ai diferite prb.
    04 Apr 2009
    exista...ca altfel nu ma chinuiam aiurea. 0015 e foarte vechi iar versiunea 6 nu e compatibila cu peer-i pe care ii am eu,cei mai multi cu gbox.
    nici tu nu te supara da mereu imi raspunzi cu o intrebare la o intrebare. aici mereu lumea e predispusa sa-ti dea in cap decat sa te ajute. eu vreau sa folosesc mbox0.4b22 cum tu vrei sa-ti iei nu stiu ce incubus de nu stiu unde. poate pentru alea luate direct din panel merge autostartul. eu am intrebat daca mai cienva in situatia mea si daca ma poate ajuta. nu e prima data cand intreb una si primesc raspuns cu alta. altu intr-o zi imi zicea sa-mi schimb recieverul cu unul pe care merge magnificul cccam, care ar fi a VIII-a minune a lumii. din cate stiu e forum de discutii asta, unde putem discuta liber despre probleme. daca nu tu n-ai avut problema mea, nu inseamna ca ea nu exista.
    RSP - TEAM
    03 May 2007
    Din pacate nu am cum sa iti dau un sfat in cunostiinta de cauza, pentru ca nu am imaginea in discutie instalata si nici conexiune la un mbox. Cred insa ca daca incerci sa instalezi de pe serverul lor, fie si o versiune mai veche de mbox, sa urmaresti unde si ce isi instaleaza, dupa care sa inlocuiesti executabilul cu versiunea de care ai nevoie, pastrind numele celui instalat via plugins, si in mod similar fisierele de configurare, ar trebui sa iti functioneze.
    O alta modalitate ar fi sa descifrezi cum isi scrie si unde linia de comanda emu ca sa il porneasca la restart sau revenire din stand-by. Un pic mai complicat, dar extrem de interesant si de educativ.
    ... Before asking what should RSP community do for you, try to find out what did you do for the others...be generous!
    04 Apr 2009
    se pare ca nu doar de emu.conf depinde treaba cu autostartul, asa ca am ales calea usoara. am dat un mbox mai vechi direct din panel l-am inlocuit cu mbox0.4b22 redenumit exact cum era cel vechi. nu-i frumos dar e sanatos.
    RSP - TEAM
    03 May 2007
    Cel mai important este sa iti poti rezolva problema, nu e concurs asa ca impresia artistica nu se puncteaza
    Desigur ca atunci cind nu vei mai fi "presat" si o sa vrei sa sti mai multe, ramine ca o optiune demna de luat in seama, analiza si descusutul, ca doar e hobby, nu?
    04 Apr 2009
    se pare ca trecerea in noua era a imaginilor enigma2 aduce suferinta playerului. nu ma intereseaza foarte mult acest aspect dar am obesrvat cat are probleme de redare a inregistrarilor HD 1080i si momentan lipseste functia Fast Forward. Sigur ca se vor rezolva in timp, dar momentan nu intelg de ce se numeste new generation,nu vad mai nimic schimbat.
    Era momentan dezactivata functia pe AVI. Apareau probleme de pierderi de memorie.
    La urmatoarele versiuni e rezolvata problema de NIT.
    Ii aducem multumiri si pe aceasta cale.
