- Rep Power
- 60
Eroare in mbox
Salut!
Am o problema si nu stiu cum sa ii dau de capat!A murit hdd-ul care avea pus sistemul (Windows 7 64 bits).Trimis la garantie , in fine
Am pus pe un alt hdd windows 7 64 bits , toate bune si frumoase dar cand ii dau drumul la gbox imi apare asta :
enx_conf = 3 ; reset on zap=1
Total 1 ports to monitor
monitoring port: 5566
CPU 80X86 compatible
ERROR: can not set ioperm: No such device
You must install ioperm -i to enable direct i/o access
TPSCrypt 1 PTS 1/1
mode: any pid
entering main loop
in mbox imi da aceasta eroare :
[19:28:00] Total 1 UDP port(s) to monitor
[19:28:00] Total 0 TCP port(s) to monitor
[19:28:00] Monitoring port(s): 5566
[19:28:00] Associating ports [8003-8019] to localhost ...OK
[19:28:00] Creating pmt receive thread for Windows or Linux...OK
[19:28:00] Creating ecm parser thread ...OK
[19:28:00] Creating timer thread ...OK
[19:28:00] Creating send thread ...OK
[19:28:00] Creating UDP receive thread ...OK
[19:28:00] [gbox]->Hello to peer ............
[19:28:00] [gbox]->Hello to peer .............
[19:28:00] [gbox]->Hello to peer...............
[19:28:00] COM1: open serial port
[19:28:00] COM1: init done
Are cineva vreo idee ce as putea face si cum?
Membru de onoare
- Rep Power
- 88
Verifica firewall si antivirusul.
