E clar solutia a venit oscam-newcs care acum citeste si cardul zomm
exista in shared si chiar fuctioneza perfect![]()
Din pacate cardul este expitat nu pot testa mai mult daca cineva are posibilitatea de a testa si sa puna un logoCode:[ 16:25:10 ] [ ECM Cache ] Initialising dynamic Cache [ NewCS ] Process ID is: 300 [ 16:25:10 ] [ Loader ] Starting Telnet on port 3001 [ 16:25:10 ] [ Loader ] Started HTTP-server on port: 3002 [ 16:25:10 ] [ Phoenix ] Opening device /dev/tts/0 [ 16:25:10 ] [ Phoenix ] Setting Parity to: ODD [ 16:25:10 ] [ Phoenix ] Setting 2 Stop bits on node /dev/tts/0 [ 16:25:10 ] [ Phoenix ] Setting Baud to standard 9600 [ 16:25:11 ] [ Phoenix ] Normal RESET on node /dev/tts/0 [ 16:25:13 ] [ ATR ] T=0 1etu=13.02us Guardtime:15etu WWT:76800etu [ 16:25:13 ] [ ATR ] Historical bytes: 3 [B0] [10] i [FF] J P p [00] [00] Z B [01] [00] [00] [ 16:25:13 ] [ Loader ] Init NDS card [ 16:25:13 ] [ Phoenix ] Setting Parity to: ODD [ 16:25:13 ] [ Phoenix ] Setting 2 Stop bits on node /dev/tts/0 [ 16:25:13 ] [ Phoenix ] Setting Baud to custom 76800 Get UA info [ 16:25:13 ] [ KeymaN ] Adding key 000000000146b1 type 0 on Provider 000000 for caid 0929 ID=0 [ 16:25:13 ] [ KeymaN ] Adding key 00000000014600 type 1 on Provider 000000 for caid 0929 ID=0 [ 16:25:14 ] [ Loader ] Card 0929 on port /dev/tts/0 ready [ 16:25:14 ] [ Loader ] Starting Newcamd Server on port 11000 [ 16:25:14 ] [ NewCS ] Ready to GO! :) [ 16:25:14 ] [ Newcamd ] Newcamd thread Server started on port 11000
Din cate stiu, s-a trimis un aparat "unde trebuie" acum 3 saptamani si raspunsul era asteptat.
Poate e coincidentza!
Si ce difera la configurarile de Oscam, fata de un card Dulce?
Frecventa de citire a cardului ?
Banuiesc ca trebuie folosit ultimul Oscam...
Cine are mai multe amanunte ?
Poate un config corect, sa nu ardem cardurile de Poom![]()
Libertatea vine din...cer !
Nu e chiar usor..dar e ok e la fel precum sky it se beleste repede cardul atentie!!
