Results 1 to 15 of 15
Thread: D*lce si oscam
    Default D*lce si oscam
    Decarcati oscam de pe server + config-ul
    apoi: var/tubox/config editati fisierele:
    -oscam.conf
    Code:
    [global]
    nice = -1
    WaitForCards = 1
    [monitor]
    port = 988
    aulow = 120
    monlevel = 0
    [newcamd]
    port = 22000@092f:000000
    -oscam.server
    Code:
    [reader]
    Label = Dolce (39E)
    Protocol = Intern
    Detect = CD
    Device = dev/sci0 #sau dev/tts0 ptr phonix
    group = 1
    #emmcache = 1,3,2
    #mhz = 525
    CAID = 092f
    BoxID = 123abc
    #savenano = all
    Customspeed = 0
    EMMCache = 1,3,2
    Fallback = 0
    -oscam.user
    Code:
    [account]
    user = user
    pwd = passwd
    group = 1
    uniq = 1
    caid = 092f
    ident = 092f:000000
    AU = Dolce (39E)
    monlevel = 0
    Copiati linia N in CCcam.cfg
    Code:
    N: 127.0.0.1 22000 user passwd 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256
    Member Addicted Member
    11 Feb 2007
    Șoseaua Kiseleff nr. 10
    Intrebare: daca dulcele merge bine direct in cccam, atunci de ce mai este nevoie de oscam?
    Adevarat dar eu vreau cadul direct si nu in hop1 in cazul meu avand 3 receptoare cu linie n ecm max 200 zic e mult mai rapid decat CCcam
    Standard RSP member potty's Avatar
    23 Dec 2008
    Default ...
    nu am reusit sa pornesc cardul cu aceste setari ..
    Super Member
    15 May 2007
    daca acum folosesc cccam 2.1.3, si cardul de dolce il citesc cu cccam-ul, dupa ce pun oscam, ce modificari trebuie facute in cccam.cfg?
    mai ramane acolo boxkey-ul?
    Standard RSP member JBTC's Avatar
    10 May 2007
    Ploiesti
    Adaugi linia N. poate sa ramana boxkey in cccam.cfg pt ca oricum reader-ul va fi oscam
    uite setarile mele:
    in ccam.cfg adaugi N (va fi in hop 0)
    Code:
    N: 127.0.0.1 50000 user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256
    sau C (va fi in hop1)
    Code:
    C: 127.0.0.1 12001 user pass no
    oscam.conf
    Code:
    [global]
    Nice = -1
    saveinithistory = 1
    LogFile = stdout
    logfile = /var/log/oscam.log
    usrfile = /var/log/oscamuser.log
    maxlogsize =10
    pidfile = /var/run/oscam.pid
    ClientTimeout = 5
    CacheDelay = 120
    [monitor]
    Port = 1000
    NoCrypt = 192.168.1.1-192.168.1.250
    AULow = 120
    MonLevel = 2
    [webif]
    httpport = 8888
    httpuser = userwebif
    httppwd = passwebif
    httprefresh = 10
    httpallowed = 1.0.0.1-254.254.254.254
    [newcamd]
    Key = 0102030405060708091011121314
    Port = 50000@092F:0000
    [cccam]
    port = 12001
    reshare = 2
    version = 2.1.3
    build = 213
    oscam.server
    Code:
    [reader]
    AU = 1
    Enable = 1
    label = Dolce (39E)
    Label = Slot0
    Protocol = internal
    detect = cd
    device = /dev/sci0
    mhz = 500
    Fallback = 0
    Group = 1
    CAID = 092f
    ident = 092f:000000
    boxid = XXXXXXXX
    EMMCache = 1,1,2
    pincode = 0000
    oscam.user
    Code:
    [account]
    User = user
    Pwd = pass
    monlevel = 1
    AU = 1
    Uniq = 1
    Group = 1
    MacMini Plex/Boxee, Dolce DTH, Dolce Interactiv, Focus DTH, Digi DTH
    Super Member
    15 May 2007
    OK, am reusit sa pornesc CCCam 2.1.3 si Oscam. problema e: nu imi mai apare cardul la Entitlements, apare doar
    127.0.0.1:50000 |00d 00:02:00|newcamd | | | 1 |remote 092f:000000 6(0)
    la sectiunea Servers.
    se pare ca nu decodeaza.
    aseara am mutat antena pe 39*est, si pentru mine (lolcal) decoda (doar cu cccam 2.1.3), in schimb, ecm-uri primite de la clienti nu decoda.
    macar stiu acum ca am boxkey-ul bun
    Ce sa-i fac ca sa decodeze si pt clienti?
    10 May 2007
    Ploiesti
    le dai linii N sau C dar trebuie sa-i adaugi in oscam.user
    ex
    oscam.user
    Code:
    [account]
    User = user
    Pwd = pass
    monlevel = 1
    AU = 1
    Uniq = 1
    Group = 1
    [account]
    User = user2
    Pwd = pass2
    monlevel = 0
    AU = 0
    Uniq = 1
    Group = 1
    entitlements iti apare in webif al oscam acum pt ca oscam este reader
    Super Member
    15 May 2007
    deci trebuie sa retrimit linii N la toata lumea? deci la fiecare peer sa am linie F in cccam.cfg si user+pass in oscam.user?
    eu tot cred ca nu decodeaza, la servers, la cccam webif apare: remote 092f:000000 95(0)
    numai un client se pare ca foloseste cardul acum, dar poate nu am eu pachetul activ pentru canalul la care priveste el. cred, sper
    nu gasesc fisierul de log. nu e in /var/log
    ---------- Post added at 13:47 ---------- Previous post was at 13:09 ----------
    asta e din log:
    >> OSCam << cardserver started at Thu Jun 10 13:31:19 2010
    2010/06/10 13:31:19 448 s version=0.99.4svn, build #2330, system=powerpc-tuxbox-linux, nice=-1
    2010/06/10 13:31:19 448 s max. clients=29, client max. idle=120 sec
    2010/06/10 13:31:19 448 s max. logsize=10 Kb
    2010/06/10 13:31:19 448 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
    2010/06/10 13:31:19 448 s shared memory initialized (size=492830, fd=5)
    2010/06/10 13:31:19 448 s anti cascading disabled
    2010/06/10 13:31:19 448 s dvbapi disabled
    imagini: http://img17.imageshack.us/gal.php?g=usersh.png
    Nu ai nevoie sa dai linie N ficcarui per din CCcam (desi atentie mare cu linile N!!)
    in oscam.config nu ai drirectionat bine fisierul log
    /var/tuxbox/config/ cred ca aici e celmai bine sa il pui
    Explicati legate de PM
    Gasiti aici
    Ori ce Linie N creata poate fii multiplicata! asta e atentia controlul il aveti un emulator
    灌水 expression's Avatar
    09 Oct 2008
    PL-RO
    Default AU
    In configuratia de mai sus oscam+CCcam se mai face AU la card?
    The quieter you become, the more you are able to hear...
    Super Member
    15 May 2007
    cum overclockez cardul in Oscam? schimb la oscam.server mhz=500 cu ce?
    nu merge cardul cum trebuie pentru clienti, adica din 250 de ecm-uri primite, doar 10 sunt rezolvate....si ma gandesc ca poate e frecventa la card prea mica.
    29 Nov 2008
    Cu capu' in nori
    Eu il am in cccam trecut la 600 si merge bine, incearca sa pui asa.
    Merge bine cu Mhz=657
    ---------- Post added at 10:26 ---------- Previous post was at 10:17 ----------
    [account]
    User = user
    Pwd = pass
    monlevel = 1
    AU = 1 acesta face au la userul respectiv
    Uniq = 1
    Group = 1
    [account]
    User = user2
    Pwd = pass2
    monlevel = 0
    AU = 0 dezactivat au ptr acest user
    Uniq = 1
    Group = 1
