Page 8 of 22 FirstFirst ... 45678910111218 ... LastLast
Results 106 to 120 of 327
Thread: KAON de la Focus
  1. #106
    07 Aug 2008
    Default Re: KAON de la Focus
    Salutare! Am si eu o rugaminte. Am un KSF100 cu hardware 12.c0.a5. Am incercat sa pun pe el R_BM-8300_STA2_HW-12.C0.A5_Fech-060321_SW-02.00.02_EMU-5.8.204_CA-2.2.8_WWW.SAT.US.PN si R_BM-8300_STA2_HW-12.C0.A5_Fech-080222_SW-02.00.02_EMU-5.8.197_CA-2.2.9_WWW.SAT.US.PN, numai ca la ambele se termina cu fail si kup 230 zice ceva de genul:
    [ Upgrade mode. ]
    File open error, please open file first!
    Engineer Mode
    UPGRADE TOOL (V2.30) 22-MAR-2004 Patch
    File open O.K.!
    > Old version binary.
    -. Target loader version :L 619
    -----------> Front :: 74HC164 used (connector: 14pin)
    -----------> Target 2M Flash.
    -----------> Target AMD/ST FLASH(TOP).
    Connect Success
    // FileInfo: BM-8300 STA2, H/W(12.C0.A5), S/W(02.00.02)
    // Target: L 619, u-C[0] , FLS[2M], KSF-100SCO, H/W(12.C0.A5), S/W(03.00.20)
    Target Model Mismatch : KSF-100SCO
    03.00.20: Software Version is High
    -. STB Model : BM-8300 STA2
    -. STB H/W Ver : 12.C0.A5
    -. STB S/W Ver : 03.00.20
    DownLoad Start
    Pe ecran apare fereastra neagra de download dar bara nu se misca si peste cateva secunde pe displayul rec-ului apare fail.
    Am incercat sa schimb si bootloaderul cu BL219v4 dar, la fel, apare fereastra cu downloading... si apoi fail.
    Aveti ceva idei despre cum pot sa scriu softul?
  2. #107
    Standard RSP member edisitaru's Avatar
    09 Aug 2007
    Giurgiu, Romania
    Foloseste softul asta http://rapidshare.com/files/13546457...ed_es.exe.html ca sa incarci flash-ul in receptor. Nu uita sa apesi tasta SPACE!! Asa am patit si eu si era de la program...
  3. #108
    17 Jul 2008
    In Tara
    [QUOTE=mrblue;46434]Salutare! Am si eu o rugaminte. Am un KSF100 cu hardware 12.c0.a5. Am incercat sa pun pe el R_BM-8300_STA2_HW-12.C0.A5_Fech-060321_SW-02.00.02_EMU-5.8.204_CA-2.2.8_WWW.SAT.US.PN si R_BM-8300_STA2_HW-12.C0.A5_Fech-080222_SW-02.00.02_EMU-5.8.197_CA-2.2.9_WWW.SAT.US.PN, numai ca la ambele se termina cu fail si kup 230 zice ceva de genul:
    daca nici asa nu-ti merge incearca sa pui [kaon-team hw.ff.oc.ff-emu 5.8.194 sw.03.00.00]tot dupa sat.us.pn,seria c.. dupa care pui soft-ul pa care vrei tu ,dar nu uita inainte sa-l incarci apasa tasta[space]asta trebue sa mearga..succes
  4. #109
    07 Aug 2008
    Quote Originally Posted by edisitaru View Post
    Exact acelasi kup l-am folosit. De apasat space, am apasat. Am procedat asa:
    cu rec-ul in standby am pus cablul in mufa, am deschis kup 230, am apasat space pentru a intra in engineering mode, am ales softul si am pornit rec-ul de la buton.
    Nu este de la kup cred, pentru ca nici boot-loaderul care este in format executabil nu vrea sa se incarce. Se blocheaza tot la download.
    Quote Originally Posted by felix73 View Post
    daca nici asa nu-ti merge incearca sa pui kaon-team hw.ff.oc.ff-emu 5.8.194 sw.03.00.00 tot dupa sat.us.pn,seria c.. dupa care pui soft-ul pa care vrei tu ,dar nu uita inainte sa-l incarci apasa tasta space asta trebue sa mearga..succes
    Imi trebuie soft pentru 12.c0.a5, ce zici tu parca e firmware universal si am inteles ca nu merge pe kaon-ul de la focus.
  5. #110
    17 Jul 2008
    In Tara
    Quote Originally Posted by mrblue View Post
    cum adica in standby?nu l-ai scos din priza? scoate-l din priza ,deschide kup,apasa space ,incarca soft-ul in kup,dupa care il bagi din nou in priza. trebue sa mearga
  6. #111
    Merge si cu power on / off din telecomanda , @mrblue verifica cablul null-modem , daca si acesta e in regula sa nu fie vreo problema de la portul serial al calculatorului ; incearca cu altul .
  7. #112
    07 Aug 2008
    Am rezolvat problema cu alt calculator. De pe primul calculator nu vroia niciun soft sa se incarce desi portul era ok, cablul ok. Am instalat firmware pentru 12.c0.a5 de pe sat.us.pn versiunea cu emu 204 si 197 si la amndoua aparea halt pe dsiplay si se bloca la cautare. Apoi am instalat KaonTeam_SerieC_v194_Esp care se pare ca este soft universal. Totul ok, scaneaza super repede, se pot adauga key cu kke sau din meniu si in plus ma si ajuta sa instalez antena pe un satelit sau altul indicandu-mi puterea semnalului.
    Nu prea imi dau seama de ce softurile instalate prima oara imi blocau receptorul. Cine mai intampina problema cu halt la ksf-100, sa instaleze KaonTeam_SerieC_v194_Esp.
    mrblue is online now Add to mrblue's Reputation Edit/Delete Message
  8. #113
    17 Jul 2008
    In Tara
    asta este cel mai bun soft pentru kaon de la f...s ,eu a-m patit ca tine de nustiu cite ori din cauza softurilor de la turci[fail,restart intr-una],in schimb cu kaonteam seria c functiona perfect din prima...........bine ca ai reusit
  9. #114
    07 Aug 2008
    Am citit pe undeva ca softul pentru AT-7010DCIZ-HW-12.01.A5 de la http://www.sat-television.com/showfile.php?id=147040 ar permite subtitrari dvb deci s-ar vedea si subtitrarile pentru jiji. L-a incercat cineva? Merge si pe 12.c0.a5?
  10. #115
    Standard RSP member gessle's Avatar
    tg ocna;jud. BACAU
    L-am incercat si nik!Ori se restarteaza ,ori afiseaza 8.88,ori scrie halt!
    Traiasca bl 219v4,altfel era pus la garbage!
    .de
  11. #116
    Poti "forta nota" , dar in cazul in care reusesti sa incarci respectivul fisier in receptor , sub nicio forma nu ai sa reusesti sa-i dai "unlock channel" din meniu , deci fara EMU ...
  12. #117
    tg ocna;jud. BACAU
    O data mi-a mers,dar afisa satelitii,dar canalele =0
    Asta a fost incercat pe Kaon 100 focus .
    .de
  13. #118
    Si oare chiar nu o sa apara un soft care sa aiba si subtitle?
    Trecut la Sfinti
  14. #119
    07 Aug 2008
    Si asta e valabil pentru toate softurile de sunny? La nici unul nu se poate da unlock channel pe 12.c0.a5?
  15. #120
    17 Jul 2008
    In Tara
    poate sa-i reuseasca din prima sau nu .unlock channel numai cu 6.1.9.v3 bin.sat.us.pn.eu am avut 1 an si ceva sunny 12.c1.a5pa 12.c0.a5 de la focus,dar nu puteam da channel unlock fara boot-6.1.9.v3.daca totusi forteaza va putea da unlock channel,dar subtitlu la 1w tot nu osa aiba scuzati-mi indrazneala
