Results 31 to 45 of 54
Thread: Astra 3B - 23.5 E ... pe orbita!
    21 Apr 2007
    Here
    Respecte!
    Daca dau baietii o bere le dau voie sa-l lanseze dela mine din gradina.
    Pozitionare pe orbita 100%.
    Le pun la dispozitie vreo 4,5 butelii rusesti.Pe gratis numai sa-l lanseze odata.
    Bafta!
    Respect!
    01 Mar 2008
    No Man's Land
    Mail-ul primit de la Arienespace
    Arianespace Flight - ASTRA 3B & COMSATBw-2
    Monday, April 12, 2010 6:46 PM
    "Arianespace Launch Update" <video@arianespace.com>
    Add sender to Contacts
    To:XXXXXXXXXXX
    ASTRA 3B & COMSATBw-2 – Flight 194
    Arianespace sets up a Task Force and conducts a Quality Audit
    Following the technical difficulties occurring during preparations for Flight 194, Arianespace, in conjunction with its partners in the Ariane 5 program, has decided to set up a Task Force and conduct a Quality Audit.
    · The Task Force was formed to understand and correct the anomaly occurring during the countdown on Friday, April 9, which led to the postponement of Flight 194; this Task Force has been asked to submit an initial report on Friday, April 16.
    · The Quality Audit is designed to analyze the underlying reasons for the technical difficulties that occurred, and to propose corrective measures. The initial conclusions of this Audit will be presented before Flight 194.
    These two initiatives will be conducted concurrently and independently of each other. They will enable Arianespace to set a new date for Flight 194 as soon as possible, and to consolidate the manifest for the following launches.
    Traducere libera:audit pt. investigarea defectiuni(lor)..
    25 Sep 2009
    Maramures
    Talking
    Chiar asa de marea e setea la Oradia? Asta e daca v-o trebuit Lotus si ati daramat fabrica de bere
    @dic_star79
    ai perfecta dreptate.Baikonurul nici nu se compara cu Kourou .De la Baikonur o lansat si Vostok-ul ce l-o dus pe Gagarin in spatiu acum fix 49 de ani!Rachetele Ariane 5 sunt destul de nereusite .Probabil se bazeaza pe faptul ca la finele lui oct 2009 satelitul militar german COMSATBw-1 a fost lansat cu succes tot cu Ariane, insa nemtii risca enorm!Valoarea satelitului militar e de cel putin 5 ori mai mare decat a unuia comercial (Astra 3B de ex)Nu inteleg totusi de ce nu se lucreaza cu racheta ruseasca Soyuz ST1 , caci sunt 20 de bucati la Kourou, evident cea mai buna racheta , invidiata chiar si de americani!!
    02 May 2007
    +44° 20' 60.00", +26° 0' 90.00"
    de ce nu se lucreaza cu soyuz ?
    lucrarile la complexul de lansare nu au fost finalizate (oct 2010 prima lansare soyuz de la kouru) soyuz are dimensiuni diferite de cele ale ariane5 si nu pot folosi acelasi launchpad.
    sa nu uitam totusi ca este vorba de costuri foarte mari ( vorbim de 2 sateliti lansati simultan) si din acest motiv siguranta maxima determina precautii maxime.
    aceste intarzieri de lansare ale zborului v194 cu arabsat 3b au decalat urmatorul zbor care mai mult ca sigur va fi si el intarziat:
    6 May - Arabsat 5A & COMS 1 - Ariane 5 ECA (V195)
    02 May 2007
    noua data de lansare 21-22 mai , sau inceputul lui iunie -datorita schimbari piesei actuale la fluxul de oxigen cu o alta inca nefabricata
    15 Feb 2007
    Sa vedem daca se lasa cu buseala s au nu....ramane de vazut...
    Golden Member mar1us's Avatar
    09 May 2009
    dublin
    15 Feb 2007
    Gata, lansarea a reusit....il avem in ceruri...
    21 Apr 2007
    Here
    Respecte!
    Da,da,dar mai trebuie sa si functioneze.Sa speram ca totul v-a fi ok!
    Bafta!
    Respect!
    15 Feb 2007
    Sper sa functioneze......
    18 Nov 2008
    Dreamland
    Of am pierdut lansarea Nu stiu de ce traiam cu impresia ca-i in noaptea asta A inregistrat cineva tot showul?
    15 Feb 2007
    Daca dai clik pe linkul postat de mar1us ai lansarea ....
    01 Mar 2008
    No Man's Land
    25 Sep 2009
    Maramures
    4crizatu
    problemo ie ca tot shoul dureaza vreo 47 de minute iar pe youtube de exemplu nu lasa mai mult de 10 min sa urci!
    Concluzii:
    Cea ce arata pe net e vax albina
    , n-am acum timp sa urc totu pe aplaudu lu peste .iera chiar interesant ca la fine vorbeste Kaiser primele lui cuvinte fiind fara sonor (vreo 40 secunde), cel mai probabil spunand lucruri nu prea placute de Ariane , apoi a vorbit cu seful armatei djermane , hehe
    15 Feb 2007
    Astra 3B se misca si deja mai are putin si ajunge la destinatie, acum conform celor de la flysat este la 31E si mai are cateva grade pana ajunge la destinatie si incep testele, ramane sa vedem daca o sa schimbe ceva in bine!
