ce e curios sunt urmatoarele: absolut toate canalele celelalte (transponderele) intra oki si ma refere atat de pe Thor cat si de pe ceialati sateliti;
dar asta nu intra de cateva zile si pace; ...
am setat corect LNB High/Low pe 10600/9750 cum zice producatorul si tot e oki mai putina acest transponder... deci nu cred ca e de regalje nu? si e putin inclinat
mai jos lnb-ul meu (e adevarat nu mai pot seta FEC la el de cand cu noul soft)
ce idei ar mai fii?
Invavom TWF-031
Universal Duel LNB 0.3dB C120 flange
This unit is Ideal for a replacement On the older Primestar Dishes that use a C120 flange or any other commercial dishes
A high performance universal LNB with 2 output, for dishes supplied with their own feed-horn.
Typically used with motorized & fixed dishes, or where the signal strength is poor.
Input Frequency:
10.7 ~ 12.75 GHz
Output Frequency:
950 ~ 2150 MHz
Noise Figure:
0.3 dB typical
Gain:
50 ~ 60dB
Interface:
C120 flange, 18.5 Ø
Ideal Dish F/D:
N/A
ALL Invacom LNB/Fs are universal which means you need to set your receiver LO for "Universal". Universals have 2 LO frequencies, 9.75 and 10.6 GHz. Normally entered as "09750" and "10600" in most receivers. If you don't know how to set your LO frequencies consult your receivers manual.
