Results 1 to 15 of 15
Thread: incubus 97
    22 May 2009
    cluj napoca
    Default incubus 97
    a aparut incubus 97
    wambertos
    Guest
    Buna stire,dar...unde a aparut?
    01 Nov 2008
    rsp kathy team menu
    03 Feb 2008
    http://www.sateliti.info/showthread....890#post115890 numai ca la mine pe sifteam dgs pe ipbox nu deschide sky it,imi arata la ecm info 'decode emu' sau asa ceva ,desi am in serverul cccam in dist 1 ,celelalte merg la fel ca inainte zic eu.
    wambertos
    Guest
    History:
    06/02/2010, V0.97
    - now you can use more than one chid in provider chid section (see config file for more info)
    - improved some log errors
    - added some stability fixes
    Download
    30 Dec 2008
    France
    I load incubus97 from your server and I tested with same files as incubus96 ,prio ,conf....
    Kathy_RSP:~# /var/emu/incubus97 /var/keys/incubusCamd.conf
    Using config file: /var/keys/incubusCamd.conf
    Segmentation fault
    Kathy_RSP:~#
    ps : incubus96 is okay
    what's my mistake ?
    Flash : AAF2.e
    USB Stick with BA : RSP ( pkt ou AAF) with OSCAM
    5?W_13?E_19?E_28?E
    Remove from menu and downlad again.
    RSP Enigma Team
    28 Aug 2009
    Departe
    OK, ma dau cu capul de pereti, ca nu gasesti nicaieri clar informatiile astea:
    1. Cum faci sa fie folosit SoftCam.Key? Ca doar are linie in fisierul de configuratie, dar incubus il ignora cu succes.
    2. Unde gasesc niste informatii despre incubus.prio, gen sintaxa, la ce se foloseste etc.? (Si care spune "Google" il rog sa-mi si dea un query care ii da rezultate relevante).
    In meniu la imaginile RSP ai la installer un script care ia khey si le converteste in format convenabil.
    Pentru prio te uiti in exemplul din kitul de incubus.
    RSP Enigma Team
    28 Aug 2009
    Departe
    RSP Menu > Installer > Download SoftCam.... ? Da, l-am descarcat, nu merge. Mai trebuie setat ceva? Descarcat alt fisier? Un cleste mai mare pentru extras informatii?
    Cat despre .prio, reformulez intrebarea: un ghid pe care sa-l inteleaga si muritorii de rand, care sa explice ce anume face fisierul etc.?
    RSP Enigma Team
    28 Aug 2009
    Departe
    Am mai gasit ceva informatii despre cum ar trebui folosit SoftCam.k_y din Incubus, dar tot nu am reusit sa-l fac sa mearga. In .conf am adaugat, inainte de [Prov:000000:CaID:0000]:
    [Prov:002111:CaID:1801]
    check_priority=emu,emu,emu
    decoder_type=0
    [Prov:002011:CaID:1801]
    decoder_type=0
    In SoftCam.... (descarcat de pe Net, merge OK in mgcamd) am pentru jiji:
    N 2111 00 88ED.............................
    N 2011 01 21BB.............................
    N 2111 01 21BB.............................
    N 2011 00 88ED.............................
    Imi poate spune cineva ce gresesc sau ce trebuie sa mai adaug? Multumesc.
    Nu merge n2 cu k_y folosite in europa. A fost implementat pentru Nord America emulatorul cu k_y.
    In ultimul timp nu prea mai reuseam sa deschid TVR HD cu incubus.
    Am mai citit si am facut diverse experimente.
    Cu urmatoarele linii in prio imi merge din cardurile de max:
    P:0500:000000:000f:0500,0500:000000:000f:0020,0500:000000:000f:0021 # TVR HD (16E)
    P:0500:000000:0001:0500,0500:000000:0001:0020,0500:000000:0001:0021 # TVR 1 (16E)
    P:0500:000000:0002:0022,0500:000000:0002:0023,0500:000000:0002:0024 # TVR 2 (16E)
    I:0500:000000:000f:0020 #TVR HD
    I:0500:000000:000f:0021 #TVR HD
    01 Sep 2008
    pt. cardul de TVRHD cei care au in dist 1 cu urmatoarele setari merge brici
    in incubusCamd.conf
    #TVR_HD
    [Prov:000000:CaID:0500]
    check_priority=cs,cs,cs
    cs_protocol_order=cccam
    max_check_uphops=1
    inainte de "[Prov:000000:CaID:0000]"
    in incubusCamd.prio
    #TVRHD (16E)
    P:0500:000000:000F:0021,0500:000000:000F:0020,0500:000000:000F:0500
    I:0500:000000:000F:0020
    I:0500:000000:000F:0500
    multam la Zil pt. ajutor
    Am facut update la SkI lT cu lina newcamd din Oscam pusa in Incubus97.
    Un singur EMM a dat dupa catva ore si a facut update la toate pachetele!
