Results 1 to 15 of 15
Thread: incubus 97
    22 May 2009
    cluj napoca
    Default incubus 97
    a aparut incubus 97
    wambertos
    Guest
    Buna stire,dar...unde a aparut?
    01 Nov 2008
    rsp kathy team menu
    02 Feb 2008
    http://www.sateliti.info/showthread....890#post115890 numai ca la mine pe sifteam dgs pe ipbox nu deschide sky it,imi arata la ecm info 'decode emu' sau asa ceva ,desi am in serverul cccam in dist 1 ,celelalte merg la fel ca inainte zic eu.
    wambertos
    Guest
    History:
    06/02/2010, V0.97
    - now you can use more than one chid in provider chid section (see config file for more info)
    - improved some log errors
    - added some stability fixes
    Download
    30 Dec 2008
    France
    I load incubus97 from your server and I tested with same files as incubus96 ,prio ,conf....
    Kathy_RSP:~# /var/emu/incubus97 /var/keys/incubusCamd.conf
    Using config file: /var/keys/incubusCamd.conf
    Segmentation fault
    Kathy_RSP:~#
    ps : incubus96 is okay
    what's my mistake ?
    Flash : AAF2.e
    USB Stick with BA : RSP ( pkt ou AAF) with OSCAM
    5?W_13?E_19?E_28?E
    Remove from menu and downlad again.
    RSP Enigma Team
    28 Aug 2009
    Departe
    OK, ma dau cu capul de pereti, ca nu gasesti nicaieri clar informatiile astea:
    1. Cum faci sa fie folosit SoftCam.Key? Ca doar are linie in fisierul de configuratie, dar incubus il ignora cu succes.
    2. Unde gasesc niste informatii despre incubus.prio, gen sintaxa, la ce se foloseste etc.? (Si care spune "Google" il rog sa-mi si dea un query care ii da rezultate relevante).
