Results 1 to 3 of 3
Thread: Primul test cu SIF E2 085
    21 Post(s)
    Default Primul test cu SIF E2 085
    Asa cum v-am obisnuit ...am facut un prim test cu noua versiune E2 SIF 085 FLASH ... versiune pe care drept sa va spun am asteptat-o mai ales dupa anuntul tentant de la vers 080 ! Versiunea merge bine ! poate cel mai bine dintre toate versiunile de pana acum !
    Tot conform obisnuitei ...am instalat panelul RSP ... instalat de mana ! ( inca astept .ipk promis de mesterul @zildan ! ) ... mi-am pus un EMU ... evident MgCamd si am trecut la teste ...emulare perfect ! sharing ...mai bun decat incubus ! deocamdata incantat ...aud ca trucul implementat de @zildan acum aproape 6 luni ... truc care elimina "zgomotul alb" este insfarsit implementat si de Tideglo ... vizionare placuta ~!
    Noutatile versiunii !
    release 0.8.5
    - fixed AC3 audio dropouts over SPDIF with downmix set to off on few HD channels (report if the bug still there on some channels)
    - fixed the enable/disable 12v option in advanced enigma2 menu configuration
    - fixed a high cpu usage bug on enigma2
    - fixed pgup and pgdown buttons, now they are mapped to be used for channel changing
    - added possibility to change bootlogo on flash images
    - fixed a bug on few receivers that on 0.8.0 made them not working
    - fixed a stability bug on all receivers
    - fixed bug on the second tuner for scrambled channels
    - added NTSC, 480i and 480p video modes support (i don't know if it works or not, i can't test it)
    To people having problem with date/time:
    since version 0.8.0 date/time is managed on the same way used on DGS firmwares, so if you at first are having a bad value
    for date/time, just go into telnet console and type the command: date -s YYYY.MM.DD-hh:mm:ss
    Replace YYYY with the year, MM with month, DD with day, hh with hour, mm with minute, ss with seconds.
    After this type: cubefpctl --syncfptime
    Now set your GMT offset on enigma2 configuration menu.
    WARNING: using PIP with the second tuner on scrambled channel could make the tuner stops to work,
    a full box restart is needed to make it working again.
    I will try to fix this on next versions.
    P.S. Celebrul ecran plin de pixeli colorati ... este la locul lui !!! a aparut dupa cam o ora ... dar recpetorul nu s-a
    mai blocat ...am schimbat canalul si a fost OK !
    22 Sep 2007
    Default panelul RSP
    as dori va rog un link cu panelul rsp pentru imaginea sif e2 085
    10 Feb 2008
    Smile
    uite aici RSP Panel http://www.sateliti.info/showpost.ph...72&postcount=3 extras de mihaip
    Uacing setalait televijan uitaut sabscripsan iz iligal !!!
