Results 1 to 6 of 6
Thread: Enigma2 for DM500
    13 Feb 2007
    Earth
    Post Enigma2 for DM500
    Enigma2 for DM500
    Enigma2 port for DM500. Consists of the linux root filesystem,
    the kernel image can be either used from the flash or loaded using TFTP/BOOTP.
    Extract the contents of the package to an exported directory (e.g. "/tftpboot/dm500-e2") on the NFS server PC.
    Boot your dreambox with a serial connection (115200, 8, n, 1) to a PC enabled.
    Hit backspace at the bootloader's "PPC load"-prompt and proceed with one of the following setups.
    Simple setup kernel init parameters, only NFS export /tftpboot on server 192.168.0.1:
    ip=192.168.0.2:192.168.0.1:192.168.0.100:255.255.255.0::ff root=/dev/nfs rw nfsroot=192.168.0.1:/tftpboot/dm500-e2,v3,nolock console=ttyS0,115200 quiet
    Advanced setup kernel init parameters, with DHCP + BOOTP server:
    root=/dev/nfs rw ip=dhcp console=ttyS0,115200 quiet
    Thanks suomipoeka
    download :
    http://rapidshare.de/files/48993921/...00114.tgz.html
    sursa : http://www.sat-universe.com/showthread.php?t=155132
    Sa luleze de pe server ntfs?
    18 Feb 2009
    langa craiova
    pls mai multe detalii pt rularea pt xp
    43 Post(s)
    Cum e?Merge?As vrea sa o incerc dar am unele dubii (19,1 MB).
    Quote Originally Posted by savin stelian View Post
    @mondo va fii bootabil din serverul nfs idee proasta daca ai un pc conectat daca ai un ruter sau chiar pc care merge non-stop atunci e ok
    23 Jul 2007
    Talking
    merge. boot din retea. sunt probleme cu telecomanda. tastele sunt amestecate... rau da tot
    mai mult nu am putut sa incerc...
