Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
Thread: RSP beta01 TDT1967 Neutrino ufs910
    Default RSP beta01 TDT1967 Neutrino ufs910
    Usb image
    RSP Neutrino panel V1 (Menu > Script)
    Ecm Icons
    Enf70 settings
    Emu Download: press Ok and wait ..... and all emu is downloaded, repeat Ok and download all emuconfig
    Emu Select: switch emu cyclical (next Ok next Emu)
    Emu Start / restart: restart emu or start selected emu (by Emu Select)
    Emu List: list installed emu
    REBOOT: restart Kathy
    For E2 RC k_ey style:
    Download k_eys.zip, unzip, copy in /var/tuxbox/config or other folder and go to menu Load K_eis from.
    Attached Files Attached Files
    22 Dec 2008
    thanks for this image
    can u post some screens?
    rotor is working? and incubus?
    thanks for answer
    Neutrino USALS (gotoXX)
    Incubus works fine.
    22 Dec 2008
    thanks zildan.
    i will install it after work.
    i dont understand one thing.
    i see diferent versions of neutrino, some are tdt and some are GIT.
    can u explain me in short what are diferences
    thank you
    16 Feb 2009
    Default neutrino
    gran imagen que me solventa el problema de las pixelaciones en hd.
    muchas gracias al equipo rsp
    09 Jan 2010
    Problems with itvHD (28e)
    Longitude and lattiutde settings becomes corrupted.
    Cannot exit from EPG.
    Cannot scan single transponder, only whole satellite.
    Go to X working most of the time, mgcamd working fine.
    Cannot mount sda4 for recording.
    Good first beta image
    30 Dec 2008
    France
    Hi
    I tested this firmware with a lot of pleasure thanks
    the file k_eys.zip is very useful.
    Could you help me to manage a parabol with 4 heads with a diseqc 1.0 ?
    mulţumesc foarte mult
    Flash : AAF2.e
    USB Stick with BA : RSP ( pkt ou AAF) with OSCAM
    5?W_13?E_19?E_28?E
    22 May 2009
    cluj napoca
    eu nu am gasit folderul tuxbox in var
    e posibil sa fi instalat ceva resit? sau tre sal fac eu
    iar la unsals o ia antena razna
    trbuie setat un punct de reper sau asa ceva pt antene mea era pe 1w si setasem motorul tot pe 1w. in momentul in care iam dat sat find trebuia sa ramna pe loc da ...poate cineva care a reusit pm sa pot discuta de amanunte .
    Standard RSP member cristilamb's Avatar
    04 Feb 2008
    Ca prima impresie:
    -high SR cu merge chiar daca pui in rcs high sr=1
    -newcs nu porneste :
    ufs910:/# /var/emu/newcs -c /var/keys/newcs.xml
    /var/emu/newcs: error while loading shared libraries: libcrypto.so.0: cannot op
    n shared object file: No such file or directory
    ufs910:/#
    -pe NDS frameaza la prov. autohton cu mbox din dist.1 la 120-180ms time ECM
    mai butonam
    @alexsan78
    il faci directorul, sau pui in alt firector si te duci cu browserul cand incarci setarile de RC.
    Vezi ca sageata dreapta face un fel de cd .. daca stii ce e aia.
    @cristilamb
    Sunt transformari in module si e posibil sa nu mearga HighSR curand.
    Nu mai am module pentru adaptorul serial, se pare ca cele puse in imagine nu se incarca.
    CIFS nu merge pentru ca nu avem modul pentru noul kernel.
    @EDW
    Motor-Settings Latitude is set default South
    Install new k_eys-map (file is attached at first post)
    Manual frecvency scanSCAN!
    next step in my study
    @papi8
    They are mostly similar, GIT is public project bassed on TDT.
    23 Mar 2009
    Thx for fantastic img RSP Team
    Very stable , mgcamd run fantastic with multiple cws , incubus same problem like with E2
    With advanced setings mine 8 LNB's work perfect
    Fast channel switching also
    THX
    23 Mar 2009
    There is no /var/tuxbox/config, just /var/config/ ???
    09 Jan 2010
    Default Ftp
    I am using KCC v3.2, when I FTP to edit file there is error message
    '530 please login with user and pass'.
    User name 'root'
    pass 'kathrein'
    is this correct?
    Password not needed
