Page 5 of 14 FirstFirst 123456789 ... LastLast
Results 61 to 75 of 210
Thread: Sbox - New cardserver/emu
  1. #61
    29 Nov 2008
    Cu capu' in nori
    New SBox 0.0.4-e #2
    ____
    | _ \
    ___| |_) | _____ __
    / __| _ < / _ \ \/ /
    \__ \ |_) | (_) > <
    |___/____/ \___/_/\_\ (emu/cardserver for PowerPC, MIPS, X86, SH4 & Freetz)
    What's new? 0.0.4-e #2
    -Fixed portlist bug
    What's new? 0.0.4-e
    -More changes related with nagra cards
    +Added channelinfo support (see sbox.conf for details)
  2. #62
    29 Nov 2008
    Cu capu' in nori
    New SBox 0.0.4-f
    ____
    | _ \
    ___| |_) | _____ __
    \__ \ |_) | (_) > <
    What's new? 0.0.4-f
    -Fixed some bugs
    +Added cccam cardserver support, emm support only for local cards (very very experimental) (see sbox.conf and users.sbox for details)
  3. #63
    29 Nov 2008
    Cu capu' in nori
    New SBox 0.0.5-0
    | _ \
    ___| |_) | _____ __
    \__ \ |_) | (_) > <
    What's new? 0.0.5-0
    -Fixes on cccam protocol (server/client)
    +Added betatunnel support (see sbox.conf for details)
    +More options for newcamd clients (see users.sbox)
    What's new? 0.0.5-0 #2
    -Como la lío
    Attached Files Attached Files
  4. #64
    29 Nov 2008
    Cu capu' in nori
    SBox 0.0.5-0 #3
    | _ \
    ___| |_) | _____ __
    \__ \ |_) | (_) > <
    What's new? 0.0.5-0 #3
  5. #65
    29 Nov 2008
    Cu capu' in nori
    New SBox 0.0.5-0 #4
         ____
        |  _ \
     ___| |_) | _____  __
    \__ \ |_) | (_) >  <
    What's new? 0.0.5-0 #4
    +Added cache for virtual cccam cards
    +Removed downhop limitation between SBox clients <-> servers (only work on local mode)
    +Now, if you connect to a local newcamd server, card will appears as hop0
  6. #66
    29 Nov 2008
    Cu capu' in nori
    New SBox 0.0.5-1
         ____
        |  _ \
     ___| |_) | _____  __
    \__ \ |_) | (_) >  <
    What's new? 0.0.5-1
    -Some fixes
    -Changes on dvbapi
    +Now can send messages through webinterface between SBox clients <-> servers using cccam protocol
    +Full emm support on cccam server
  7. #67
    Daca ii merge cuiva ca si client cccam stabil sa ridice doua degete si sa spuna versiunea sbox,receptorul folosit,etc.Sunt binevenite si testele pe partea de server cccam,dar sa fie facute pe o perioada de minim cateva ore.
  8. #68
    Standard RSP member silvica's Avatar
    06 Jul 2009
    SBox 0.0.5-0 #3 + DM800 + card jiji
    Din pacate ultimele 2 versiuni au un minus pe partea de stabilitate CCcam,in rest sunt ok
  9. #69
    VIP
    23 Sep 2008
    au rezolvat cu versiunea 5-1
    se mai lucreaza la el.
    mie imi merge stabil pe ipbox9000 sbox.sh4.
    am renuntat la oscam client cccam!
  10. #70
    23 Apr 2007
    P3X-888
    incercai si eu sa-l pornesc pe Alien dar nu vrea ... apare la procese dar nu deschide nimic si nici nu se conecteaza la webinterface .
  11. #71
    29 Nov 2008
    Cu capu' in nori
    SBox 0.0.5-1 #2
         ____
        |  _ \
     ___| |_) | _____  __
    \__ \ |_) | (_) >  <
    What's new? 0.0.5-1 #2
    -Some fixes on webif and others
  12. #72
    29 Mar 2009
    Austria - TM
    Default SBox 0.0.5-1 #3 Public
    | _ \
    ___| |_) | _____ __
    \__ \ |_) | (_) > <
    What's new? 0.0.5-1 #3
    -Contigo si contigo no
    DOWNLOAD
  13. #73
    Member
    21 Nov 2009
    Default problema sbox
    am un card digi care imi merge in dm500 cu cccam_sbox.pana acum ceva timp aveam o problema cu receptorul care se bloca si trebuia scos cablul de curent pentru a pleca.cu ajutorul lui zmeura am reusit sa scap de acest blocaj.acum mai nou am o alta problema si este si mai sacaitoare . de cateva ori pe zi se blocheaza imagine pe programul care merge din local.pleaca doar daca ii dau restart camd.cccamul functioneaza pentru ca programele din share imi merg.imaginea pe dm este gemini 4.6.orice sfat e binevenit.multumesc mult.
  14. #74
    Si pana la urma ce card servar folosesti ? Sbox ??
    Member
    21 Nov 2009
    sbox folosesc
Tags for this Thread
