Page 4 of 14 FirstFirst 12345678 ... LastLast
Results 46 to 60 of 210
Thread: Sbox - New cardserver/emu
  1. #46
    14 Oct 2008
    Close to you...
    Default DA
    Merge binisor ultimul sbox, mult mai stabil ca si versiunea anterioara. Are ecm cu 15ms mai mare ca si oscamul dar este okay.
    Note: Viewing Pay TV without a valid subscription is illegal!
  2. #47
    Pacat ca nu stie pcsc...
    Sbox la 2Mhz,card rom142:
    Version: 0.0.4-8, compiled 16/12/2010 #2
    Using /var/bin/sbox.conf as config.
    SBox uptime 00d 17:38:35
    ECM Req ...ECM Resp ...Hits %
    ...7909..........7909.......100
    Resets
    ...0
    09:59:26 newcamd 15000: ecm cccam [1802:000000:055A] [81308F078D54D6227139...] ok (342ms)
    09:59:32 newcamd 15000: ecm cccam [1802:000000:055A] [80308F078D8C0B21AF00...] ok (353ms)
    09:59:42 newcamd 15000: ecm cccam [1802:000000:055A] [81308F078DE4BA2C53C0...] ok (342ms)
    09:59:52 newcamd 15000: ecm cccam [1802:000000:055A] [80308F078DB52D25DE52...] ok (343ms)
    10:00:02 newcamd 15000: ecm cccam [1802:000000:055A] [81308F078D2B1529803F...] ok (342ms)
    10:00:12 newcamd 15000: ecm cccam [1802:000000:055A] [80308F078D434B247015...] ok (342ms)
    10:00:22 newcamd 15000: ecm cccam [1802:000000:055A] [81308F078D901D2BA1AC...] ok (343ms)
    10:00:32 newcamd 15000: ecm cccam [1802:000000:055A] [80308F078D9DF52F479D...] ok (343ms)
    10:00:42 newcamd 15000: ecm cccam [1802:000000:055A] [81308F078D7BAF207B19...] ok (342ms)
    10:00:52 newcamd 15000: ecm cccam [1802:000000:055A] [80308F078D9D3023E238...] ok (343ms)
    10:01:02 newcamd 15000: ecm cccam [1802:000000:055A] [81308F078D90232BE994...] ok (343ms)
    10:01:12 newcamd 15000: ecm cccam [1802:000000:055A] [80308F078DD10526C861...] ok (344ms)
    10:01:22 newcamd 15000: ecm cccam [1802:000000:055A] [81308F078D19D32A9F16...] ok (342ms)
    10:01:32 newcamd 15000: ecm cccam [1802:000000:055A] [80308F078D53082ABB65...] ok (343ms)
    10:01:42 newcamd 15000: ecm cccam [1802:000000:055A] [81308F078DAC6A234A51...] ok (343ms)
    Vreau sa spun ca nu sunt deloc curios de ecm time,scopul meu e sa ia de pe localul meu 100% ca sa nu trag de cardurile altora.
    Merge cccam de pe local perfect,nu l-am vazut sa mai ceara de pe cardurile din share nici macar odata.Am considerat ca 17 ore sunt suficiente pentru a da rezultatul testului,la 3;3,57;3,68;4;.... Mhz cccam sarea cu cererile in share deja.
  4. #49
    Standard RSP member suporter's Avatar
    29 Jul 2009
    Ca sa inlocuiesc versiunea 0.0.4-7 cu 0.0.4-8 cum fac?
  5. #50
    Cred ca merge la fel si cu 0.0.4-7,doar sa setezi cardul la 2 Mhz.Posibil totusi sa difere situatia de la un receptor la altul,tine de cardreader.
    Ca sa treci la 0.0.4-8 trebuie facute unele modificari in sbox.conf (neimportante,poate doar adaugarea user/parola pentru webif e singura importanta) si mai ales in users.sbox unde s-a schimbat modul de setare al liniilor (client sau server).
    sbox.conf
    [main]
    server_only=1                # 0=emu+newcamd server 1=only newcamd server
    log=1                    # 0=no log 1=log to /tmp/sbox.log    //ALWAYS USE 0//
    logudp=192.26.0.1:3354            # server ip:server port
    userspath=/var/bin/users.sbox        # users list
    webinterface=1                # 1=web interface on 0=web interface off
    webadmin=user:parola           # user:pass for webinterface
    webport=8888                # web interface port
    rdgserver=0                # 0=radegast server off 1=radegast server on
    rdgport=7000                # radegast server port
    use_nagra=0                # 1=use as nagra card 0=use as irdeto card (only for nagra over irdeto cards)
    [slot0]
    active=1                # 0=inactive 1=active
    sci=/dev/sci0                # lower
    ncdserver=1                # 0=newcamd server off 1=newcamd server on
    deskey=0102030405060708091011121314    # newcamd deskey
    port=17000                # newcamd port
    mhz=200                    # Mhz for card in this reader, DON'T WORK ON PHOENIX INTERFACE. Example: mhz=357, mhz=368
    reader=1                # 0=phoenix, 1=sci (internal reader), 2=smartreader
    cache=10                # how many ecms can be cached, 0 or less=cache disabled
    #Nagra2/3 Example
    [XXXXXXXX]                # nagra2 camid (4 bytes)
    rsa=xxxxxxxx                    # rsa "n" from this card (like newcs)
    boxkey=xxxxxxxx            # boxkey from this card
    emm=0                    # 0=accept all 1=block emms 2=block emmu 4=block emmg
    portlist=1                # use portlist or no
    portlistpath=/var/keys/port.list    # path from port.list
    Vedeti de port si user/parola pentru webinterface.Intotdeauna testati mai intai doar cu sbox,puneti mai sus server_only=0 si trebuie sa mearga de pe card fara cccam pornit sau daca e setat un script pentru sbox/cccam deja nu e problema ca oricum nu va mai porni cccam daca sbox e pus primul.
    users.sbox:
    #Example configuration file for sbox cardclient server
    #NC=dummy dummy slot0 0
    # |    |    |     |   |________________ 0=au disabled for this user 1=au enabled for this user
    # |    |    |     |____________________ server to which this user belongs
    # |    |    |__________________________ password for this user
    # |    |_______________________________ username
    # |____________________________________ newcamd client
    NC=user parola slot0 0
    #NC=edk2 edk2 slot1 0
    #RS=ip port caid provider
    # | |   |     |     |__________________ provider
    # | |   |     |________________________ caid
    # | |   |______________________________ server port
    # | |__________________________________ server ip
    # |____________________________________ radegast server
    #RS=127.0.0.1 16050 1800 000000
    #NS=ip port user pass deskey au
    # | |   |    |    |     |     |________ enable send emms, 0=send all 1=dont send emm-s 2=dont send emm-u 4=dont send emm-g
    # | |   |    |    |     |______________ deskey
    # | |   |    |    |____________________ password
    # | |   |    |_________________________ user
    # |____________________________________ newcamd server
    #NS=127.0.0.1 15000 cccam dummy 0102030405060708091011121314 0
    Am lasat tot ce era ca explicatie (oricum sunt ignorate acele linii cu #) dar daca ai numai linia pentru client scrisa cu rosu e suficient.
    Port.list se pune dupa ce totul functioneaza,pentru a opri cererile ecm care nu pot fi deschise de card.
  6. #51
    Folositi log=0 .M-am trezit dupa cateva zile ca logul meu avea 1,4 Mb si probabil pe un receptor cu flash mai mic crapa deja.Am uitat de el si acum vad ca asa am postat si in config.
  7. #52
    Standard RSP member dodo13's Avatar
    19 Nov 2009
    Default CUM SE POATE FACE RESHARE LINI N in sbox?
    Am cccam 2.0.11+sbox 4.4.8-2 si nu reusesc sa fac reshare la linile N tot in N pentru un Opticum 7100 cxe care stie numai de newcamd. am reusit numai cardul local dar in slot 1 nu vrea deloc. serverul raspunde la ping si atat. Ma intereseaza pentru ca am lini n de la sky it, nova, polsat, Tivusat, digialb, max....etc. Linile se conecteaza independent direct pe serverul de origine Opticumul le deschide dar asa nu le mai deschide Ipboxul............ M-ar interesa sa stiu cum se fac lini N cu carduri multiple. In sbox.conf am activat slotul 1 si iam alocat un port.........degeaba nu vrea.
    Asta este sbox.conf
    [main]
    server_only=0 # 0=emu+newcamd server 1=only newcamd server
    log=0 # 1=no log 1=log to /tmp/sbox.log //ALWAYS USE 0//
    #logudp=192.26.1.100:11000 # server ip:server port
    webadmin=root:root # userass for webinterface
    webport=14001 # web interface port
    rdgport=12002 # radegast server port
    [slot0]
    port=34000 # newcamd port
    #mhz=357 # Mhz for card in this reader, DON'T WORK ON PHOENIX INTERFACE. Example: mhz=357, mhz=368
    cache=0 # how many ecms can be cached, 0 or less=cache disabled
    [slot1]
    sci=/dev/sci1 # upper
    #Conax Example
    [571A491C] # conax camid (4 bytes)
    #portlist=0 # use portlist or no
    #portlistpath= # path from port.list
    Nu pot sa-mi dau seama unde nu este ok...............daca stie cineva......HELP
  8. #53
    In sbox nu poti face linii N "fake" sau altfel spus "reshare" la linii N.Incearca oscam.
  9. #54
    29 Nov 2008
    Cu capu' in nori
    | _ \
    ___| |_) | _____ __
    / __| _ < / _ \ \/ /
    \__ \ |_) | (_) > <
    |___/____/ \___/_/\_\ (emu/cardserver for PowerPC, MIPS, X86, SH4 & Freetz)
    What's New? 0.0.4-b
    -Removed gbox support
    -Removed cccam support
    +Some fixes on conax smartcards
  10. #55
    29 Nov 2008
    Cu capu' in nori
    ____
    | _ \
    ___| |_) | _____ __
    \__ \ |_) | (_) > <
    What's New? 0.0.4-c
    -Fixed some bugs found in the latest version
    -Updated gcc compiler (e1/e2)
    !This version are not fully tested
  11. #56
    11 Jun 2011
    Default public?
    exista si versiunea private?
  12. #57
    Public inseamna ca au publicat o anumita versiune,nu ca ar tine altele private ascunse.Cand modifica ceva testeaza acele modificari in cerc restrans ca sa nu se trezeasca ca ii injura lumea cand modificarile aduse nu sunt functionale sau afecteaza altceva in emu.Daca totul e in regula poate il publica sau poate mai asteapta pana cand mai aduc alte modificari,la randul lor testate in cerc restrans.
  13. #58
    29 Nov 2008
    Cu capu' in nori
    | _ \
    ___| |_) | _____ __
    \__ \ |_) | (_) > <
    What's New? 0.0.4-d
    -Fixed bug when parsing pmt
    -Changes on nagra io funcs (once again)
    +CCcam cardclient support it's active again, no emm/server support atm (see users.sbox for details)
  14. #59
    Cu linii cccam moare dupa un timp.Mai au de lucru la el.
  15. #60
    29 Nov 2008
    Cu capu' in nori
    New SBox 0.0.4-d #2
    | _ \
    ___| |_) | _____ __
    \__ \ |_) | (_) > <
    What's new? 0.0.4-d #2
    -Some related changes with nagra cards (experimental)
Tags for this Thread
