Thanks Thanks:  14
Likes Likes:  17
Page 14 of 14 FirstFirst ... 41011121314
Results 196 to 210 of 210
Thread: Sbox - New cardserver/emu
  1. #196
    10 Post(s)
    cardul 1802 pus in oscam la mhz pus 600 si card mhz la 369 arata asa
    (1802&000000/0000/03F5/92:326B6EFB1ACE8252B004E76B7D0CF1AA): found (274 ms) by jijica
    (1802&000000/0000/0DDE/92:59C1A4476D22968DA96DF86163F97E77): found (268 ms) by jijica
    (1802&000000/0000/0400/92:314EB6CDD6F528677BB2F8A591900932): found (267 ms) by jijica
    (1802&000000/0000/1770/92:0FEC01CEA340DF1D23777FF8AC39A531): cache1 (1 ms) by jijica
    (1802&002011/0000/1770/92:0FEC01CEA340DF1D23777FF8AC39A531): found (265 ms) by jijica
  2. #197
    Membru de onoare
    08 Apr 2007
    Eu stiu,doar ca mie imi da rateuri in DM600 si numai asa merge stabil.
    Oscam imi face asa http://sateliti.info/showthread.php?...473#post223473
  3. #198
    11 Apr 2008
    Fost mebru
    SBox 0.0.5-4 #0 tests
    - Changes in dvbapi (try cutting those of you in the picture)
    - Small changes in newcamd module
    Download : http://d-h.st/mfH
  4. #199
    11 Apr 2008
    Fost mebru
    După cateva zile de teste, (deocamdată) am 100% uptime cu SBox 0.0.5-4 #0 tests
  5. #200
    18 May 2013
    Asa este , SBox 0.0.5-4 #0 merge foarte bine , testat cu card digi 1880 si card focus sat , uptime 100%
  6. #201
    15 Apr 2008
    Default Sbox/cccam card Digi 1880
    Salut,
    Cine ma ajuta cu un config pt cardul de mai sus.
    Debian, Sbox/cccam instalat.(cititor easymouse)
    Pana acum am mers pe OScam si ma gandeam sa testez.
    Multumesc anticipat.
  7. #202
    08 Oct 2009
    Am instalat si eu SBox 0.0.5-4 #5 tests, merge ok, timp mai bun comparativ cu oscam, dar nu primesc EMM deloc. in webif apare ON si la user si la card.
    newcamd e oprit, si ma conectez prin cccam de pe un diablo wifi cu underworld 2.28, unde sa fie problema? face AU doar singur, prin dvbapi?
  8. #203
    15 Feb 2007
    De aproape doua saptamani a aparut SBox 0.0.5-4 #6 , functioneaza ok si mult mai stabila decat versiunea anterioara.
  9. #204
    SBox 0.0.5-4 #6
    -Fixed portlist, and works again
    -Fixed bug with viaccess cards and readers phoenix / smargo / pcsc
    -Fixed bug in priority
    -New parameters for viaccess cards (see sbox.conf for more info)
    "Partial"-Support in NA nagra cards used (must specify mode = 3)
    -Improved compatibility with smargo readers V2, you may now fail the V1 ... (reportad fault if you have one)
  10. #205
    Super Member
    07 Feb 2007
    Stimati colegi,
    Imi poate spune cineva daca cardul TVR (Freesat) merge in combinatia sbox+cccam ?
    Daca da ma poate ajuta cineva sa fac configuratia ?
    Multumesc
  11. #206
    cardul TVR (Freesat) via caid 0500 nu deschide in 3C. Doar trece prin 3C si lumineaza la cine are un emu (oscam) care stie sa deschida.
    Deci, daca il pui in sbox (desi mai bine ramane in 3C) si dai linie in 3C, tu nu vezi din el.
  12. #207
    Super Member
    07 Feb 2007
    Caid 0B02 are cardul meu si e conax.
    Am vorbit cu cineva care are card de Focus si mi-a zis ca merge bine.
    Eu am momentan oscam, dar tot am atacuri, incearca sa se conecteze , probabil fosti parteneri la serverul meu.
  13. #208
    Versiunile vechi contineau si fisier info referitor la cardurile si reader-ele suportate, de ceva timp "e pe testate". Am facut si asta dar nu am gasit ce am nevoie: varianta care sa suporte card conax si Phoenix serial reader; receptorul este DM500. Foloseste cineva o varianta cu aceste cerinte?
  14. #209
    "Pe testate": SBox v 0.0.5-4 #7, DM500, card 0B02 in cititorul receptorului, card 1802 in Phoenix serial (Max232 + 74HC00). Nu ma asteptam, azi a facut update cardul conax.
  15. #210
    20 Apr 2009
    Arges
    27 Post(s)
    Sbox e un proiect mort ? Ar fi nevoie de o versiune pentru procesoare arm ( vu+ 4k , dreambox 4k ).
Tags for this Thread
