Nu mai pune adrese in clar. La fel cu fisierele!
Poate un moderator sa stearga!
Dislikes: 0
stiu ca s-a discutat mult pe tema asta dar am o problema in configurare mbox+newcs pt un card tvr hd, folosesc un ipbox 910hd pe care am instalat e2 pkt 7.5, problema e urmatarea nu reusesc sa leg mbox +newcs desi setarile sunt bune, in newcs imi arata caid 0000, o sa pun si poze si fisierele de con fig poate ma ajuta cineva sa rezolv acest
ar aici aveti atasate fisierele www.unlocktricks.com/fisiere.rar
ipbox 910hd / h-h opticum dm 3800/ e2 pkt
pai cum sa le pun? ca nu inteleg
Last edited by zmeura; 03-01-10 at 12:38. Reason: Regula 12.Quote inutil la post consecutiv.
Editeaza in fisiere adresele.
Ceva de genul xxx.dyndns.org sau cum vrei tu.
La imagini sterge prima parte si box id-ul prin editare in paint.
Altfel o sa ai intruderi.
<?xml version="1.0"?>
For setup-issues, look in readme.txt!
If there are other troubles, try different forums or irc channels around)
<newCSconfig>
<globals>
<listening-ip>127.0.0.1</listening-ip>
</globals>
<readers name="Card Readers">
<device>
<name>lower</name>
<type>sci</type>
<node>/dev/sci0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>yes</export>
<enabled>yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<!-- <boxkey>0000000000</boxkey> -->
<crypto-special>no</crypto-special>
<carddetect>no</carddetect>
<newcamd_port>32100</newcamd_port>
<priority>round</priority>
<sid>
<allow>
<!-- valid value for id are:
4 numbers, if the service id is 3 numbers, add a 0 infront of it. -->
<id></id>
</allow>
<deny>
<id></id>
</deny>
</sid>
</device>
</readers>
<radegastserver>
<!-- valid value for enable are:
0,1 - Enable or Disable radegast server. -->
<enabled>no</enabled>
<!-- valid value for port are:
0,65535 - Which port to listen for incomming connections. -->
<port>10001</port>
<!-- valid value for allow are:
ALL - Not active yet. -->
<allow>
<hostname>127.0.0.1</hostname>
</allow>
</radegastserver>
<cache>
<emm>10</emm>
<ecm>10</ecm>
</cache>
<debug>
<level>verbose</level>
<type>init</type>
<output>all</output>
<logfile>/tmp/newcs.txt</logfile>
<console_options></console_options>
<file_options></file_options>
<udp_host>192.168.1.10</udp_host>
<udp_port>1000</udp_port>
<udp_options></udp_options>
<tcp_port>3001</tcp_port>
<tcp_options></tcp_options>
</debug>
<newcamdserver>
<name>bla</name>
<userfile>/tmp/users.txt</userfile>
<user>
<name>dummy</name>
<password>dummy</password>
<au>on</au>
<allow>lower</allow> <!--Use this just when you want give free just some readers to your Users -->
<allow>upper</allow> <!--Use this just when you want give free just some readers to your Users -->
</user>
<user>
<name>dummy</name>
<au>on</au>
</user>
</newcamdserver>
<httpd>
<server> <!-- Port to accept connections on -->
<port>8080</port>
</server>
<user>
<!-- valid value for userfile are:
Any username you'd like - Used for browser to logon (its case sensitive). -->
<name>newcs</name>
<!-- valid value for password are:
Any password you'd like - Used for browser to logon (its case sensitive). -->
<password>newcs</password>
<!-- valid value for accesslevel are:
admin, stats - Define what rights the user has in the web-console -->
<accesslevel>admin</accesslevel>
</user>
</httpd>
</newCSconfig>
Incerca newcs de mai sus.
in cwshare linia este
C: { 127.0.0.1 32100 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 } { 10 } { 05005900:05025900 }
Voi ati incercat vreodata sa si intelegeti parametrii din newcs.xml, sau ii puneti doar asa cum ii gasiti pe net .... ?
Daca s-ar citi ce inseamna fiecare parametru ( pentru asta e readme si newcs.xml.excemple) din newcs.xml nu ar mia aparea nici o problema indiferent de cardurile folosite.
Si asa sa va dau singurele ponturi necesare pentur acest card:- ptshandake trebuie sa fie YES pentru cardurile viaccess din care face parte si tvr;
- radegast poate disparea din schema daca nu e folosit;
- autosid sa fie pus no si bagate apoi manual sidurile pentur cele 3 canale tvr : 0000:0002 si 000F.
@livs sunt curios cate bad ecm-uri si reset-uri iti da newcs folosind acel config care e cam varza.
am pus ptshandake yes dar celelalte nu le gasesc poti sa-mi explici mai in detaliu?
pai ce e gresit la mine? ca nu inteleg, tu ai pus doar alt user si pass sin cate am vazut eu, explica-mi si mie
Last edited by zmeura; 03-01-10 at 12:39. Reason: Regula 12.Foloseste butonul new reply.
chiar nu vede nimeni daca am gresit sau nu, sau nu s-a mai intalnit cu pr asta?
deja s-a inchis proiectu mbox si eu nici macar nu am reusit sa-l folosesc![]()
Din cate am vazut ai asta in port.list G: { 05025900 },sterge asta si o sa mearga.Liniile G din port list sunt pentru ignorare de provideri si ce ai pus tu ignora tocmai providerul bun.
am rezolvat problema, aveam 2 pini la cititor de la cartela in scurt, defect de fabric, acum merge
