Results 1 to 12 of 12
Thread: Vdr 1853 Bootable for UFS-910
    Default Vdr 1853 Bootable for UFS-910
    All python drausssen (E2) is.
    boot independently.
    remote.conf is empty RC wizzard so you can come and are pleased to demonstrate to your RC.
    diseqc is off and can be activated in the menu.
    ne diseqc.conf is in there with A and B astra hotbird
    actual sender list hb + astra in there
    720p will be recruited via rcS. who need the scart to 576ip50 change it!:
    720p50 echo> / proc / stb / video / video mode
    bugs:
    vol + - functionless
    poweroff does not work.
    visual schonmal goes wech but usually comes back.
    The fun here will boot from five Sunter 30 seconds! fromusb or later flash even faster!
    the img must be as pure as regards testimg halt very buggy.
    but at least it runs on ufs!
    bootargs are the same for nfs or usb boot as for E2!!
    - http://www.megaupload.com/?d=33FYU8IZ
    26 Dec 2008
    Dublin, IRL
    poti te rog da sursa de unde ai dat paste, inainte de traducere? nu inteleg mai nimic din traducerea asta...
    multumesc
    26 Dec 2008
    Dublin, IRL
    e VDR sau Enigma2?
    E VDR, se instaleaza in partitie si merge pe boxul de 1W.
    Pe cel de 14W nu merge telecomanda.
    Da , am testat si eu acest vdr, e foarte "sumar"
    Personal imi placea mai mult daca prg. erau sortate dupa satelitii si nu dupa tematica , fiindca nu le stiu pe toate pe din afara pe ce satelitii sant
    A si nu am vazut/gasit nimic despre media player/multimedia , poate fiind la inceputuri cu acest "tip" de imaginii
    Zidan aceasta era "surpriza" despre care vroiai sa ne spui mai asta-vara ?
    Este o varianta de luat in calcul pt. cei care se rezuma doar la receptie/sharing
    26 Dec 2008
    Dublin, IRL
    fiind prima aparitie nu stiu la ce te asteptai
    nu e vorba de aia, kathrein este un receiver de satelit, hai sa nu facem din el si robot de bucatarie
    DA! este ceea la ce ma asteptam si de la Enigma2 sa fie. nu media player, ci in primul rand un receiver de satelit stabil. din pacate TDT in ultimul timp lucrau la media player in loc sa lucreze la partea de receiver, vezi dm800 unde patrea de receiver este super stabila (dar nu-l ajuta hardware din pacate) si partea de media player e pe locul 3
    Pareriile sant impartite , cele scrise de mine sant prime impresii legate de acest tip de imagine si nu le consider reprosuri
    Am scris pt. a citi si alti useri si a vedea despre ce este vorba , fiind o noutate in "peisaj"
    In alta ordine si "robotul de bucatarie" iti este util in anumite situatii , atata timp cat stii ca se poate
    Daca stiam ca nu poate imi cumparam un receiver non-linux si nu aveam oaresice pretentii la el ( nu cred ca ai cumparat dm 800hd numai pt. receptia satelitara )
    03 Jun 2008
    Nu se pote face nimic pt. rec. de 14w sa functioneze telecomanda?
    26 Dec 2008
    Dublin, IRL
    sunt de conceptia ca nu iti iei ceva care le face pe toate si niciuna calumea...
    pai no linux, no share, acum depinde ce doresti. eu sper totusi ca nu ti-ai luat receiver de satelit special pentru media center
    nu am, si nu voi lua niciodata
    03 Jun 2008
    Din pacate nu pot sa folosesc vdr pt. ca am katy 14 w.Deocamdata.....
    Sa inteleg ca se poate pune CCcam( nu sunt interesat, doar experimental...)? Sau se pot folosi multitudinea de plug-inuri:http://www.vdr-wiki.de/wiki/index.php/Plugins ETC...?
    Oricum e o treba buna!
    Sa vedem si neutrino!
    26 Dec 2008
    Dublin, IRL
    din pacate CCCam nu, pentru ca tot nu e compilat pentru sh4
