Sunt tare curios care sunt rezultatele celor discutate pe mess![]()
salutare..sa incep cu inceputul,am achizitionat de 2 zile un laptop SONY VAYO MODEL :PCG-3192 (nu are CD-rom) doar memory stick si win 98 instalat.deci ori ce as face imi trebuie driveri si ptr mem. stick si ptr a foloso usb de la Cable data modem.deci INTREBAREA e : se poate construi un Convertor USB - LAN ? daca da care se fac legaturile intre usb si lan care e ordinea?fa functiona fara driver acest convertor? thk
am cumparat un USB2.0 card bus dar nu am reusit sa-l fac sa mearga cu win98se...asa ca am formatat HDD si acum caut o solutie ptr a instala Windows Tiny (super super lite).acum vin cu urmatoarea intrebare:se poate face boot de pe memory stick? uitati cite ceva din specificatiile "TinyXP"
Windows XP Pro SP2 Unattended (UK Version)
Thank you for installing this stripped out (103Mb)
Edition of XP. I clocked mine in Task Manager
using only 39.5Mb of RAM. Windows XP usually uses
300Mb of RAM at the very least. This "TinyXP" takes
up only 400Mb total space on your system hard drive.
http://thepiratebay.org/tor/3410229/...d_(103Mb_ISO)_[eXPerience]
By using only 40Mb of RAM, this allows
your PC to run fast, I mean VERY fast!
