Page 2 of 8 FirstFirst 123456 ... LastLast
Results 16 to 30 of 107
Thread: RSP E2 Sfinx Edition E2 RSPv3.98 TDT VER1749
    22 Dec 2008
    Dear Zildan, very good work,
    Is possible compile the crongEpg pluging for epg-week of D+ spanish?
    In the web the autor of CongEpg, have the source code for this, D+ is MediaHigthWay (MHW).
    He say that in he source code have all for prepare this pluging for MHW (D+ spanish) and for a E2 katy.
    Is posible?
    Very good pluging your Watch emu...
    Thank your and Regards
    04 Apr 2009
    @ Dreanew
    Thankyou for the Info !
    I reinstalled now the Sfinx image and now i have it running since yesterday
    wout "Massive" Freezers, Interruptions yes, but no complete freezers.
    I managed to make a complete recording too.
    @Zildan
    Yes, this Image is MUCH more sstable that all othes B4!
    Thankyou ZILDAN 4 that !
    Cheers,
    Konstantin
    20 Dec 2009
    Hi,
    thx for the good image,
    but i have one question:
    How I can use my old channel-list (bouqeut-lists)?
    I tried to copy the List with Dreamboxedit 3.0.0 and mit Satchanneleditor 3.8 but it dosent work in this image.
    I tried to copy the list form the AAF IndianSummer V2 Image ...
    Can plz someone tell me how I can use my Channel-Lists in this image?
    Thanks a lot
    Settings path:
    /usr/local/share/enigma2/
    satellites.xml path:
    /etc/tuxbox/
    26 Dec 2008
    Dublin, IRL
    Or set enigma2v4 in Dreamset, it is the same as dm800 /etc/enigma2 (thhis being a link to /usr/local/share/enigma2) for bouchets and /etc/tuxbox for satellites.xml.
    22 May 2009
    cluj napoca
    credeti ca sar putea rezolva intro imagine viitoare timer recording din stand by ?
    O sa studiem problema, in mod normal ar trebui sa iese din standby si sa inregistreze.
    22 May 2009
    cluj napoca
    din pacate nici una din imagini nu o face nici ptk nici AAF
    Default Mai pot spune multumesc ?
    Suntem niste fericiti ai soartei , posesorii de KATHY ...de ce ?
    Pt. ca , printre noi exista acesti oameni deosebiti , ce se plaseaza deasupra tuturor prin dotarile cu , care au fost inzestrati de natura....Nu vreau sa parafrazez , dar pot spune : " JOS PALARIA " FRATE ZILDAN ...ai facut din kakao bici...si mai si pocneste ...dar nu oricum ...FELICITARI SI SARBATORI FERICITE INTREGII ECHIPE RSP ...mentionez special pe ENF70 , untip deosebit...LA MULTI ANI SI SARBATORI FERICITE !
    03 Jun 2008
    Intradevar jos palaria! Ca de obicei o imagine peste restul! Zapping supe rapid, super stabilitate! Cu noile driver video, eu zic, ca se vede cum trebuie!
    21 Mar 2009
    Exclamation Probleme ?
    - am observat ca la aceasta noua imagine, foarte multe canale, aleator, nu mai au sonor cand se schimba programul ?
    - este normal ca pe 1w pe gigi cu mgcamd softcam si autoroll bine puse imaginea sa faca patratele pe majoritatea canalelor si sonorul sa aiba o crestere/descrestere aleatoare insotita de un pacanit ?
    - La Multi Ani echipei RSP !
    Ai tu probleme cu antena.
    vodafonul
    Guest
    Default Felicitari maestre
    Felicitari maestrului Z
    Acum merge si reglajul fin al motorului antenei.
    Din pacate e o problema la media player ...sper sa se rezolve.
    RSP Enigma Team
    28 Aug 2009
    Departe
    Problema cu disparitia aleatoare a sonorului am remarcat-o si eu. Daca schimb canalul inainte/inapoi revine. Ceva similar remarcasem si la un beta mai vechi, dar acolo disparea la fiecare schimbare de canal.
    Cortorent, tu iesi cu HDMI direct in TV sau intr-un AVR (amplificator)? Eu am un AVR (Denon 1910).
    Cat despre patratele, asta seamana intr-adevar a semnal slab pe antena.
    21 Mar 2009
    Exclamation
    @proteus
    - legat de sunet, ies cu HDMI direct in TV, sonorul se modifica odata cu fragmentarea imaginii, mai ales pe CineStar, ActionStar, GigiFilm; fragmentarile de imagine sunt de cca 1sec la intervale de cca 4-10min.
    - semnalul de antena este foarte bun, pe nordici canalele HD merg foarte bine
