Page 1 of 8 12345 ... LastLast
Results 1 to 15 of 107
Thread: RSP E2 Sfinx Edition E2 RSPv3.98 TDT VER1749
    Default RSP E2 Sfinx Edition E2 RSPv3.98 TDT VER1749
    RSP e2 Sfinx Edition
    e2_RSPv3.98_TDT_VER1749
    UFS910 e2 stick image, all latest RSP updates included, based on TDT rev.1749
    AC3 DownMIX is NO longer mandatory.
    The most important thing that we want emphasize, regarding this new release, is that receiver is more stable now.
    In order to avoid annoying situations when receiver stop responding, you will find a new feature, EMUwatch, that can be enabled/disabled from the RSP panel, the Start/Stop EMU menu option and the main goal is to act like a watch-dog for your active EMU
    Many thanks to Team Ducktales for their Work!
    Team Ducktales:
    Twisted + 8.2
    + Various fixed volume
    + Tuner Driver advanced
    + To busybox stty, traceroute, netstat, and expanded
    + Fixed XML
    + Time synchronization with transponders will be forced
    + Tuner and CI separate kernel modules
    + Libeplayer2 http streaming mp4
    +Pace & implement a function for the SWTS-based playback
    + Add missing proc file
    + Set as default evremote2
    + Tuner2 cam and handling (trial version)
    + Separating individual driver code into the kernel modules
    + Splitted all the tuner and your controller
    + Libeplayer2 http streaming MP4
    + Player131 hopefully fix the problem of sound
    + Added runtime detection mp4
    + Vob/m2ts only sending pts on ***frames, this might lead to mutch smoother playback
    + Added the m2ts extension plugin mediaplayer
    + Default player switch 76 -> 131
    + Fixed mute on channel change
    + Fix error yellow button menu
    + Tuxtxt enable exiting
    + Reaenable page up and down ***s, also enable the menu ***s
    + Set Downmix on / off on the fly
    + Enhanced tuxtxt config
    + Video + some fixes
    + Updated patch network nits, this MIGHT have better nfs performance.
    RSP Update from last public image:
    -s-a introdus instalarea e2 direct din Panel
    -adaugat EmuWatch (auto-restart pentru IncubusCamd si Mbox)
    -procedura noua de despachetare a modulelor
    -adaugat in meniul de configurare A/V controale manuale pentru TINT, Contrast, Luminozitate (Brightness) si Culoare (Colour)
    -interfata web rsp-webif a fost temporar inlocuita cu cea preluata din imaginea Enigma2 Dreambox
    -reafisarea pe ecranul VFD a numelui canalului dupa ce a fost afisat mesajul de pornire emu
    -adaugata capabilitatea de montare a tuturor formatelor valide ale partitiilor Linux si Windows
    -mici modificari aduse in cwscript_e2.sh
    -introdus ShareInfo 2.21, descarcarea adresei de *** de pe serverul RSP
    -s-a introdus scriptul cwscript_e2.sh de actualizare SoftCam.*** (autor: stinkefisch)
    -au fost adaugate noi module plugin, cum sunt afisarea permanenta a ceasului pe ecran (Permanent Clock), editarea listei de steliti, si multe altele
    -configurarea implicita a CrossEPG a fost schimbata pe valoarea “small”
    - linia de program epg din fisierul /etc/init.d/rcS a fost eliminate
    pachetul de programme CrossEPG a fost actualizat, s-a adaugat si configurarea implicita a cestuia
    -s-a adaugat in nucleul imaginii comanda “ipkg”
    -au fost adaugate in imagine Restart_GUI si skin-ul BrushedAlu-HD
    -a fost actualizata lista de canale (Settings) de pe server, s-au operat mici modificari in partea de cod
    -reparat bug-ul cu subtitrarea si teletextul
    -s-a adaugat montarea manuala pentru /hdd/movie
    -s-a schimbat formatul listei de canale EnF, se descarca o zrhiva format zip
    -reparat bug-ul din meniul de configurare a pozitioner-ului, nu mai apar ecrane verzi la comandarea motorului
    -a fost inlocuit MyEPG cu CrossEPG
    -s-a introdus config.usage.on_long_powerpress=standby
    -a fost adaugata auto-testarea starii EMU dupa revenirea din starea de stand-by, se lanseaza auto-restart in cazul in care EMU e oprit (s-a adaugat emucheck.sh)
    -multi-bouquet
    -a fost adaugat config.usage.multibouquet=true
    in cazul in care se depisteaza absenta /hdd/movie se creaza in mod automat
    -a fost actualizat standby.diff
    -corectii asupra mesajelor afisate pe ecran
    -reparata resetarea camd3 emu dupa actualizarea de chei camd3 atunci cind camd3 nu este de fapt pornit
    -Added E2 Install from RSP Panel
    -Added EmuWatch (for auto-control of IncubusCamd and Mbox)
    -New modules unpacking procedure
    -added TINT, Contrast, Brightness, Colour in A/V settings menu
    -rsp-webif is temporary removed, classic web-if included in image
    -VFD restoring after emu start messages, former channel name back on VFD
    -mount all valid partitions, Linux and Windows
    -cwscript_e2.sh small changes
    -New ShareInfo 2.21
    -Update SoftCam.*** with cwscript_e2.sh by stinkefisch
    -More plugins added, such as Permanent Clock, Sat List Editor, etc.
    -Changed CrossEPG config default to small, removed epg line from /etc/init.d/rcS
    -Updated CrossEPG package, added default configuration
    -Ipkg added
    -added Restart_GUI and BrushedAlu-HD skin
    -Settings update from server, small changes on code
    -Subtitle & teletext bug solved
    -added manual mount for /hdd/movie
    -changed Enf list download to zip format
    -fixed “Positioner setup”, no more crashes on motor control
    -replaced MyEPG with CrossEPG
    -config.usage.on_long_powerpress=standby
    -added emu off state check and auto-restart emu on comeback from -stand-by (emucheck.sh added)
    -multi-bouquet
    -config.usage.multibouquet=true
    -add /hdd/movie if not exists
    -updated standby.diff
    -on screen display message corrected
    -fixed camd emu reset after camd3 *** update if camd3 emu is not started
    RSP Share Info for Incubus, Mbox, Mgcamd:
    TDT lucreaza si speram ca intre Craciun si Anul Nou sa avem imagini noi.
    Zildan & E2 RSP Team
    30 Dec 2008
    France
    excellent firmware
    NB : I tested a lot of points
    I had 2 troubles
    • with the green button ( no video size change ? )
    • interface ( yellow button in extension ) with webinterface
    Very happy with the emuwatch for incubus
    thanks a lot for your job
    Restart image after install is finished.
    04 Apr 2009
    Hello Zildan,
    Thankyou for the new Image !!!
    1) does this image correct the problems with incubus and NDS cs (> 800ms CW, etc)
    2) does this image include the new Video drivers (better quality HD & SD)
    3) which incubus version is better 4 that image ?
    Thankyou in advance,
    Konstantin
    Partially solved, the image works if DCW has over 800 MS delay.
    New drivers, but quality is not better.
    I think latest version is better.
    23 Nov 2008
    Primele impresii si probleme:
    Grave
    - crash in Media Player dupa ce se termina o melodie
    - pasii pentru reprodus:
    1 load mp3s in playlist
    2 start one of them with OK
    3 browse to another
    4 start this one with OK
    5 repeat steps 3+4 a few times
    6 leave mp3 play to the end
    7 at the end => crash
    - n-am reusit sa gasesc crashlog-ul
    - picture player-ul e inutilizabil
    - daca merge(rar) e infernal de lent
    - uneori nu incarca pozele deloc (cel mai des)
    - pozele de dimensiuni mari le refuza cu eroism
    - preview-urile sunt decodate ciudat, alb-negru si inclinat (pixel depth and/or format mismatch)
    - fara imagine imediat dupa instalare indiferent de satelit si post
    - face tuning (arata SNR, BER, EPG, etc/) pe canal dar nu arata nici o imagine
    - gaseste canale noi daca dai search
    - nu merge chiar daca descarci o noua lista din RSP Menu
    - merge dupa ce am incarcat o lista de la o versiune de E2 AAF
    mai putin grave sau minore:
    - nu face automount (la partitiile FAT32 cel putin) asta cred ca-i intentionata - dar se poate rezolva usor
    - nu citeste numele lungi de pe FAT32 - in Media Player totul arata aproape inutilizabil
    - nu vede in Media Player extensia .trp pentru fisierele salvate cu imaginea originala Kathrein
    - forever spinning cand am incercat sa pornesc un .ts inregistrat cu AAF last summer dream
    - forever spinning cand am incercat sa pornesc un .ts cu ceva HD content
    - in meniul principal de pe prima pozitie, cu sageata sus nu poti sari la ultima pozitie - asta inseamna ca pentru un restart tre sa dai vreo 10 sageata jos
    - dintr/un buchet nu poti sari la un alt buchet cu FF sau REW trebuie sa revii tot timpul la lista principala de favorite
    Cam astea pana acum.
    Crash in Media Player
    Problema cu media playerul e cunoscuta si se pare ca se rezolva abia prin imaginile peste 1850. Asta e un bug conoscut si dezbatut.
    Fara imagine
    La instalare dupa ce termini primul start este obligatoriu un restat !
    Aici nu e vorba de BUG! Pur si simplu abia dupa restart se considera instalata imaginea.
    Menu, Setup, Customize,Change buquets in quickzap
    dai sageata stanga si sare la ultima pozitie
    Ia vezi dupa restart merg?
    11 Apr 2007
    Cum se instaleaza direct din panel? Nu ma descurc deloc!
    04 Apr 2009
    Hello Zildan,
    thankyou for the Answers.
    I just activated the new RSP image with Incubus 0.96 as a client to a 7025 cccam 1.2, with EMU Watch activated.
    I will let it run to see if it continiues to crash or not.
    1) You mentioned that the problem is "Partialy" solved, what do you mean ?, are there more probs with incubs and cs ?
    2) Should the Software Manager work ?, cause for me it doesnt, just an empty box
    Thanky
    Konstantin
    06 Sep 2007
    Bravo maestre @zildan
    Cea mai buna imagine.
    Emuwatch e cel mai tare lucru. (asta in special pentru disperatii de zapping ,aici ma includ si pe mine)
    22 May 2009
    cluj napoca
    pe media player imi da green screen la mp3-uri,sar putea face ceva?
    A scris zildan mai sus.
    30 Dec 2008
    France
    24 hours with incubusCamd and 2 records : ok
    thanks a lot
    04 Apr 2009
    Unfortunately my setup lasted only 3 hours...then the UFS froze (at least no colorfull snow ;-)
    @Zildan
    Well seems that i am doing something wrong , if it works 4 others...
    can you please check my configs below ?
    Thankyou in Advance !
    @DreaNew
    you managed to get it to work 24 Hours... wow !!!
    What is your configuration ?, do you use internal cs ?
    ########################### general configuration ############################
    [General]
    # Enable (1) or disable (0) background execution
    # 0 - Off
    # 1 - On
    background_execution=1
    # This sets the level of console output for debugging:
    # 0 - No debug messages, 1 - First level debug messages, 2 - Second level debug messages,
    # 3 - Print all debug messages
    debug_level=3
    # This option enables (1) or disables (0) the writing of debug information to the
    # console.
    log_to_console=1
    # This option enables (1) or disables (0) the writing of console output to a log file
    log_to_file=0
    # When log_to_file is set to 1, this is the path and filename to write console
    # ouput to.
    logfile_name=/var/keys/incubusCamd.log
    # This is the path and filename to read SoftCam.Key file
    # by default it will be searched in the /var/keys directory
    softcamfile_name=/var/keys/SoftCam.Key
    # This is the path and filename to read prio file
    # by default it will be searched in the /var/bin directory, or in /etc, or in /var/keys
    priofile_name=/var/bin/incubusCamd.prio
    # Used to activate on-screen messages. Username and password required if
    # HTTP authentication is enabled on enigma.
    # 0 - Off
    # 1 - On
    on_screen_messages_show=0
    on_screen_messages_username=root
    on_screen_messages_password=
    on_screen_messages_key_update=0
    on_screen_messages_wait_for_key_update=0
    on_screen_messages_ecm=0
    on_screen_messages_emm=0
    # When activated, incubusCamd will listen on the specified port for connections. All
    # log activity will be broadcast in real-time to connected clients.
    console_logs_broadcast=1
    console_logs_broadcast_port=666
    # Enable/disable incubusCamd web interface (default port is 668).
    # 0 - Disable
    # 1 - Enable
    webif=1
    webif_port=1965
    [Prov:000000:CaID:0000]
    check_priority=cs,cs,cs
    cs_protocol_order=cccam
    #,newcamd,gbox,camd35,camd33,radegast,aroureos
    # Enable (1) or disable (0) emm process when a cs protocol is used
    # 0 - Off
    # 1 - On
    process_emms_on_cs_mode=0
    # Enable (1) or disable (0) emm g type process
    # 0 - Off
    # 1 - On
    process_emm_g=0
    # Enable (1) or disable (0) emm s type process
    # 0 - Off
    # 1 - On
    process_emm_s=0
    # Enable (1) or disable (0) emm u type process
    # 0 - Off
    # 1 - On
    process_emm_u=0
    # Enable (1) or disable (0) seca 3 ecm pid handler
    # when is set to On, it will try to use seca 3 ecm pid
    # before try seca 2 ecm pid, otherwise seca 2 pid will
    # be selected firstly
    # 0 - Off
    # 1 - On
    seca3_handler=0
    # This is the ChannelID wich will be used as first value
    # on irdeto channels. Value "-1" means no preferred channel id will be used
    # The value is expressed as decimal. Automatic change will be done.
    #chid=-1
    #[Prov:000501:CaID:1833]
    #check_priority=cs,emu,card
    #cs_protocol_order=cccam,newcamd,gbox,camd35,camd33,radegast,aroureos
    #process_emms_on_cs_mode=0
    #process_emm_g=0
    #process_emm_s=0
    #process_emm_u=0
    #seca3_handler=0
    #chid=-1
    ########################### servers configuration ############################
    [Servers]
    card_server_url=cccam://ufs910:ufs910@192.168.200.3:12000/yes/[EMM]
    ########################### CaIDs tunneling configuration ############################
    [CaIDTunnel]
    1833:1702:000000
    And the cccam Dreambox config:
    F: ufs910 ufs910
    c: xxxxxxxxxxx.dyndns.org 6666 dfgdsfgdsfgsd sdfgdfgdfgdgf no {0:0:3, 1702:0, 1722:0, 09c4:0}
    c: xxxxxxxxxxxxx.dyndns.org 7777 Kdfgdfgdfgdfg dsfgdfgdfg no {0:0:3, 1702:0, 1722:0, 09c4:0}
    # Other config settings #
    # server shall listen on this port pro incoming connections
    # default port is 12000, disable server with parm -s or set port 0
    #SERVER LISTEN PORT : 12000
    # server can give some info about server and client connections
    # and cardinfo using telnet or webbrowser.
    # Switch on/off access to info
    # default is yes
    #ALLOW TELNETINFO: no
    #ALLOW WEBINFO: no
    # Show extended client info when showing client list
    # default is yes
    #SHOW EXTENEDED CLIENT INFO : no
    # The webinfo service can be protected with a username and password.
    # This is switched off by default
    #WEBINFO USERNAME : <username>
    #WEBINFO PASSWORD : <password>
    # The telnetinfo service can be protected with a username and password.
    #TELNETINFO USERNAME : <username>
    #TELNETINFO PASSWORD : <password>
    # default port for telnet is 16000
    # default port for web is 16001
    # supported commands:
    # info
    # activeclients
    # clients
    # servers
    # shares
    # providers
    # entitlements
    # example use:
    # echo servers | telnet localhost 16000
    # go with your browser to http://ip_CCcam_server:16001
    #TELNETINFO LISTEN PORT : 16000
    #WEBINFO LISTEN PORT : 16001
    # time in seconds to keep On Screen Display active.
    # default is 0 (turned off)
    #ZAP OSD TIME : 3
    # username used to show popup (default : root)
    #OSD USERNAME : root
    # password used to show popup (default : dreambox)
    #OSD PASSWORD : dreambox
    # port used to show popup (default : 80)
    #OSD PORT : 80
    # Serial reader config. Add as many as you have attached too your system
    # replaces old name 'PHOENIX READER PATH', but still works.
    # default is none
    # optionally add readertype : phoenix,mouse,uniprog,sc8in1,smartreader+
    # (when non readertype given defaults to uniprog (e.g. for mastera))
    # SERIAL READER : <device> <type>
    # example
    #SERIAL READER : /dev/tts/0
    # Serial reader smartcard write delay.
    # Setting to finetune smartcard write speed, optimal setting depends on speed of system, and
    # speed of card. Default value is calculated, but can overrule by setting.
    # Use number of microseconds delay between bytes, 0 = no delay, -1 = calculated default
    # Note: huge difference between values 0 and 1, because of schedular overhead
    # SMARTCARD WRITE DELAY : <device> <delay>
    # example, 10ms write delay on smartcard in reader attached to /dev/ttyUSB0
    #SMARTCARD WRITE DELAY: /dev/ttyUSB0 10000
    # NOTE on sc8in1; because 8 smartcards are used on the same devicename, use
    # devicename_0 .. devicename_7 for settings which require devicename to make
    # settings per smartcard. example /dev/ttyS0_0, /dev/ttyS0_1 ..
    # example, 8ms write delay between bytes to smartcard on last sc8in1 channel, attached to /dev/tts/0
    #SMARTCARD WRITE DELAY: /dev/tts/0_7 8000
    # Smartcard clock speed override
    # Setting override specified speed for smartcard.
    # Don't add setting unless you're sure what you're doing.
    # In 99% of the cases the reader selects the optimal speed.
    # Adding this setting either slows your card down, or might destroy it.
    # SMARTCARD CLOCK FREQUENCY : <device> <freq>
    # example
    #SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB0 5500000
    # if timing should be shown in OSD and debug output
    # default is no (turned off)
    #SHOW TIMING : yes
    # enables mini OSD which shows server(type), cardreader, keys or fta only
    #MINI OSD : yes
    # turns debugging on and off
    #DEBUG : yes
    # should CCcam try to read and parse newcamd.conf for server connections
    #NEWCAMD CONF : yes
    # configure what EMM blocker you want. Add as many as readers you have attached
    # default is blocking nothing
    # B: /dev/sci0 01
    # 00 - nothing
    # 01 - sa blocked
    # 02 - ua blocked
    # 04 - ga blocked
    # and sum of for combinations
    #examples
    #B: /dev/tts/0 07
    #B: /dev/sci0 01
    # disable all local EMM readers
    # saves lots of CPU, but you won't get any updates anymore
    # (unless you get updates from your clients)
    # default: no
    #DISABLE EMM : yes
    # with this setting you can
    # allow a client on two hops away
    # to send the updates to the cardserver
    # default : no
    #EXTRA EMM LEVEL : yes
    # configure how many emm listeners are started.
    # for example use 2 when recording
    # and viewing different systems and both need constant updates
    # default : 1
    EMM THREADS : 2
    # overrule the nds boxkey (4 byte hex)
    # BOXKEY: <device> <byte1> <byte2> <byte3> <byte4>
    #example
    #BOXKEY: /dev/sci0 00 11 22 33
    # set card pin
    # * please be very careful with this option as you could lock your card *
    # PIN: <device> <pin>
    #example
    #PIN: /dev/sci0 1234
    # overrule the irdeto camkey (8 byte hex), default 11 22 33 44 55 66 77 88
    # CAMKEY: <device> <byte1> <byte2> <byte3> <byte4> <byte5> <byte6> <byte7> <byte8>
    #example
    #CAMKEY: /dev/sci0 11 22 33 44 55 66 77 88
    # overrule the irdeto camdata (64 byte hex)
    # trailing zero bytes can be omitted
    # default for unknown ASC's is 11 22 33 44 55 66 77 88 00 00 .. 00, known ASC's have other defaults
    # CAMDATA: <device> <byte1> <byte2> <byte3> <byte4> <byte5> <byte6> ... <byte64>
    #example, when only the first 15 camdata bytes are nonzero
    #CAMDATA: /dev/sci0 11 22 33 44 55 66 77 88 99 aa bb cc dd ee ff
    # custom add id's for BEEF patched cards
    # BEEF ID: <ident1> <ident2> <ident3> <ident4> <ident5> <ident6> <ident7> <ident8> <device>
    #example
    #BEEF ID: 4101 0 0 0 0 0 0 0 /dev/sci0
    # what Softcam.Key should CCcam try to read
    # defaults to /var/keys/SoftCam.Key
    #SOFTKEY FILE : /var/keys/SoftCam.Key
    # what AutoRoll.Key should CCcam try to read
    # defaults to /var/keys/AutoRoll.Key
    #AUTOROLL FILE : /var/keys/AutoRoll.Key
    # what constant.cw should CCcam try to read
    # defaults to /var/keys/constant.cw
    # file content can be like
    # ca4:id6:sid4:pmtpid4:ecmpid4:key16(01 02 03...)
    #STATIC CW FILE : /var/keys/constant.cw
    # in this file you can configure what CAIDs CCcam should prefer or ignore
    # defaults to /var/etc/CCcam.prio
    # file content can have ignores (I) and prio lists (P)
    # note 1: I line affects both for ecm and emm (receive no emm on ignored systems)
    # P line only affects ecm choice (emm still received for all available systems, not just the priority system)
    # note 2: ident 0 means 'all idents'. So 'caid:0' is the same as 'caid'.
    # note 3: for some systems (e.g. nagra (caid 18xx)), the ident is not known at the time the
    # prio lists are checked. In that case, matching is done on caid only, even if the P line
    # defines nonzero idents. So for example '1801:401' behaves the same as '1801' in a P line
    # I lines work differently, they are checked two times, once before ecm or emm is received, again
    # after ecm or emm are received (and nagra ident should be known)
    # P lines are only checked once, before ecm received.
    # note 4: if a P line contains caid:ident pairs which are not available for the current
    # channel, that P line is not used for that channel.
    # Example, channel has systems 626, 1801:401 then P line with "1801,100:96,626" is ignored by that channel,
    # because channel doesn't have 100:96.
    # But P line with "1801" works, and also "626,1801" will work for channel
    # note 5: P lines are parsed in the order in which they are found in the prio file.
    # Only the first matching P line is used
    # situation 1: ignore allways this caid, all idents, on all channels
    # I: caid
    # situation 2: ignore allways this caid/ident pair
    # I: caid:ident
    # situation 3: ignore this caid/ident pair, on channel 'sid'
    # I: caid:ident:sid
    # situation 4: when both caid1 and caid2 exist for a channel, prefer caid1 over caid2
    # P: caid1, caid2
    # situation 5: when caid1:ident1 till caidN:identN exist for a channel, use them in order of this list.
    # P: caid1:ident1, caid2:ident2, .., caidN:identN
    # situation 6: when caid1:ident1 till caidN:identN exist for channel 'sid', use them in order of this list.
    # Sid on first caid/ident pair identifies sid for which list is used. All other sids ignore this list.
    # P: caid1:ident1:sid, caid2:ident2, .., caidN:identN
    #CAID PRIO FILE : /var/etc/CCcam.prio
    # In this file all provider idents are defined
    # The info from this file is being used in the web interface
    # format:
    # <caid><ident> "Provider description"
    # PROVIDERINFO FILE : /var/etc/CCcam.providers
    # In this file all channel idents are defined
    # format:
    # caid:ident:sid "Channel description"
    # CHANNELINFO FILE : /var/etc/CCcam.channelinfo
    # write wrong logins to file
    # defaults is off
    #LOG WARNINGS : /tmp/warnings.txt
    # global setting for stealthy login to newcamd/newcs server, N line can overrule
    # stealth modes: 0 = disabled, 1 = mgcamd new, 2 = mgcamd old, 3 = evocamd, 4 = generic
    # default: 0
    #NEWCAMD STEALTH : 0
    # load balancing between identical cards, list device names of card readers containing identical cards,
    # optionally followed by a list of service id's which are to be excluded from loadbalancing
    # LOADBALANCE : <device1> <device2> .. <devicen> { <exceptsid1>, <exceptsid2> .. , <exceptsidn> }
    # multiple loadbalance groups can be configured, by adding multiple lines
    # warning: restart is required, when loadbalance group config changes
    #example 1: load balance requests for three identical cards
    # LOADBALANCE : /dev/ttyS0 /dev/ttyS1 /dev/ttyS2
    #example 2: load balance requests for two almost identical cards, sid 0df3 and 0de1 are only available
    #on one of the cards, so requests for these sids shouldn't be loadbalanced
    # LOADBALANCE : /dev/ttyS5 /dev/ttyS6 { 0df3,0de1 }
    # in version 1.2.1 and lower there was a problem which could lead to disconnecting clients
    # in version 1.4.0 network load was significantly reduced
    # in version 1.7.0 dangerous password bug was fixed
    # in order to take advantage of these fixes, all clients should upgrade
    # with this setting you can force that clients at least use a certain version otherwise they are denied when logging in
    # default : accept all versions
    #example 1: avoid disconnecting clients problem
    #MINIMUM CLIENT VERSION : 1.3.0
    #example 2: achieve network load decrease
    #MINIMUM CLIENT VERSION : 1.4.0
    #example 3: don't allow potentially wrong passwords (pre 1.7.0 has password bug)
    #MINIMUM CLIENT VERSION : 1.7.0
    # Irdeto smartcards: option to disable smart chid checking for irdeto smartcards.
    # Default, only chids advertised by card are accepted.
    # This avoids a lot of unwanted card traffic
    # But if smartcard has hidden/unknown chids, all chids should be tried.
    # In that case specify 'TRY ALL CHIDS' option for cardreader.
    # Use with care, enabling option causes more card traffic.
    # Only use setting when some channels don't work without it.
    # note: if even this setting don't help decode all channels, try using
    # commandline arg -l, to disable all self-learning features (warning: slower)
    #TRY ALL CHIDS : <device>
    #example: card in /dev/ttyUSB0 gets ecm for all possible chids, not
    #just the chids it officially supports
    #TRY ALL CHIDS : /dev/ttyUSB0
    # perform smartcard post init commands
    # POSTINIT : <device> <filename> (<autodelete>)
    # send commands in 'filename' to 'device', and delete 'filename' when
    # optional 'autodelete' argument nonzero
    #example:
    #POSTINIT : /dev/sci0 /tmp/postinit
    #example /tmp/postinit contents:
    #c134000003000000
    #c13201000a
    # Option to override autodetected dvb api version. Restart needed.
    #DVB API: <value>
    # <value> -1 = no dvb, 1 = dvb api 1, 3 = dvb api 3
    # WARNING: only use when autodetect fails!
    #example, disable nonworking dvb hardware:
    #DVB API: -1
    # Option to set global share limits
    #GLOBAL LIMITS: { caid:id(:downhops), caid:id(:downhops), ... }
    #example:
    #GLOBAL LIMITS : { 0100:000080, 0622:000000:1, 0500:000000:2 }
    # all users get no 0100:000080.
    # and our 0622:000000 cards only for themself (1 hop down),
    # and 0500 cards for themself plus one additional hop down.
    # global limits are overridden by client specific limits (see F:)
    # Option to reject shares with less than required downhops on clientside
    #MINIMUM DOWNHOPS: <value>
    # default: 0 (don't ignore any shares)
    #example:
    #MINIMUM DOWNHOPS: 1
    # ignore shares that have less than 1 'downhops' (i.e. can not be shared
    # further down to other clients)
    # Option to ignore all shares that go through a certain node
    #IGNORE NODE: <nodeid>
    #example, ignore two nodes:
    #IGNORE NODE: ccd536ab515767ad
    #IGNORE NODE: aad536ab515761af
    # The seca handler is used to better support simulcrypt on the same ident
    # With this setting you can change the behaviour of how SECA has to be used
    # This setting is ignored unless SECA2/SECA3 simulcrypt is detected!!
    # When disabled CCcam behaves like previous versions
    # When "prefer SECA3 over SECA2" is enabled try to use SECA3 ecm first, then SECA2
    # When "Ignore SECA2" is enabled, ignore all SECA2 ecm so a SECA3 card will not get SECA2 request which it cannot handle
    # When "Ignore SECA3" is enabled, ignore all SECA3 ecm so a SECA2 card will not get SECA3 request which it cannot handle
    # The following settings can be used
    # SECA HANDLER: <value>
    # <value> : 0 = disabled, 1 = prefer SECA3 over SECA2, 2 = prefer SECA2 over SECA3, 3 = Ignore SECA2, 4 = Ignore SECA3
    # default: 1
    # Example try to use SECA3 ecm first, then SECA2
    #SECA HANDLER: 1
    # Example try to use SECA2 ecm first, then SECA3
    #SECA HANDLER: 2
    # Example to ignore all SECA2 ecm so a SECA3 card will not get SECA2 request which it cannot handle
    #SECA HANDLER: 3
    # Example to ignore all SECA3 ecm so a SECA2 card will not get SECA3 request which it cannot handle
    #SECA HANDLER: 4
    Following my Setup:
    UFS 910 CLIENT with sfinx Image, EMUWatch enabled, Incubus 0.96
    Dreambox 7025 SERVER with Nabilosat 0.11 Image, Cccam 1.2, Local
    Sky Germany A02 Card (Betacrypt tunneled in Nagra i think).
    Cheers,
    Konstantin
    Following my Incubus config:
    30 Dec 2008
    France
    Quote Originally Posted by zyxel13 View Post
    @DreaNew
    Yes with my dm7000 and 2 cards
    yes, me too , I checked my records, and i saw some freezes, but the movie cames back without personal action.
    I write in green fonts my config
    Following my Incubus config:########################### general configuration ############################
    [General]
    # 0 - Off
    # 1 - On
    background_execution=1 0 to avoid memory trouble
    debug_level=3 0 to avoid memory trouble
    # console.
    log_to_console=1 0 to avoid memory trouble
    log_to_file=0
    # ouput to.
    # 0 - Off
    # 1 - On
    console_logs_broadcast=1 0 to avoid memory trouble
    # 0 - Disable
    # 1 - Enable
    webif=1 0 to avoid memory trouble
    webif_port=1965
    check_priority=cs,cs,cs check_priority=cs
    # 0 - Off
    # 1 - On
    process_emms_on_cs_mode=0 process_emms_on_cs_mode=1
    # 0 - Off
    # 1 - On
    process_emm_g=0
    # 0 - Off
    # 1 - On
    process_emm_s=0
    # 0 - Off
    # 1 - On
    process_emm_u=0
    # 0 - Off
    # 1 - On
    seca3_handler=0
    #chid=-1
    #process_emm_g=0
    #process_emm_s=0
    #process_emm_u=0
    #seca3_handler=0
    #chid=-1
    ########################### provider configuration ###########################
    check_priority=cs
    process_emm_g=0
    process_emm_s=0
    process_emm_u=0
    seca3_handler=0
    #chid=-1
    [Servers]
    [CaIDTunnel]
    1833:1702:000000 for my cards , no caid tunnel
    F: ufs910 ufs910
