Results 1 to 15 of 26
Thread: OSCAM 0.99.4rev5x-cardserver
    95 Post(s)
    Default OSCAM 0.99.4rev5x-cardserver
    Deschid acest topic pentru cei care sunt interesati de SKi lT si au cardul de SKl in local!
    OSCAM este cardserver ca si Newcs
    Aveti atasata arhiva cu executabilul pentru:
    i686 / sh4 / ppc / mipsel
    Exemple de config :
    .conf
    [global]
    nice = -1
    WaitForCards = 1
    [monitor]
    port = 988
    aulow = 120
    monlevel = 0
    [newcamd]
    port = 34000@093b:000000
    .server
    [reader]
    Label = SkyItalia
    Protocol = Intern
    Detect = CD
    Device = /dev/sci0
    group = 1
    CAID = 093b
    BoxID = ######
    #savenano = all
    Customspeed = 0
    EMMCache = 1,3,2
    Fallback = 0
    #blockua = 0
    #blockga = 0
    #blocksa = 0
    #AU = 1
    #Enable = 1
    .user
    [account]
    user = user
    pwd = pass
    group = 1
    uniq = 1
    caid = 093b
    ident = 093b:000000
    AU = SkyItalia
    monlevel = 0
    Acum sa trecem la teste!
    Attached Files Attached Files
    10 Oct 2009
    In majoritatea capitalelor EU
    Cum si unde se instaleaza oscam
    13 Feb 2007
    Earth
    Post
    '' example how to config for sky it working on Dreambox
    Put the bin in /var/bin (e1) or usr/bin (e2) atributes 755
    Put the 3 files:
    oscam.conf
    oscam.user
    oscam.server
    in /var/tuxbox/config (e1) or etc/tuxbox/config (e2)
    oscam.conf
    [global]
    nice = -1
    WaitForCards = 1
    [monitor]
    port = 988
    aulow = 120
    monlevel = 0
    [newcamd]
    oscam.server
    [reader]
    Label = SkyItalia
    Protocol = Intern
    Detect = CD
    Device = /dev/sci0
    group = 1
    CAID = 093b
    BoxID = ###### (your BoxID)
    #savenano = all
    Customspeed = 0
    EMMCache = 1,3,2
    Fallback = 0
    #blockua = 0
    #blockga = 0
    #blocksa = 0
    #AU = 1
    #Enable = 1
    oscam.user
    [account]
    user = user
    pwd = pass
    group = 1
    uniq = 1
    caid = 093b
    ident = 093b:000000
    AU = SkyItalia
    monlevel = 0
    CCcam.cfg
    N: 127.0.0.1 34000 user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256 ''
    download :
    http://rapidshare.de/files/48711895/...talia.rar.html
    *preluat de pe un forum ( eu nu am testat , nu am la indemana dm ul ..... sorry )
    95 Post(s)
    Merge perfect, puneti la toate cardurile de SKl asa ca sa nu mai vina fake din cartile puse normal.
    OSCAM este ce era NEWCS!
    IN CCCAM sau MBOX puneti linii de newcs, la cccam cu 256 dupa!
    13 Feb 2007
    Earth
    Post How to start OScam from telnet
    Thx to CCCam Team.
    login into your box with telnet
    call the directory by typing the below command and press enter
    cd /var/bin
    use the command to list all the files in the directory
    ls
    after this a list of files should be listed
    look closely at the filename of oscam
    and type the following replacing filename.ext with the one you see in the list
    ./filename.ext &
    depends what you have in the config files you may see the debug on screen or just nothing happens on screen
    you can open another telnet session in case needed and type the following command to confirm that oscam is running, if it is running you should see in the list filename.ext (depends on the oscam name)
    ps -A . ''
    23 Nov 2008
    Default salut
    cer scuze ,si rog pe cei ce au instalat acest OSCAM
    in dream sa spuna mai exsact unde trebuie instalat
    si cum.
    am dream 7020si ,,gemeni.
    va salut.
    Acest emu este util/necesar numai celor ce au card Sky it!
    RSP - Team dan2000's Avatar
    28 Feb 2007
    roma
    cred ca acest emu va deveni ceea ce a fost pana acum newcs, poate chiar mai mult. sa speram ca va ramane open...
    95 Post(s)
    Default oscam-0.99.4.522svn-ppc-tuxbox-linux-dbox2 win
    oscam-0.99.4.522svn-ppc-tuxbox-linux-dbox2-win
    Mama m........ de roman , toti se dau "zmei" pe aici da nici unul nu explica si pt. cei mai neinitiati
    Dupa ce a-ti descarcat/dezarhivat "oscam_r519 sky it" , veti avea in acest folder 6 fisiere , si-le copiati cu dcc -ul pt. e1 ( e2 inca nu am incercat ) :
    - oscam.config
    - oscam.server
    - oscam.user
    Toate 3 copiate in var/tubox/config cu atribut 755
    - oscam_r519.ppc
    Copiat in var/bin cu atribut 755
    Apoi va duceti si editati fisierul "oscam.user" tot din dcc :
    oscam.user
    [account]
    user = user care-l folositi la linia N
    pwd = pass care o folositi la linia N
    group = 1
    uniq = 1
    caid = 093b
    ident = 093b:000000
    AU = SkyItalia
    monlevel = 0
    Acum tot cu dcc-ul va duceti la var/etc/cccam.config si copiati linia N:
    - N: 127.0.0.1 34000 user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256 sau
    - N: 127.0.0.1 34000 user pass 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D
    - USER si PASS ( din linia N ) sant cele scrise in fisierul oscam.user
    La sfarsit da-ti un restart la dm
    ZILDAN EDIT: Acest soft este un CARD SERVER, daca nu aveti cardul in aparatul vostru nu aveti ce face cu softul !!!
    95 Post(s)
    Default oscam-0.99.4.523svn
    oscam-0.99.4.523svn-i686-pc-linux
    oscam-0.99.4.523svn-powerpc-tuxbox-linux
    oscam-0.99.4.523svn-sh4-linux
    oscam-0.99.4.523svn-mipsel-tuxbox-linux
    29 Mar 2009
    Austria - TM
    Thumbs up no local no instal
    @mario08
    E adevarat ce zici tu dar o mica paranteza
    Daca nu ai local karte de sky italia nu trebuie sa faci nimic trebuie doar sa astepti päna cänd parteneri tai de sharing instaleaza oscam
    Merge fara nici un seting probat de mine la un Dm 800 & 8000 CCcam 2.1.1 & 2.1.3
    Am probat la 8000 si cu karte si merge daca faci setingul box-id
    E ceva de genul digi cartela + rec
    Stati linistiti si asteptati päna partenerii de schimb cu local vor instala oscamul si veti putea viziona linistit ( daca nu i-ati sters )
    NU INSTALATI NIMIC DACA NU AVETI KARTE SKY ITALIA
    26 Dec 2008
    Dublin, IRL
    daca citesti tot thread-ul si nu doar ultimul post, iti dai seama clar ca e card server, si merg si alte carduri, nu e doar pentru Sky IT! Marele plus se pare ca poti filtra si in CCCam nu mai ai 3 CAID pentru TVR
    12 Mar 2009
    Salut,am un 7020 si am facut exact asa cum a postat Mario(multam Mario) si nu se lumineaza nimic,mentionez ca am sky it.in local.Rog ajutor
    Standard RSP member cristilamb's Avatar
    04 Feb 2008
    Merge si pe kathrein cu cardul connax autohton in phoenix.Am incercat si cu cel nds, dar in continuare nu vrea in phoenix.
